Question about RCA RC5215P DVD Player
Play dvd has no color
All work fine except for color
    Problem Solver:
  • 6 Answers
This is often the problem when the output is set incorrectly. i.e. you are using component cables and the output of the unit is set to video or such, try looking in set up on the menu screen and see id you can change the output.
The other time I have had this happen is when the RGB plugs were in the wrong hole.
Hope this helps you, Cheers, Rob
Posted on Dec 28, 2008
My NAD T550 cannot play DVD's with a heavily painted top (i.e. newer DVD's). Older DVD's (with just text written on top) works just fine. Also, burned DVD's play fine as well. What could be the problem
The heavier paint is keeping the dvd from spinning at it's optimal speed. Not much you can do about it except get a new player that can handle it.
Oct 07, 2009 | NAD T550 DVD Player
DVDs all play in Black & White
Could be because it is set to NTSC. Needs to be set to Pal.
Mar 27, 2009 | Panasonic Televison & Video
Loss of color when watching dvds
Uh oh, time for a shop visit as the chroma processor is not working properly....accordianman
Jul 03, 2008 | GoVideo DV2150 DVD Player/VCR
No color on TV when a dvd is played
are you using the correct colour output? change it and see if it works....go to set up, video or display, and look for the colour output option...check that, and if that dont work, try changing ntsc or pal....it wrkd for me
Jun 29, 2008 | RCA Audio Players & Recorders
DVD plays only in black and white
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
HDTV:
Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
DVD:
Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
May 02, 2008 | Televison & Video
Daewoo DP42SM coloring missing blue tint on dvd playback only
I don't know are you familiar with electronic,if you are you can fix it by yourself.The problem is in video process board,the one in metal cage.What you need to do is to remove the board from the set,remove the cage, then to replace all SMD capacitors!!!And do not put SMD as replacement put the normal capacitors same values they can be fited.You should aslo replace capacitors at the PSU and check 170V,160V and 70V and adjust them after the replacement.PSU is easy part but the video board is tricky one but it can be done
Feb 15, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Black and white picture
turn off you dvd player... them click on "setup" button on your remote control! them click right botton to appear "tv sys" them click "enter"... choose your tv system, PAL or NTSC.
Jan 15, 2008 | Pioneer DV-360-S DVD Player
DVD player will not show in color.
could be loose or damaged SVideo cable or cable getting interferance from other equipment. try moving cable around and see if color comes back.
Sep 16, 2007 | kawasaki SVP500 Multi-disc DVD Player
Same as other poster: Player only plays black and white
It sounds like the circuitry which actuates the color drives for the screen are not working, this would ba analogous to adjusting for a B&W picture on a color TV you have color but the screen shows black and white. I would get a schematic for this set and measure the voltages on the color processor that connects to the screen since you know that the external jack has color. If possible I can help you troubleshoot this, if you need me to help out.
Aug 19, 2007 | Durabrand PDV-705 Portable DVD Player
RCA RC5215P DVD Player Logo
89 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
