Question about Audiovox XMCK10 Satellite Radio Receiver
Radio shut down, now won't turn on
Owned this radio for 6 weeks, with sporadic use. Yesterday the radio shut down for no reason. Subsequent attempts to turn it on had no effect. I am positive the connections are secure, since I tried the connections three times this morning to no avail. When I touch the power button, nothing happens. How can I resolve this?
Thanks.
    Genius:
  • 1,239 Answers
Hi Is your battery charge low?
I know sometimes if the battery is low the radio can turn off
Posted on Dec 28, 2008
  • ABHISHEK.C
    ABHISHEK.C Dec 28, 2008
    select "Restore Connections." However, this gives the error "Timeout waiting for Radio." Manually selecting
    According to alt/shift/H ("help me!"), battery should be at 80%; I now have it on external power. Handheld has been turned off and back on.
    Scholar:
  • 141 Answers
It's just a big microprocessor in there, nothing much to do...
However, if you open it without batteries, you might find that the power button or switch is broken ( if like you said, you used it version sport), check for any bad connection or dirt.
Connect a multimeter (volt) on the electronic board where batteries are connected put back the batteries and measure if you get power on the board. Leave the ground connected and with the + of your multimeter check on condensator if you get some power. Be carefully with the CPU, this kind of device are sensible.
Usually the CPU (microprocessor) control the on and off of the device, so I don't have big hope.
good luck
    Genius:
  • 1,550 Answers
Have you checked the inlet power supply to the radio . Using multimeter check the continuity .
My 2011 Ford F150 radio will not work. For a while the radio would pop and go silent, with only the clock display flashing, but would sporadically come back on. It now has not worked in a week. CD will...
Did you ever find out what was wrong? My radio was doing exactly the same. Popped, shut off, came back on later, repeat.... Email me a reply if you wouldn't mind, I only found this site searching for a solution to the radio problem.
Desertracer72@gmail.com
Sep 22, 2013 | Ford F150 Cars & Trucks
Radio on chrysler 300 won't shut off when key is turned off. When i open the door the radio shuts off.
This is actually normal. There is a option in the menu on the dash to turn this off and on
Apr 20, 2013 | 2006 Chrysler 300
Volume doesn't work on bose radio in car all the time
Sue,
I had the same issue with a car I owned and had to replace the unit.
May 04, 2017 | 2009 Nissan Rogue
2008 GMC Acadia radio won't turn on
The radio and BCM needs read for codes. No reason for the radio not to work after a FOB program. Just a guess, but if the battery power was to low, radio is locked out.
Mar 06, 2013 | 2008 GMC Acadia
I have the unlock code for my 99 saturn sl2 but i need the radio layout
Hello, you will need to enter your radio unlock code using these instructions.
  1. Press SEEK DOWN, SEEK UP, TUNE DOWN, or TUNE UP. The radio display should show 0000.
  2. PRESS SEEK DOWN to set the first digit.
  3. Press SEEK UP to set the second digit.
  4. Press TUNE DOWN to set the third digit.
  5. Press TUNE UP to set the fourth digit.
  6. If the code was entered correctly, the radio will display SEC (SECURE). The theft deterrent system for the radio is now active and normal operation may be resumed. If the code was entered incorrectly, the radio will display Err for 5 seconds and the LOC (LOCKED) will be displayed again. If LOC is displayed, repeat 1-6.
  7. If the correct code is not entered in 8 attempts, follow the next steps:
  8. 7.1. Turn ignition to ACC position. 7.2. Turn radio power switch OFF. 7.3. Wait one hour before repeating steps 1 through 7. If attempts to unlock the system are made before the one hour period is up, the radio will display INOP (INOPERATIVE). Continue to wait. If the ignition is not in the ACC position, power will never reset internally to allow itself to be unlocked. 7.4. After one hour, repeat steps 1-7.
Jul 03, 2010 | 1999 Saturn SL
Display for radio stuck in '7 SAFE' mode
This sounds like a Phillips Car Stereo:
To get the code in:
1. Turn the stereo off.
2. Turn off the ignition
3. Turn the ignition back on (dash warning lights on)
4. Hold and keep down the AS button on the stereo.
5. Turn the stereo on.
6. Release the AS button after 4 dashes appear on the display
7. Now enter code (if code = 7009. Press preset button 1 seven times, button
2 once
3 once
4 nine times
If you go past you can go round again by pressing the
preset button repeatedly
8. Once all 4 numbers are correct hold down AS again until you hear a beep (2 - 5 seconds)
9. The stereo after beeping will scan to program channels
You have 10 attempts to get the code in. However some models will not give you the number of attempts remaining!
Time delays work as follows:
Attempt 1. 10 seconds
Attemp 2. 30 seconds.
Attempt 3. 10 minutes.
Attempt 4. 20 minutes
Attempt 5. 40 minutes
Attempt 6. 80 minutes
Attempt 7 160 minutes
Attempt 8 320 minutes
Attempt 9. 640 minutes (yes that is 10 hours 40 minutes!!)
Vitally important thing to remember, the countdown timer works only when the radio is switched on. ANY interruption in the power will reset the timer!
So, be prepared for a VERY long wait to be able to enter the code!
Oh, and if it has reached 10 attempts, then it needs a dealer unlock.
May 09, 2009 | Car Audio & Video
Radio does not turn on - red security light sometimes flashes
I had the same problem, the main plug in the back of the radio does not seat correctly, you have to buy the radio removal tools which are four "keys" you pop into the four corner slots of the radio, pull out the radio, unclip the main wire plug and re-clip it in... it'll work fine, however, its happened to me about 3 times in the 6 years I've owned the car, so keep those keys handy. Oh, and don't believe any dealer that'll tell you different, my dealer told me I needed a new $500 radio, and the radio removal tools were like $300.... I got them for like $20 on ebay.
Mar 10, 2009 | 2002 Volkswagen Jetta TDI
Audiovox XMCK10 Satellite Radio Receiver Logo
66 people viewed this question
Top Audiovox Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Chinmay Joshi
Chinmay Joshi
Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
