Question about Kenmore 24902 Top Load Washer
How to replace inlet vavle
How do i replace inlet vavle? i was told that that will fix the problem of my washer continously filling up even when its in the "off" position.
  • 318 Answers
Yes your inlet water valve is the problem. you have to remove the outer cabinet first by taking the control panel loose and "flipping it back, then remove the 2 hold down clips, kindof a wierd "s" shaped thing in each upper corner, then the cabinet will "hinge" forward allowing you to get into where the valve is at. the rest should be easy, a single mounting screw and the 2 hoses, make sure to put the wiring plugs back on in the correct place on the new valve.
Posted on Dec 28, 2008
My samsung washer continously fills with cold water even if it is unplugged.
inlet water solenoid needs replacing but you need to pinch pipes and feel to see which it is as there are two or three, they are were the pipes go in to your machine Re: Jeff
Apr 12, 2012 | Washing Machines
Kenmore washer model #110.28882790 is very slow to fill with water. We've checked and cleaned the hose filters. Is there some kind of water sensor? Or hidden filters?
Remove the water line from the INLET valve and start the machine , if there is no proper flow of water then the inlet vavle is not working to open , the filter on the vavle is clogged or the inlet filter is blocked. Also check the voltage on the inlet valve to make sure that the controller unit is outputting correct voltage.
If not replace filter , valve to ensure that the drum get best flow for filling.
Aug 22, 2011 | Kenmore Washing Machines
My Whirlpool washer won't go into the rinse cycle. The water inlet screens are clean and I replaced the timer but obviously wasn't the fix as I still have the problem.
Hi, When the water is suppose to be filling, Can you hear the inlet valve humming? You might need to remove the inlet vavle and check voltage to it. When the water is to be filling, you should get 120V to the valve. Please let me know if this helps or if I can assist you further.
Vic
Jul 15, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
When the washer is off, even if the door is left open, the tub will fill with water and leak onto the floor.
sounds as if you have a bad inlet water vavle, it doenst complety shut off after use, and waer will trickle in( adding up to quite a bit in a day) youll need to replace the water inlet valve(directly behind themachine where the hoses hook into). in the meantime turn off water inbetween uses
Mar 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water doesnt stop
defective inlet vavle or ( FILL VAVLE ) replace..onthejob
Feb 08, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer does nothing
ok we need to check a couple of things...take the fill hose off ,,,now put unit in a cycle and make it call for water...is the inlet vavle humming or vibrating....will your there look in vavle and see if your inlet vavle screens are clogged...does the unit have water in it,,if so it wont fill with water in it...keep me posted onthejob
Feb 01, 2009 | Frigidaire ATF6000ES Front Load Washer
Cold water inlet on maytag top load washer not working
switch the hoses fill hoses and if no hot enters you have a defective inlet vavle,,replace...onthejob
Jan 13, 2009 | Maytag PAV2300 Top Load Washer
E10 error
thers no filter just inlet vavle screens....pull fill hose off and there little screens inside the water fill vavle,,always replace after cleaning..onthejob
Dec 30, 2008 | Frigidaire Affinity ATF7000E Front Load...
Washer does not stop filling up
replace inlet vavle...if you need instruction ,,post question how to replace inlet vavle
Dec 27, 2008 | Kenmore 24902 Top Load Washer
Kenmore 24902 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
