Question about Airtronics Toys
Left goes to the right
If i give my control gas it brakes if i turn left it will go right whats the problem
The switches on the remote can change the direction of servo throws, you just need to flip the switch on the reversed channels.
Posted on Dec 07, 2011
  • 15,935 Answers
Youre holding the remote upside down. Turn it arouns d - problem solved.
Posted on Dec 28, 2008
  • blueextc3221
    blueextc3221 Dec 28, 2008
    I thought it was a trick question - Sorry
  • blueextc3221
    some toys have leftie control switches on the controller, so they can really hold it upside down to let their predominent hand be in control. Look for a switch on the controller.
Probably a really simple question, but on a Mercury Mystique 1997 (manufactured 1996) brake master cylinder (with ABS), which port, front or rear, leads to the front wheel section of the ABS module?
Off the master cylinder. The front tube controls the rear brakes. And the back one controls the front brakes. Just a note. I don't know which year they started doing this, but, the front right brake goes/ties in to the left rear brakes. left front to right rear. This set up runs off the ABS module to the brakes.
Mar 01, 2015 | 1997 Mercury Mystique
Intermittent buzzing sound at turn signal switch - 97 suburban
You found it. and you verified it the solution and the fix is the turn signal switch
Mar 17, 2012 | 1997 Chevrolet Suburban
Need to wire sockit on toebar need help with wire colour aliment
green, right turn /right brake yellow(or red with really old stuff) left turn/brake, brown, running lights(GOES TO BOTH SIDES) and usually what's left is white, which would be your ground. Good luck
Mar 10, 2011 | Toyota Highlander Cars & Trucks
Left blinker flash fast, hit brake left blinker goes out left taillight goes out but both backup lights come on
Usually a fast flashing signal is because one of the bulbs is burned out or shorted out. If the signal and brakes use the same light which many cars do then check the wiring to it and replace bulb. If burns out again then it has a short between the signal switch and the actual light or the brake wiring to it is shorted.
Sep 03, 2010 | 1999 Chevrolet Silverado 1500
Which colour wire to use to hook up a trailer for a Kia Carnival 2000,trailer leads are yellow, green,black,brown,red,white and blue(no connection). just want to know which lead goes to which in the Kia?...
Here is a cheat sheet I compiled that you will find very helpful:
Plug Types/Application
7 Way - RV Trailers, Horse and Utility Trailers
6 Way - Horse, Stock and Utility
4 Way - Utility Trailers
Columns are Color, Function, Mark on the plug.
Seven wire Trailer plugs
Horse, stock or utility trailers:
White = Ground - 1
Blue = Electric Brakes - 2
Brown = Tail and clearance lights - 3
Black = Battery, aux power - 4
Yellow = Left turn/Brake - 5
Green = Right turn Brake - 6
Orange or Purple (not both) = Auxilliary or Reverse - 7
Recreational Vehicle:
White = Ground - 1
Green = Tail and clearance lights - 3
Red = Left turn/Brake - 5
Brown = Right turn Brake - 6
Yellow = Auxilliary or Reverse - 7
Six wire trailer plugs:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Yellow = Not used -
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Four wire plugs:
White = Ground
Ground should be 10ga.
Others 14 ga
Best regards
Mike
Oct 28, 2009 | 2000 Kia Amanti
Toys Logo
110 people viewed this question
Top Airtronics Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Airtronics Toy Expert? Answer questions, earn points and help others
