Question about Uniden Bearcat Pro PC78XL 40-Channels Base CB Radio
Can transmit but not recieve
I have a uniden pc78xl 40 channel cb, my antenna is a 48 in firestick tunable antenna that is mounted to a bare meteal section of my roof basket. then i have a 10 gauge fine copper stranded wire only about 10 in grounding the antenna base to the chasis, with an 18 ft coax cable. i have really good swr readings on all channels but i cannot recieve anything. my signal strength according to the meter on the cb is very weak. i have adjusted all the settings on the cb(squelch,rf gain) but nothing. whats wrong?
  • mgilles88 Jan 18, 2009
    My info is from Uniden tech support. They said that its a bad CB radio.
  • Rommel Cana
    Rommel Cana May 11, 2010
    have you tried your radio in different antenna?
    have you tried antenna in other radio?
3 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: MyCB radio wont broad cast
One of two things is wrong---either a problem in the radio or a problem with the Microphone----
Do you know how to open the mic plug and check the wires there?
Most of the time it is a problem with the mic cord---
Let me know if you need wiring diagram of the Mic--I can provide that---almost any 4 wire mic can be used to replace the stock one---
Original mic was 1 k impedance---but a 500 ohm mic will work and make the audio even louder.
Also have someone check the SWR or match on the antenna system--easy to do.
I am here to help---if this helped you rate this solution as I do this here for free.
SD TECH
Posted on Jan 02, 2010
anymhz
  • 500 Answers
SOURCE: I have a Uniden PRO510XL radio and a 48" single
then the antenna needs to be moved. antennas have to have a ground plane to get correct swr below 3... or there may be a bad ground. try moving antenna @ different angles to see if it changes swr's or even opening the door away or closer to the body will make it change. also check the insulator it should be on top. call if you need help
Posted on Dec 27, 2010
My radio receives the wx stations fine, it transmits fine but it will not receive when switched to cb, I have tryed ex speaker, still nothing. mete wont move in receive mode, but when keyed the tx is over...
Here is the list just scratching the surface.
  • Bad antenna
  • Bad coax cable ......grounding externally or internally with shield.
  • Bad/poor ground for antenna..........door to body, painted parts when mounted elsewhere.
  • Antenna installed incorrectly. Nylon grommet must insulate antenna from contact with mounting bracket. Coaxial connector must have contact with bracket for grounding.
Jul 02, 2011 | Uniden Bearcat Pro PC68LTW 40-Channels...
I purchased a Midland 1001z in the fall of '09 and installed it on my boat. I is mated to the existing Shakespear 8' CB antenna. The CB worked great last summer while boating with my brother and...
Vibrations on the small cb's make the internal circuit boards come loose and its intermitted or will not RX or TX.. Check the antenna with another cb. using an SWR METER.. or have someone check it.. SWR should be free if you take it to them.. to check.. Make sure the antenna, mounts, and coax are ok.. if soo then its in the cb itself .. Email us if you need more help or need the radio looked at, the post office has flat rate boxes cheap nowadays. were in Temple, TX at the CB SHop.
May 30, 2011 | Midland 1001Z 40-Channels Base CB Radio
Realistic trc 443 cb quits transmitting and recieving
Sounds like the weather alert system is getting activated.
Jul 26, 2010 | Uniden PC78ELITE 40-Channels Base CB Radio
Power meter on my dx-979 barely moves off of 0 when transmitting the swr meter also hovers around 1.0 no matter what channel...not used to seeing such low swr readings and almost nothing on the power...
I would check the radio with an external meter to see if it is the transmitter or the Meter in the radio. If it is the meter in the radio it could have a bad detection Diode or just oout of adjustment or even a bad calibration pot. other wise start looking to fix your transmitter like finals or other similar problem.
May 13, 2010 | Galaxy Radios DX-979 40-Channels Base CB...
Power meter on my dx-979 barely moves off of 0 when transmitting, the swr meter also hovers around 1.0 no matter what channel...not used to seeing such low swr readings and almost nothing on the power...
Well,some meters are set different than others,to see what is going on,you need a good WATT-SWR meter,but that is not a bad reading of SWR, you can get one at Radio Shack. You can not go by the meter that is on the radio,it,s probably not set right. hope this helps..
Mar 21, 2010 | Galaxy Radios DX-979 40-Channels Base CB...
Uniden pc78elite antenna light
What kind of antenna is it? Have you checked your standing wave? To do this process you will need a field strenth or a SWR meter to do it,would be cheaper to have it checked at Radio Shack or you can buy one,and do it yourself. Some radio antenna light come on when transmitting,....hope this helps....
Mar 15, 2010 | Uniden PC78ELITE 40-Channels Base CB Radio
I can't xmit or receive on CB channels: Wx channels come in OK. I had a bad WalMart Special mobile antenna which shorted out because of corrosion. Now have a Diesel 15 inch mobile with tunable SWR tip....
If try another mic and see if problem is still
there then you have half of the problem,the
TX an RX all go through the mic if mic good
you will have to go inside of the unit.
Good Luck
Sep 10, 2009 | Cobra 18 WX ST 40-Channels Base CB Radio
Not able to transmit or recieve on cb radio in car
It could be your ant. a broken coax wire or a bad ground could cause this a could a broken or shorted wire on your mic.
Jun 02, 2009 | Maxon Radio Communications
Mic not Keying up
Sounds like you are not modulating well. try adjusting your amp.also, test your antenna for wire breakage and, make sure that your mic has good wires as well.
Jan 22, 2009 | Uniden Bearcat Pro PC78XL 40-Channels Base...
Uniden Bearcat Pro PC78XL 40-Channels Base CB Radio Logo
114 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
Greg Cann
Greg Cann
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
