Front loader whirlpool washing machine won't go thru cycles.
AWM 8121 starts at the wash cycle and will not continue the program. When it has to spin it stops and starts flashing on 0. I have to manually move it thru all the cycles - spin - drain- and rinse as it won't go thru any of them. We thought it was unbalanced although that doesn't seem to be the problem. Can anyone help please
  • afhq109 Mar 28, 2009
    What is F dL  will not run ?
  • 318 Answers
"o" is an unsual code. usually it will have an "f" then a number. it may be that you are having a draining issue. is the unit full or have some water left in it? if so take off the front panel and see if you can remove the sump cover. be ready for water to come out, then remove whatever is blocking the pump and sump area. it most liekly has lint or items in there causing no drain.
Posted on Dec 28, 2008
I have a whirlpool awm 8121 6th sense front loader. when i select the cycle, usually rapid, and press the start button the machine commences to fill with water. when it comes time for the actual washing...
If your machine is reasonably old, perhaps take a look at the bushes of the motor . Before that, take the manual and run the test cycles by following the instructions; it might provide you with answers
Oct 14, 2017 | Whirlpool AWM8123 Front Load Washer
Whirlpool AWM 5080 stops during cycles
Sound like could be faulty pump however you need to make sure no
Could be pump at fault 1st you need to make sure no coin stuck in there ...
Mar 31, 2010 | Whirlpool AWM6100 Front Load Washer
Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
Washing cycle starts and takes hours even for short cycle.
Try checking for good water supply.
Pull out detergent tray and check for good water supply during filling.
if poor filling-
Try checking the hoses.
Turn taps off, disconnect from machine, place hose end in sink, turn tap on and check for good water flow.
if the hose has a red indicator in the side of the hose (end which is fitted to the tap) - Red indicator is a failed hose.(for models with Water Stop hose type "B")
Oct 05, 2008 | Whirlpool AWM6120 Front Load Washer
Whirlpool 6th sense front loader awm 8121
my whirlpool 6th sense will not start all lights and power i think that it is the door sensor at fault? The green light door locked light is not on.
Jul 18, 2008 | Whirlpool AWM6100 Front Load Washer
HI, I am having a lot of trouble with my front loader which is only about 4 years old. It seems to become very unbalanced during the coloured wash setting (even with a small load) - and yet is perfectly...
check teco coil on the back of the motor, it may have come loose'its about inch round thing it gives power to the the speed control module circuit board thats why its tumbleing too fast.bye Eamonn Ireland
Jun 11, 2008 | Whirlpool Washing Machines
Whirlpool AWM312/3 Front Loader Washing Machine - not spinning
I would recommend getting the service manual for your model as some models have clutches that control spin and others have belts. The service manual would be the best route if you are planning on repairing this yourself. If you would like the service manual let me know and I will post a link to where you can get one emailed to you.
Mar 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
408 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
