Question about Samsung MW1080STA Microwave Oven
Samsung MW 1080 STA Weird displays when not in use
I have this Samsung MW 1080 STA for four some years, and lately showed the code A-1 in the display out of nowhere, in the middle of night, or during the day without anybody touching or using it. It'll beep twice, then, go to A-2 and A-3, and back again. When you cancel, it will disappear, but it will come back right away in 2 to 3 seconds. It becomes a headache because I had to unplug it after each use. Any ideas, please?
  • Samsung Master
  • 9,156 Answers
Your keypad or control panel are malfunctioning. A bad keypad may be worn out due to age, damaged, or it may have gotten wet or otherwise contaminated. Moisture and contamination can be caused by not using the fan when boiling on the stove top, spraying of cleaners, by storing the microwave in an unheated garage or shed, or infestation. I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller. Apply an alcohol-based cleaner (such as the purple kind) to a cloth (since paper towels can scratch) and gently wipe it off. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics. You can order replacement parts here: http://www.samsungparts.com/search/search.asp If you or a friend decide to work on it, we have *critical* safety & disassembly, info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Apr 24, 2007
Bosch hmc80151UC/01 (MW/Convection) not heating
MAN! I hunted and hunted for you but BOSCH is one of the poorest with support documentation! BOOOOooo... and I have a BOSCH dryer too that gets ''unhappy"...
MAYBE THIS will help you??
Of course, DISCONNECT THE POWER and DOUBLE-CHECK each fuse THERMAL FUSE and SWITCH!
That's all I can offer you my friend. METHINKS ONE of these puppies has to be bad!
Anthony
Apr 04, 2018 | Bosch Microwave Ovens
Fgmv174kfb dim display
The owner's manual (here) does not mention that as a feature, so I would assume the oven has a defect and would need to be returned to your dealer to be exchanged under warranty.
Oct 25, 2012 | Microwave Ovens
Display show SE from samsung microwave range hood
The keypad has a short in the membrane, which means the keypad control board will probably need to be replaced.
May 05, 2012 | Samsung SMH8165STE Microwave Oven
My child locked the microwave pad. How do I unlock it?
The operation manual is available for free download from Samsung at this site: http://downloadcenter.samsung.com/content/UM/200305/20030529145700437_MW5592.pdf
The answer to how to lock and unlock is on page 15 of the manual. It's instructions are: 1. Press the '0' button, the display will show: "PRESS 1- DEMO 2-CHILD LOCK"
2. Press the "2" button, the display will show: "PRESS START"
3. Press the start button and the display will show "LOCK" then returns to the time of day.
At this point the microwave can't be used. To unlock, just repeat steps 1-3.
Hope this helps
Jun 18, 2011 | Samsung MW5592W Microwave Oven
My Samsung SMH7178STD just started showing error code E-13
Hi, please click on this LINK then select 'Display Panel', then 'Microwave Is Displaying An Error Code' for instructions on what to do in the event of an error code, such as 'E-13'
Oct 31, 2010 | Samsung SMH7178STD Microwave Oven
Switching off the sound of my Samsung Microwave
1 Press the Sound button. The display shows "ON".
("START" will flash)
2 Press the Sound button to turn the volume off. The display shows:
"OFF".("START" will flash)
3 Press Start. The display returns to the time of day.
Lastly, you can find a copy of the manual here:
http://downloadcenter.samsung.com/content/UM/200507/20050727140356453_DE68-01945A[GB].pdf
Sep 01, 2009 | Samsung MW1030WA Microwave Oven
Microwave Oven "Error 1"
Error 1 = Short circuit in the MW(microwave) relay.
Maybe the relay have problems in your contacts. In idle state, the relay's contact must be open.
Feb 11, 2008 | Microwave Ovens
Samsung Microwave MW 1040WC 800 Watts
The "Handy Helper" pad may be sticking, indicating a failing keypad. That pad will cause the display to read "A-1". I would suggest unplugging the oven from the wall for a few minutes, then plugging it back in. If it still has a problem, you may need a new keypad, which can be had here: http://www.samsungparts.com/search/search.asp If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk Post back here if you need more help. If you don't have the owner's manual, you can download it here: http://downloadcenter.samsung.com/content/UM/200305/20030529152504390_MW1030WC_02601A.pdf
Sep 24, 2007 | Samsung MS1040BB Microwave Oven
MW stops after 23 seconds.
PLESE CHECK RELAYS ON PCBOARD .ALSO TRY DISCONNECTING ALL CONNECTIONS TO FRONT PANEL LEAVE IT DISCONNECTED 5MIN THEN RECONNECT AND TRY THE ELECTRONICS SHOULD RESET .HOPE I HELPED BIT OF A WEIRD FAULT
May 09, 2007 | Panasonic NN-S553 1350 Watts Microwave...
MY MICROWAVE WILL NOT DO ANYTHING
I couldn't find those exact trouble codes, but a common problem is when the controller gets damp, either from steam rising from the cooktop or someone spraying cleaner directly on the keypad. Cleaners should always be sprayed on a soft cloth, then wipe the keypad with the cloth. Also, GE / Samsung codes of F1, F2 and F3 may be the same since Samsung makes GE microwaves. Those would mean trouble with the temperature sensor, keypad, or control panel. Assuming your control panel is clean and dry, it may be time to call for service.
Apr 04, 2007 | Samsung MW1080STA Microwave Oven
Samsung MW1080STA Microwave Oven Logo
222 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
solarfinder
Level 1 Expert
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
