I am tryin to upgrade my processor on my 4000783 gateway motherboard need to change my fsb speed and dont know how
  • bigetybigchr Dec 28, 2008
    hanks wat it is my fsb is 533 i had a 2.0 cpu 400 mhz i tried to put
    a 3.0 800 mhz fsb and it works it just gives me a speed of 1.5mhz i
    guess ill have to get a 2.8 533 mhz p4 socket 478 by the way please
    confirm thanks a million
    would flashing my bios possibly help thanks
    President:
  • 1,179 Answers
You cannot change your fsb. You need to upgrade to a cpu with a fsb speed that your board can support. Once you install the new cpu your bios will set the fsb to the higher setting of your new cpu if your board supports it. If you have your board specs it will tell you something like supports fsb 1066/800. That would mean you could upgrade to a supported 1066 fsb cpu. Hope this helps & please remember to rate my answer. Thanks.
Posted on Dec 28, 2008
  • Roy Lonsinger
    Roy Lonsinger Dec 28, 2008
    If you have a 533 mhz fsb then the 2.8 would be the way to go. I had to go this route with my wife's olf dell as it had an older motherboard. The reason you can see the 800mhz cpu at all is because chipset is same but it will never give you full performance because of the fsb issue. I hope this helps you out.
  • Roy Lonsinger
    Flashing the bios would do nothing to change your fsb speed but it would provide support for compatible cpu's that came out after the board was manufactured.
Can i change the processor of a gateway ml6720 to core2duo
most likely yes... search cpu upgrade for your laptop on google.... I have done the change out on many laptops. you need to know what the socket type i.e. socket m, socket p ect. and the fsb (front side bus) speed is.
May 20, 2011 | Computers & Internet
Yea i need to purchase a new processor chip the motherboard is a 754 socket my pc takes a 3100+ amd sempron processor my pc is 1.8ghz im just not sure what to buy some say they are 64 bit and this one is...
please purchase the processor that is compatible to your motherboard. if the motherboard can be upgrade to a higher speed of processor then purchase it. if not, stick to the required specs. if you still want to upgrade, replace the motherboard, processor and the memory.
Mar 23, 2010 | Computers & Internet
I have a gateway MSII have a gateway MSI Ms-7399 mother board. I have an E6300 pentium dual core processor at 2.8 with a FSB at 1066,in it and it works fine. I want to know what the specs on the board are...
The board is maxed out at 1066 and it does not appear that gateway has a BIOS update to allow for the higher FSB reuired with the faster Intel chips. If you installed one of these newer LGA 775 chips into your computer it may work but would be a lot slower than what it is rated due to the chips multiplier would be set for 1333. I could not see any BIOS updates from gateway for this board. Also these chips are designed to run with the faster memory and the 800mhz memory speed would also be a bottle neck for your system.
Oct 10, 2009 | Computers & Internet
I have an Ms-7037 motherboard. I want to change
You cannot change the FSB to 800 , the board is made to take certain FSB's and processors are made with certain fsb speeds (Mainly 533mhz , 800mhz , 1066mhz etc)
These speeds cannot be changed . You have to buy a new processor and a new board to get the faster speed FSB !
If you found this solution useful , please rate below
Kind Regards
1234s282
Jul 02, 2009 | Intel Motherboard
Changing FSB & Voltages
Hi there.
You can change the front side bus in the bios if the bios supports it, if it does be very careful not to overclock the processor to much as you can cause damage to the motherboard and blow the processor up, also bear in mind that cooling is very important when it comes to overclocking.
Good luck and thanks for using FixYa!!
May 13, 2009 | Gateway Tabor 3 (4000532) Motherboard
CPU Upgrade for Compaq (283983-001) Motherboard
download and run everesthome
click on the + by motherboard
click on cpu then click on motherboard
the cpu will id the the processor
motherboard will id the FSB speed.
CPU-Z
click on the download latest version, left column
when you unzip and run this it will tell you if the processor is 478 or 479 pin both have 478 pins but location is different.
Mar 29, 2008 | Compaq (283983-001) Motherboard
CPU Upgrade
Athlon XP 3000+ is 400mhz FSB according to the link(http://www.amd.com/us-en/Processors/ProductInformation/0,,30_118_1274_3734^11672,00.html), means that in order to display the actual speed of your Athlon XP 3000+ you have to set your board 166mhz to 200mhz jumper setting or in CMOS utility overclocking option. and also just to inform you that your motherboard is in Overclocked condition when set, because it only supports processors up to 333mhz FSB (http://www.digital-daily.com/motherboard/soltek-sl75frv/)
Sep 11, 2007 | Soltek SL-75FRV Motherboard
Computers & Internet Logo
475 people viewed this question
David Payne
David Payne
