Question about Apple LaserWriter 8500 Printer
Printing Error I cannot print from my Macintosh to my printer because it keeps coming up with a "paper misfeed" error. I have done everything short of turning it upside down and shaking it (only because its too heavy) to find where the misfeed is, but there is absolutely nothing jammed anywhere. I think it must be a jammed microswitch somewhere but I don't. Has anyone else experienced this and if so how did they fix it. Thanks in advance.
Another problem which occasionally occurs is a paper jam or misfeed will fool the printer in thinking that it is getting a long piece of paper. You have to restart the printer to clear this.
Posted on Jan 17, 2008
  • 23 Answers
You're problem is not with the printer. It is the set up you are using in the program you are sending to print for example: in InDESIGN after you hit apple P for the print command you will have a dialog box that says printer (the middle top) you will need to select your printer also at the bottom there is a printer button which must also be selected with your printer. Whatever program you are running will need to be set to the printer you are printing to. if you do not see your printers ID you will need to "add printer" and search out the proper driver for your printer.
Posted on Jul 11, 2007
  • elaine orth
    elaine orth Jul 11, 2007
    also you must choose the right paper size in the set up area. If you do not the printer will think the paper is odd sized and send it to manual feed.
Konica C550 Misfeed error how to get rid of it?
I know this sounds silly but some try flipping the paper over, then try turning it 180 degrees. Printer paper has a grain (a direction that allows it to feed through the printer better).
Mar 27, 2014 | Konica Minolta bizhub Office Equipment &...
PM4i print error "out of paper...." How can I
When printing start take and keep with fingers label,pull sametime label when start,after that some sensor?? work again and next printing session come out ok.
May 12, 2011 | Intermec EasyCoder PM4i Printer
Ricoh SP c221sf Aficio upper misfeed jam? What's that all about? There is no apparent paper misplaced anywhere in the paper path.
I had the same error. In my case one of the two springs in the paper tray was missing (on the floor behind the printer) so there wasn't enough force to push the paper up to the pickup roller. After I installed the spring the error cleared and printing resumed.
May 18, 2010 | Ricoh SP C221SF Aficio Printer
MY PRINTER STOPPED PRINTING AND GIVES A ERROR MESSAGE THAT THERE IS A MISFEED. I CAN NOT SEE THE PAPER FROM THE FRONT OR TOP ARE THERE ANY OTHER SOURCES THAT I CAN CHECK TO CLEAR THE MISFEED, IF THERE IS...
You need to consult your manual for all the paper paths that you may have missed.
Check all paths and go out and buy paper path cleaner, follow the instructions on the package and completely clean out the paper paths.
This should loosen or remove the stuck paper and get the printer printing again.
Please write back results (good or bad)
Mar 16, 2010 | Ricoh Aficio SP C231N All-In-One Laser...
Error message reads "34 short paper". What does this code mean and what can I do to correct it? Thanks
This error means that the type of paper that is configured in the printer is different from the one you have chosen in your computer to send for printing. Make sure that the paper size is the same in both places the computer program you are using and the printer. For example if I have a Letter size word document that I want to print but the printer has A4 configured then I will get the 34 short paper error but If I change the paper in the printer and the setting to letter size then everything should print fine.
Nov 13, 2009 | Lexmark C510 Laser Printer
Not printing glossy A4 paper / paper jam / no paper feed
dont use thick photo paper like 230 gsm up, instead use 180 gsm papers. but if you dont want to waste the purchased thick photo papers, you can open the back and manually insert the paper once the printing process started. i tried this as a trial & error basis until i had perfected it.... hope it works with yours.
Aug 06, 2009 | Brother DCP 130C All-In-One InkJet Printer
Apple LaserWriter 8500 Printer Logo
113 people viewed this question
Top Apple Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Ronny Bennett Sr.
Ronny Bennett Sr.
Alun Cox
Are you an Apple Office Equipment and Supply Expert? Answer questions, earn points and help others
