TV 40'' Samsung LNA630 Touch of Color
How do u turn on the Touch of color???????And What are the options?
  • 2 more comments
  • Aleks Dec 28, 2008
    Yes I know that but there no red trim of light around it i see the back of it but should it be like a light ?it is almost invisible like there's no touch of color.
  • Anonymous Dec 30, 2008
    I am having the same problem with my 40A630, which is brand new. I think it is a defective unit. I am calling Circuit City to see if I can exchange it.
  • derric5001 Jan 06, 2009
    same issue with the 40". I dont know if I am just expecting too much color, but I cant see any thing
  • ace636 Jan 15, 2009
    I wasn't expecting the red tint to light up. However, my TOC set has begun chipping on the inside and you can see the silver metal underneath the red TOC.
  • 21 Answers
The touch of color is not a function, it's the red tint on the plastic cover
Posted on Dec 28, 2008
Ican't qdjust the color on my Samsung LED screen
Follow the below mentioned steps :
1.Turn on the LED TV and let it warm up for 30 to 40 minutes before making any changes or adjustments.
2. Put on the lights that you would normally use when watching the TV. You want to create the same ambiance that would constitute normal watching conditions for you. Make sure there is no glare or reflection from other items in the room such as a mirror.
3.Open the menu on the screen of the LED TV with your remote control and find the options for adjusting the color, contrast and brightness. Menu options will vary by TV, but look for options that will say "Contrast," "Color" and "Brightness."
4.Start with the "Brightness" control. It would be best to have a DVD playing so that you can get a better idea of the control settings. Pause the picture at a place that you can see a variety of scenery, such as sky, mountains and people in the forefront. Adjust the "Brightness" by pressing the up and down arrows until you are happy with the picture. Press "Save" or "OK" to set the brightness at this level.
5.Repeat this with the "Contrast" and "Color" controls, remembering to save your settings. Look for the "Mode" setting. Press the arrow to get to "Normal" or "Movie/Cinema." Press that setting and save it.6.Turn off any settings that are titled "Flesh Tone Correction" or "Vivid Sports." These will make the colors unnatural, use up energy and damage the TV over time.
Jun 26, 2011 | Computers & Internet
Red Tint on Screen
This is normal and is a color calibration issue.
For correct color, NEVER use the "WARM" setting. Why? Too red. You cannot get REALISTIC or ACCURATE color using the "Warm" setting.
Since we are speaking of Samsung, first avoid the "Flesh Tone" adjustment. When things are set correctly there is no need for this adjustment. It is a quick fix and not for the "discerning eye".
1. First, access the "Color Temperature" menu. From here select "Cool2" or the coolest temperature setting.
Note: For Samsung use "Cool2", or if not available, "Cool1". Samsung has inadvertently increased calibration confusion by issueing TVs that have just "Cool1", and TVs that have both "Cool1" and "Cool2" :0[
For other brands, use "Cool", or "High", or "+6500k". Anything lower artificially reddens the picture and compromises detail.
2. Now return to the color settings and reduce "Color" to between 30 and 40 (on a 100 scale). The sweet spot is just near the place where the color rapidly washes out.
3. To round out the color palette, move to the "Tint" adjustment and ADD a couple (3-5) clicks to the GREEN.
Adding the touch of green is what is needed to take out the last bit of "pink" and will make all the tones and all colors display properly.
I hope this helps!
To further increase the quality of your picture visit
http://www.wowvision.tv/main.htm
Highdefjeff :0]
Jun 15, 2010 | Samsung LN46C630 TV
Samsung HLP4663w. After replacing the Ballast, Bulb and Color Wheel (color wheel came without the CCA values and the Actuator and Index delay values) we still have the same color and picture problems. Do...
if the picture is blue green there is a jumper to be removed on the dmd board on connector cn810--the index delay should be between 40 and 50 for optimum color --or adjusted for best flesh tone also in the options the cw setting should be set for cw2
Feb 06, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
No color on samsung lcd tv even after factory reset
hi if you bring the menu up and it's clear then you have a tcon board fault, if the menu is the same as the picture then you have a mainboard problem, thanks
shaun
Mar 09, 2017 | Samsung LE40R73BD 40 in. HD-Ready LCD...
My tv no longer shows the color red. No idea what
I have sound but my tv screen is black. Sometimes when I turn on the tv I get a picture but after 15 minutes or so the screen goes black again.
It's a 4 year old LCD.
Nov 23, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
RED COLOR NOT coming on TV, showing green all over place
I also have a samsung 40 inch. Try hitting the menu button on the remote the scrolling over to the right once and scroll down and hit pictures reset to see if that works. If it doesn't check your connections coming from the back of the source and the tv itself.
Sep 03, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Sound but no picture
check out input for video, make sure your color code is right, and if you using a receiver check your inputs and color code
Jan 18, 2009 | Samsung LE40R74BDX 40 in. LCD Television
Samsung plasma
the neck board of your tv tube has lose solder have it resolder.
Mar 07, 2007 | Samsung TX-P3264 32" TV
Televison & Video Logo
2,455 people viewed this question
Top Televison & Video Experts
