Question about HP L1530 (Carbonite, Silver) 15" LCD Monitor
HP 1530 Onscreen Menu refuses to go away
This monitor worked great, until the onscreen menu started popping up. It would pop up, you'd close it, and it'd pop up again. Because the menu was on top of everything else, and refused to go away, the monitor is unusable. So it's in my closet, because, other than that, it works great, and I haven't totally given up on it yet. If anyone could help me to disable the onscreen menu function, or replace any part that was broke, I'd sure appreciate it. Thanks!
  • HP Master
  • 3,398 Answers
The button is bad on it the select OSD button
the cable is bad, and tells you out range, no signal, or other cable dead errors or in sleep mode. can be PC, cable or monitor
id have to see your screen to wax smarter.
unplug monitor from power and pc
let sit for 1hr.
the plug it in all alone
does OSD pop up> is there an error
if no error there, the monitor buttons are broken,
Posted on Jun 11, 2017
  • 9 Answers
SOURCE: problem on hp monitor
I have a Dell E171FPB monitor that had the same problem with the Main Menu coming up and I thought I would tell you what I did to fix the problem.
1. I shut down the PC.
2. I removed the power cable and video cable from the back of the monitor.
3. I removed the four screws that hold the stand for the monitor and slid the stand off.
4. I then removed the 5 screws that hold the back cover on the monitor.
5. I took two flat blade screw drivers and carefully removed the back cover.
At the bottom of the monitor case, there is a small circuit board the holds the 6 switches for controlling the display.
6. I located the button that calls up the Main Menu. It is the second switch from the left as you are looking at the monitor from the rear.
7. I used a small solder iron and heated up the four prongs in sequence while holding the switch with a pair of needle nose pliers. I had to rotate this process from one prong to the other while all the time applying slight pulling pressure on the switch pulling it away from the circuit board.
8. Once the switch was removed, I put the cover back on and tightened up the five screws.
9. Then I slid the base back in the slot it came from and tightened the four screws.
10. I connected the video and power cable and turned on the PC.
With the switch removed the Main Menu never popped up again and I am so very happy.
Posted on May 30, 2008
SOURCE: osd and main menu keep popping up on my monitor hpf2105
moniter will not turn off
Posted on Mar 20, 2009
  • 225 Answers
SOURCE: OSD main menu pop-up will not go away
Please try to Turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu and remove that message from your screen. best regards
Posted on May 23, 2009
rulds2008
  • 3866 Answers
SOURCE: HP W19B monitor displays menu all the time
There is a little circuit board under the buttons that has gone bad or the button was pushed to far in and depressed the button sensor inside, befor you begen going into this monitor let me warn you of the risk. There is very high voltages inside that can ;ead to injury up including your death, so with that in mind and your ready to pop the back off this, lok at the little board take a cue tip, cotten swab and genly push on the button to see if it free itself if not this little board will need to be replaced.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on May 24, 2009
Roonie Tunes
  • 136 Answers
SOURCE: my volume menu from monitor pops up, volume auto-decreases
Was something spilled on the volume key? Sounds like it is stuck... you can use a fine toothpick and plain water to "scrub" around the key, there may be some buildup that inhitbits the key from "unpressing".
Hope this helps!
-- RT
Posted on Sep 02, 2009
I have a HP officejet 4315 All in one printer/fax/scanner/copier -- I am told my faxes are very blurry -- what does that mean and how do I fix it?
Good Day,
I would like to suggest use your hp solution center click the tab for the HP All-in-One.In the Device support area, click Onscreen Guide or Troubleshooting. If you click Onscreen guide, a pop-up menu appears. You can choose to Help for the HP All-in-One. and If you click Troubleshooting, the Troubleshooting and support page open.
Good luck and God bless.
Jun 10, 2010 | HP Officejet 4315 All-in-One Printer
The monitor menu appear suddenly in the display and I can´t erase it.
usually this is caused by having your keyboard too close to the monitor and the keyboard bumps the menu button..
look at the buttons on your monitor itself. One of them should say "menu" pressing that one again should close the onscreen menu. if that doesn't work look for another button marked "exit" or an "exit OR close menu" selection within the menu itself. Use the menu button to get in the menu, use the left , right, up or down to navigate through the menu and usually the "menu OR select" button to make chnages.
Apr 22, 2010 | HP L1706 17" LCD Monitor
My volume menu from monitor pops up, volume auto-decreases
Hope this helps!
-- RT
Sep 02, 2009 | HP w2207 Monitor
May 19, 2009 | HP Pavilion F1703 17" LCD Monitor
The screen has frozen, it starts up but the screen fails to respond..
Try calibrating your screen. Please use the stylus to calibrate!
The fastest way is to be on the slide-lock screen & hold the side volume button in the Up position until
"Press volume down key to check" comes up onscreen. This may or may not work on all firmware versions
on the current i9, but works on most. Make sure to hold the button firmly in the Up position. You will first
see the normal volume speaker icon show onscreen and the volume rise, but just keep holding it Up, and
eventually you should see the pop-up box noted earlier. The moment you see that pop up onscreen,
immediately press the side volume button in the down position. A white calibration screen should now
show & you can calibrate the touch screen using the stylus. Try to tap as close to the center of the little
pulsating icons as possible, as this will more accurately calibrate your touch screen. If the calibration
screen didn't come up using that method, then you can get to it from the Main menu screen.
Select "Settings", then select "Pen calibration", & follow the previous instruction.
For full help topics I have a cd available for 10 us dollars. Has 100's of mp3 ring tones wallpapers, and java games and opera java browser. Guaranteed help on every question ever asked on these phones. And all settings for all cellular services. I have answered 100 questions with this CD. If interested contact prestorose@aol.com Pay Pal only, will send out First CLASS Mail in padded envelope. If interested I will send Pay-Pal invoice that can be filled out and returned with instructions. Guaranteed safe transaction.
May 02, 2009 | Dual Electronics CECT P168 Cellular Phone
Cect phone a8+ freezing
If you are talking about the touch screen not being responsive at all under normal conditions, read on.
First try calibrating it. There are 2 ways to get to the calibration screen. Please use the stylus to calibrate!
Apr 09, 2009 | Dual Electronics CECT P168 Cellular Phone
I have a cect i9+ mobile and when I swith it on and try to unlock it from the arrow it is not working (like it is jammed). Any solution pls?
You need to recalibrate your screen.
Mar 06, 2009 | Dual Electronics CECT P168 Cellular Phone
Unable to view setup menu on TV screen
I had this same experience and after hours of attepts to fix it (including the suggestions on this site) I found that the company that installed and set up my system literally disabled the "set up" on the remote so that it could not be changed. To fix this (and/or confirm that this may be your problem) reference page 39, "all reset functions" to reset your remote back to factory settings. As soon as I did this and hit "set-up" -- the set up menu popped up and worked appropriately. Hope this works for you!
Dec 16, 2007 | Denon AVR-3802 Receiver
Menu option
stuck in adjusting button?
Oct 11, 2007 | HP f1905 19" Flat Panel LCD Monitor
HP L1530 (Carbonite, Silver) 15" LCD Monitor Logo
96 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
