Question about Hunter 52" Ceiling Fan With Light And Remote Control
Ceiling fan remote will not turn on light
I have a hunter ceiling fan with remote..the remote turns on the fan and adjusts speed but will not turn on the light. how can i fix this ?
  • 8 more comments
  • Anonymous Mar 16, 2014
    chair broke and now unable to change the speed of the fan, still works well at the setting. Is there some where in my area (19136) where I can drop off for repair?
    Remote works for light but not fan
    ceiling fan turns on by itself. It has a hardwired switch and also a remote
  • Anonymous Mar 17, 2014
    Fan turns on at any time by itself
  • Anonymous Mar 22, 2014
    Wiring
    Hello; I have 2 identical ceiling fans in one room using 1 remote. the remotes no longer work on either fan, on/off, speeds or lights. When using the chains on either fan the lights don't work and neither fan has high speed. What should I try?
  • Anonymous Mar 27, 2014
    remote handset will light up but will not work on the fan
  • Anonymous Mar 29, 2014
    Remote part 85094-02
  • Anonymous Mar 31, 2014
    ceiling fan lights blink
  • Anonymous Apr 01, 2014
    Ceiling fan remote avion
    President:
  • 379 Answers
Common problem , i went to home depot and bought a new remote for my hunter fan , and it worked again , salesman was very knowledgeable and helpful . thanks. explain the problem to him , he can help .
Posted on Dec 30, 2008
  • Rick Byrd
    Rick Byrd Jan 03, 2009
    follow up - was this information worth a FIX YA vote ? thanks for voting ! .
I have a problem with my Hunter Newburgh Type 2 ceiling fan.
Likely a defective receiver 20 ft. above but could be a defective remote control. This is a common failure in remotely controlled fans.
Sep 30, 2017 | Hunter Dryers
How to fix ceiling fan light
Make sure the light wire is connected to the receiver & bottom of fan.You should set the light to the on position when using the remote and leave it that way.
Sep 10, 2015 | Hunter 52" Ceiling Fan With Light And...
My hunter ceiling fan turns very slow
Check your capacitor. If this is an add on remote, set the fan on high with the remote then pull the chain on the fan until you get high speed.
Sep 17, 2014 | Hunter 52" Ceiling Fan With Light And...
Remote will not turn on fan. A ll I get is a click.Light works fine
How i fixed my Hunter #28096 remote controlled ceiling fan, started not controlling the light, then later the fan quit also. Start by testing the remote buttons, see this post... http://www.fixya.com/support/t11813083-cp9430r Cp9430r Fixya
May 30, 2014 | Hunter Ceiling Fan Light Remote Control
My Hunter ceiling fan remote works fine with the fan. I can turn it on or off and adjust to all 3 speeds but it will not turn the light on or off.
Make sure your light wires are connected at bottom of fan. If this was an add-on remote ,make sure the light wire at the receiver is connected.If there is a pull chain on the light, make sure it's in the on position.
Apr 06, 2013 | Dryers
I have a Hunter ceiling fan with a remote control model number 85095. The remote will turn the fan on and off and change the speeds but it will not turn the light on or off anymore. Any help?
Make sure the wires to the light kit are connected to the light & light wire connected in ceiling.If that's not your problem then you probably need a new receiver. Call 1-888-830-1326 and have your FAN model handy.Should be a five digit number beginning with a 2.
Jan 14, 2013 | Hunter Ceiling Fan Remote Transmitter...
My hunter remote control ceiling fan doesn't go real fast. the highest speed is what a normal fan would do on medium. is there a fix?
if you have pull chain switches in addition to the remote control, your pull chain switch may be set to Medium, which would make the fan run on a maximum of medium speed.
May 16, 2010 | Hunter 52" Ceiling Fan With Light And...
I have a Hunter fan with remote. The fan or the light comes on by itself with no one around
See my post below: (Sorry, we're in the same boat)
Hunter ceiling fan with remote, have 5, 4 are seriously impaired! Lights dim to half strengh after variable time 10 seconds-30 minutes. And lights or fan turns on randomly (come home & fan on full blast), and one in which the lights won't dim (just blinks when try to dim)! Hunter "kinda" admits there is serious problem with remote but doesn't have a solution. Tells people to try changing to different code due to possible interference (pain in **** to change code on ceiling base!), was totally ineffective. Then replaced receiver in ceiling base (another total pain) in 3 fans with new ones sent Hunter, still totally useless. Hunter's suggestion, don't use the remote, just use the pull chain. If I had wanted a pull chain fan, I'd have bought a pull chain fan. TOTALLY USELESS! Moral of story: If you want a remote ceiling fan (my friend found out that all their remotes are made by the same company in Taiwan), don't buy Hunter!!!!! P.S. I found a "Kinda"- fix for the lights dimming to half strenth. After turning on the lights, wait 1 second, then dim lights slightly, they will then stay on the strength that you dim them to. - P.P.S. When I changed the receiver in the one where the lights won't dim, it "solved" that problem...Now it has the same problem as the others, lights or fan turn on randomly!
Apr 02, 2010 | Hunter 52" Ceiling Fan With Light And...
HUNTER ceiling fan remote works with fan but not light
Unfortunately, you either have a faulty reciever or remote. A replacement will cost $30-$40 at homedepot2.gif. And it doesn't matter which is faulty because you can't purchase them seperately anyhow.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jerry_612d8419f8984578
Sep 08, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
Dryers Logo
1,899 people viewed this question
Top Hunter Dryers Experts
Joe Paxton
Level 1 Expert
Paul Bade
Craig Butler
Craig Butler
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
