Question about Pyle Car Audio & Video
Having trouble installing my Pyle PLDBT30U
Is there an extra wire you have to get besides the standard wire harness to install a Pyle PLDBT30U? There looks like there is another wire i need to buy, but i am not sure if i have cut the wires or buy a new wire harness.
  • charlessmell Dec 28, 2008
    It is a 2006 Hyundai Sonata
  • blueextc3221
    blueextc3221 May 11, 2010
    depends on the vehicle you are installing it into. Please update so i can help.
  • 15,935 Answers
Your part number is Metra 70-5520
It is a standard Ford plug, but is used on your car as well.
Only 1 plug is necessary
See link - http://cgi.ebay.com/FORD-2003-2007-HARNESS-METRA-70-5520_W0QQitemZ170248469364QQcmdZViewItemQQptZCar_Electronics_Installation?_trksid=p3286.m20.l1116
i dont think this model has a premium sound upgrade.... could it be a changer cable?
Posted on Dec 28, 2008
  • blueextc3221
    blueextc3221 Dec 28, 2008
    Radio 12v
    orange
    radio harness
    Radio Ground
    black/orange
    radio harness
    Radio Ignition
    yellow
    radio harness
    Radio Illumination
    brown/white
    radio harness
    Factory Amp Turn-on
    lt. green
    radio harness
    Power Antenna
    gray
    radio harness
    LF Speaker +/-
    tan - black
    radio harness
    Notes: If equipped, the amplifier is in the passenger side of the trunk.
    RF Speaker +/-
    blue - red
    radio harness
    LR Speaker +/-
    white - brown
    radio harness
    RR Speaker +/-
    orange - green
    radio harness
  • blueextc3221
    These are the wire codes to help u identify the plug in question.
    If you have a factory amp, it is located in the trunk (passenger side), and you will need to unplug and bypass the hi-level inputs (in) to the amp to the (out) of the amp. Like a jumper cable - otherwise the radio will not be loud (if it plays at all)
    heads up!
Pyle PLDNV695 radio. How do I install it?
You need an interface module so it will work with the vehicle ! The radio is hooked up to the class 2 serial data bus , if you don't hook it up right the vehicle will not start an run !
Feb 24, 2015 | 2002 Chevrolet TrailBlazer
How to install Pyle radio PLR31MP
remove factory radio ,if you dont have the special tool to do this you can use coat hangers but I perfer using the factory tool sold at wallmart (the cheepest) or autozone push tools into holes on both ends of radio pull radio out. disconect wireing harnes and antenna wire.To install new radio you will need a wireing adaptor and a install kit. These must be spasific to your vehicle. you can buy these online Ebay , or Amazon or off line wallmart or orillys auto parts you will have to connect your new radio wiring harness to wiring adaptor.put install kit on new radio attach antenna wire connect wireing adaptor to original radio wiring push radio gently back into dash with install kit attached. enjoy your new radio. if this was helpful please leave good feed back.
Jan 03, 2015 | 1998 Ford Ranger
1996 Ford Thunderbird Stereo deck installation issues. I purchased a Pyle Deck and the wiring from the stock stereo has no instructions to crimp which wires to which. The Pyle deck has the instructions on...
Your best would be to buy a harness adapter to connect the new deck through the adapter into the existing OEM wire harness connector. It makes things so much easier and more reliable.
Oct 19, 2013 | Pyle Car Audio & Video
Install rear backup camera
PYLE, 3.5 MONITOR INSTALLATION INSTRUCTIONS, INSTALLED IN SUV. As others have mentioned ThePyle Instructions are pretty much non-existant. As a formerly ASE Certified mechanic I am posting this to try to help others.THE PYLE KIT: Monitor + Camera Mount + Wiring Harness for hard wiring into vehicle electrical. --- Additional Materials Required to Install: 3ea. coils of automotive 18 ga. wire. One red, one black, and one white. 1/8" non insulated wire but connectors, wire shrink wrap (1/4", 3/16\', 5/16" AND 3/8" best to get assort. pack). Self taping sheet metal screws 1/2" long. Roll of electrical tape, Barbed Butt Connectors (2ea.- see illustration wiring Monitor posted this site). Rubber wire grommet 3/8" outside, 1/8" for wire, 1ea. req. Pull ties. --- Tools Required: Utility Knife, Drill w. phillips bit driver, wire tripper, volt meter, small pry bar. + Misc. ---
Mar 16, 2013 | 2004 Hyundai Santa Fe
Install pyle radio in 1996 monte carlo
Get the proper dash kit end wireing harness adapter kit, That plugs into the factory radio wireing harness, That is the easist way to do it,
Dec 04, 2012 | Pyle Plr34m In Dash Usb Sd Aux Am Fm Car...
Can some1 please tell me how to connect all the wires with my chvy wireing harness just to make sure im doing it right, because the unit doesn't turn on...
red-power(keyed), yellow-power(constant), black-ground. If you're having problems installing it, try powering it on with your'e car battery, if that works you have a blown fuse in the system.
Sep 05, 2009 | Pyle PLTDN71 Car Video Player
Where can i find a place where i can get my back wires connections for a pyle view pldbt30u car stereo
The owners manual.
CLICK HERE
Page 4 (3 actual) is the wiring diagram.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Aug 19, 2009 | Car Audio & Video
Wiring in oven
If you are saying you are re installing this oven, then what did the 2 other wires go to before?
Feb 15, 2009 | KitchenAid Ovens
Wiring troubleshoot
Make sure that your car is not amplified!! Some Celicas have an amplifier under the passenger seat. If this is the case, you will need to either bypass that amplifier and go directly to speakers, or you'll need the proper interface plug. The extra rapid heat build-up indicates that your radio is incorrectly wired (channels are mixed up)
Your Pyle radio may have an extra wire for "amplifier turn-on" or for "mute". A standard wiring harness for Toyota (Scosche part TA-02B) should work in dash behind the radio in non-amplified vehicles. If you are still having difficulty, please seek advice from a local stereo installation shop.
Aug 10, 2008 | Car Audio & Video
Car Audio & Video Logo
558 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
