Hi, This is the first time I am using this and I appreciate your time. I have just purchased a TX SR806 for my home theatre and it works wonderfully, except for a rather annoying problem or two I am experiencing. 1) When I run the Foxtel (Australian cable network), I sometimes lose the signal and the screen goes blank while it is "processing". I initially thought it must be the cable set top box and signal coming from that. However, when I try and run the Wii game console, the same thing happens. Oddly enough, this problem does not happen when I run a DVD, there is no picture interruption at all. I am using a high quality HDMI cable from the amp to the projector. I thought it migt be a loose connection to the projector and even though it seems loose, there is no interruption when playing a DVD as I mentioned above. 2) In all modes except DVD playback, the picture size "jumps" on the screen, from a mid size to a large size (although it doesn't fit the entire 110" screen). I understand that the cable picture is not designed to fit the entire screen, but the picture size should not jump between mid size and larger size. Is this a problem with the amp or more to do with the projector (it is an Optama)? Any advice would be greatly appreciated. Kind Regards, Laurie
  • laurie331 Dec 28, 2008
    Thanks for your reply. I am not using any attenuator, but will try and see what happens
    problem still exists. Any more suggestions?
  • 19,396 Answers
Replace the HDMI cable, and buy a good shielded/gold connectors one , that often sort out the problem.
Posted on Dec 28, 2008
  • 8,596 Answers
HDMI cables are pretty "glitchy" - I scoured Onkyo's website, and they did not have an HDMI-related upgrade (or any upgrade for that matter) for your receiver. Most likely the projector is at fault in combination with that particular receiver - usually requires a software upgrade if the projector is capable of receiving such upgrades (does your projector have a USB port on it anywhere?). There were certain Philips, Magnavox, and other televisions that experienced an HDMI jump like you are describing. Optoma does not have information on their website regarding that particular issue, but it is worth giving them a call (although I didn't see an Australian support number). If possible, switch to a component (red, green, blue) cable connection - you will get very nearly the same quality (1080i) without the headaches.
-Tha Mp3 Doctor
  • 4,472 Answers
First try just hooking up the wii, or cable directly to the projector to see if you still have the problem, then you will know if it is the projector or the receiver. If it is the receiver try a replacement of the same model. If its the projector it may have something to do with the resolution. Once I have more information I will be able to assist you further if need be. Also please take a moment to accept and rate my solution accordingly.
Thank you,
Lee
  • Lee A.
    Lee A. Dec 28, 2008
    Does it only change size once? Depending on the input or does it "jump" several times back and forth or something. Also what is the exact model of your projector. try hooking up the wii and cable directly to the projector first to make sure if the problem is with the projector or receiver.
    thank you,
    Lee
    Genius:
  • 1,550 Answers
Use amplifier for increasing the strength of the signal to the tv . Are you using any signal attenuator .
I bought a Onkyo TX-SR806 from Crutchfield a few years ago, never took it out of the box until now (finished theater room) and while hooking up wires there was a quick spark and now the unit turns on but...
Unless you are good at soldering have the parts on hand and know exactly what you are looking at, it will be very difficult for you to fix it yourself.
Mar 20, 2011 | Onkyo TX-SR806 Receiver
My Onkyo TX-SR806 remote has recently lost its mind. The On/Standby switch no longer turns receiver on or off; must do it manually on the receiver. The Volume control is now reversed: when you press the UP...
Hello, the most used buttons can wear out over time. On/standby and volume are the ones that are used most often. I suggest purchasing a new remote. It is available at shoponkyo.com. Thank you, Onkyo USA
Jul 08, 2017 | Onkyo TX-SR806 Receiver
Hi I have just purchased a Panasonic Plasma TV and Panasonic home theatre. Everything works well except for I cannot get sound coming out of the home theatre when watching normal TV. I purchased the...
Try running the audio from each video source (NOT the TV, which is an output, not a source) to the HTR digitally so you'll get the best mutichannel sound possible. Then you can turn the TV speakers (assuming it has them) off for hi-end watching.
Aug 15, 2010 | Panasonic Audio Players & Recorders
I have a Onkyo TX-SR806 HDMI output does not work anymore. Tried switching HDMI cables. My component video output works.
Sounds like you may have a bad HDMI card my friend. I had an issue with my HDMI card that was causing blue dots to appear on the dark parts of the screen, when outputting 1080p over HDMI. This is a rather common issue, so it wouldn't surprise me if your HDMI board needs replacement - especially if you've ever experienced the infamous blue dot issue.
Jan 22, 2010 | Onkyo TX-SR806 Receiver
My reciver just shutdown then went into standby mode. Will not power back on. How do I fix this problem?
What do you mean by standby mode? Do you hear the power relay switch clicking constantly, or does it just click once and turn off? In any case, it could be a faulty power relay. I just sent in my TX-SR806 for warranty repair recently, and it ended up being just that.
Nov 13, 2009 | Onkyo TX-SR806 Receiver
Onkyo Reciever TX-SR806 Losing HDMI signal.
I had the same problem with my xbox 360. I was able to fix the problem by disabling the Display Discovery setting on the xbox.
Sep 10, 2009 | Onkyo TX-SR804 7.1 Channels Receiver
Dish Code for TX-SR806
Dish Network
System
00775, 01505,
01775
Jan 27, 2009 | Onkyo TX-SR705 Receiver
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
