Question about HP Computers & Internet
The calculator no longer turns on despite new batteries
Does not turn on despite new batteries. Have been told there is a chip which needs replacing? Have had other calculators repaired that way, but this one only lasted 6 months. Have had repairs done this way 6 times before but would prefer if there is a method which is more permanent. The HP 41 came out in 1980 and have 6 in my possession. Over time the calculaters degenerate and can not be activated. Presentlt only 1 is working and it is showing signs of 'pcking it in'. In my opinion the newer models are not a patch on the HP41, HP41C, HP41CV or the HP41CX.
    Genius:
  • 1,239 Answers
Hi
Well, this might not be right, but check the Brightness. Hit 2nd, then the down arrow. repeat this a few times. see if that works.
Posted on Dec 28, 2008
  • ABHISHEK.C
    ABHISHEK.C Dec 28, 2008
    lets try a reset this calculator? Back to factory settings?
    =shift , setup button.. 1 is for fraction, 2 for decimal.
  • ABHISHEK.C
    if you already done removing the battery then perform this operation!
    SHIFT 9 (CLR) 3 (ALL) = YES
    This will initialize the calculator and return the calculation mode and setup to its initial default setting. this will also clear all data currently in the calculator.
    Genius:
  • 1,550 Answers
The replacing chip may solve the problem temporarily for permanent fix you need to call service technican to check the internal connection .
    Genius:
  • 1,011 Answers
Sir,
Click this link for more info
check the manufacturer's website, if any update firmware is avialable. Better go through the manual. If it not worked if u have warranty period better replace
thanks
good luck
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
My compliments, the HP41 do bring back school days memories.
To your concern, initially, pls try:
  • hard reset, remove battery pack, short the battery terminals of the HP41;
  • replace/recharge batteries;
  • clean, scrape the battery terminals. In some instances they may have to be stretched/bent to ensure more pressure/contact with the batteries;
  • unplug any peripherals/external add-ons;
  • perform a memory reset by turning the HP41 OFF, pres and hold the backarrow < while turning the unit ON.
Should the above be not corrective, then the unit has to be opened up and voltage measurements be performed on the powersupply section. You may be interested to reference some repair pages.
Good luck and Thank you for using FixYa.
My TI-83 Plus Calculator will not power up despite the fact that I have put in new batteries.
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
Apr 10, 2014 | Texas Instruments TI-83 Plus Calculator
It just won't work with the new batteries!
Sep 11, 2012 | Texas Instruments TI-83 Plus Calculator
My Texas Instrument TI 83 Plus will not turn on?
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible. If this doesn't do it, please reply to this post and we'll go on from there.
Feb 11, 2012 | Texas Instruments TI-83 Plus Calculator
I borrowed this calculator from my sister for my daughter to use at school until I could get her one of her own. She told me I needed to replace the batteries which I have with two different new sets and...
If this doesn't do the trick, please append a comment and we'll go from there.
Aug 10, 2010 | Texas Instruments TI-83 Plus Calculator
I have not used my ti-83 plus calculator in a long time. I replaced the batteries but it will no longer turn on
I'm not sure aht you've tried so hear are some trouble shooting tips.
1.) Make sure the batteries are good
2.) Make sure that the batteries are in correctly
3.) With new batteries in, turn on calucalator if nothing appears hold the 2nd key then press up until the contrast of the screen darkens
Good Luck
Jun 28, 2010 | Texas Instruments TI-83 Plus Calculator
TI-83 Plus ram cleared message when turned on
It calculator tells you Ram Cleared each time you turn it on, the most likely reason is that the backup battery is depleted. Its role is to keep the memory modules electrically refreshed when calculator is turned off. If the backup battery is dead, the memory is erased when you turn calculator OFF. Main batteries no longer supply power and the contents of the memory are cleared.
  1. Check that main batteries are good and inserted in calculator.
  2. Turn calculator OFF.
  3. Replace the backup battery.
  4. Turn calculator ON.
  5. Press the [CLEAR] key to erase the "Ram Cleared" message.
Jan 19, 2010 | Texas Instruments TI-83 Plus Calculator
I am a teacher. I have about 10 calculators that
It has two batteries CR2032. They should not be removed at the same time. There must always be one battery in the calculator. The calculator should be turned OFF when changing batteries.
Often after you change batteries the screen contrast may be too light and you cannot see anything. The contrast can be adjusted (lightened or darkened). As you adjust the contrast setting,a highlighted number in the upper right corner changes to indicate the current contrast setting; 0 is the lightest, and 9 is the darkest.
To adjust the display contrast:
1. Press and release the [2nd] key.
2. Use one of two keys: (UpArrow or DownArrow)
--- To increase the contrast (darken), press and hold [UpArrow]
---To decrease the contrast (lighten), press and hold DownArrow
Hope it helps.
Nov 23, 2009 | Texas Instruments TI-80 Calculator
The calculator casio CFX 9850GA was not turning on..
first:you must clean battery compatrment in direction of contact point with good contact cleaner from any electronic store near you or from radio shack.
second:clean power switch with contact cleaner.
Dec 21, 2007 | Casio CFX 9850GA Plus Calculator
Turns on but does not respond to buttons
Try replacing both the AAA batteries and the back-up batteries. This should probably fix the problem. If not, contact the guys over at Texas Instruments for replacement parts if you need them.
Mar 12, 2007 | Texas Instruments TI-83 Plus Calculator
Computers & Internet Logo
16 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
