Question about Frigidaire GLEQ2152ES Electric Dryer
My Frigidaire electric dryer doesn't heat normally.
I get heat, but not as hot as it used to. takes several cycles to dry a load. Plenty of air flow. I even have the vent hose attached to a dryer can in case the vent duct was clogged. No change. Is it the element going bad or some sort of sensor?
  • 1 more comment
  • mc4bama Jan 05, 2009
    dryer will not heat..wheres the circuit panel
  • Anonymous Jan 25, 2009
  • Anonymous Jan 28, 2009
    My dryer takes forever to dry my laundry.. Plus it take a every load squeak.
  • 115 Answers
Some of them dryers have 2 elements and one could be out you have too take drum out too check it
Posted on Dec 28, 2008
Takes several cycles to dry
You may have a clogged air vent, check that the air vent hose is not smashed, if it is not smashed, have your dryer vent cleaned professionally, all the way from where the dryer connects to the wall to where the vent leaves the home,
Recheck the dryer operation, dryer vents should be cleaned every other year for optimum performance
Feb 16, 2014 | General Electric GTDP490EDWS GE 7.0 Cu....
It just doesn't seem like my frigidaire gas affinity dryer is drying as fast as it should
Hey Car Guy,.. there are two factors that determine how fast the clothes will dry:
1- air temperature, Is the gas burner is lighting and heating the air? Just stop the dryer mid-cycle and feel the clothes - if they are hot, then the burner/heating part of the dryer is working ok.
2 - adequate air going through the dryer. This is usually where the problem lies. There is a lint filter at the dryer somewhere, accessed either where the door opens, or on the top of the dryer....there may be an additional lint filter somewhere on the exhaust duct. Check for that, and check your air flow where it exhausts outslde. See that the flappers of the backdraft damper aren't stuck closed etc.
If you have good heat and good air flow, then it's doing all it can.
Mar 22, 2013 | Dryers
My dryer takes a long time to dry, what could this be?
Normally when a dryer is getting hot but taking too long to dry it indicates that it either has a clogged vent or poor air flow. You can check this by turning the dryer on and then going to where it vents out of the house and see if there is a strong air flow, or by taking the vent off the back of the dryer and letting it run and see if the clothes dry in one cycle. 99% of the time its going to be some sort air flow problem.
Dec 09, 2010 | Frigidaire GLER341A Electric Dryer
NOT DRYER CLOTHS LIKE IT USE TO TAKING MUCH LONGER
Check for clogs in the vent air line. If dryer lint or some obstruction is slowing the air flow it will take longer to dry clothes. Also the dryer may not be getting hot enough. Check to see if the clothes feel hot or warm when you reach inside. If it feels hot enough it is likely an issue with air flow. heat and air flow are required to dry clothes.
Oct 02, 2010 | Frigidaire Electric Dryer
I just bought a gas dryer - takes forever to dry clothes
check the high limit switch/thermostat on the burner housing and if they are weak they will cycle the heat off too soon and it wont build the heat you have it set for,just bypass it with a jumper wire to test it,if this is the problem,dont leave it bypassed,replace it as it is a safety feature to prevent a fire
May 09, 2010 | Kenmore 95087 Gas Dryer
My Frigidaire stacked unit FEX831CS0 is operating ok except it doe not get as hot as it used to and will not dry the clothes. I did replace the high limit t/stat as I found it would not reset after...
The question is .. is it drying? .. if it is drying then previous to the high limit tripping you had an air flow problem creating the abnormal heat in the dryer which you took as normal .. suprise part is that if it is drying then the heat you feel now is the correct heat for that unit.
Slippy
Apr 18, 2010 | Frigidaire FEX831CS Top Load Stacked...
Dryer not getting hot enough
the heat sensor or spark ignitor is at fault
Feb 28, 2010 | Whirlpool LER4634J Electric Dryer
Dryer not drying loads properly.
You need to clean the vent ducting from the point where it leaves the dryer to where it exits your home. The reason the dryer performed better was because it was not meeting any resistance from the ducting to push air through the exhaust on the back of the dryer. You obviously have a clog, kink, excessive bend, or a run that is too long. If you haven't had your vent ducting inspected or cleaned in a while, now would be a good time. In addition, the fact that your dryer became excessively hot WITH the ducting attached adds credence to my suspicion that your ducting is clogged or obstructed in some way. Without proper air flow the dryer will actually overheat to the point of failure. Usually the Thermal Cut-Out (also known as a Thermister) will blow. This component is designed to blow like a fuse in the event of an overheat condition and must be replaced. Running your dryer in an overheat condition not only will damage the appliance, but it can become a fire hazard. I would recommend a thorough ventilation inspection and cleaning. Make sure you are using the metallic semi-rigid ducting and NOT the plastic ducting. The semi-rigid resists crushing, kinking, is heat resistant and resists intrusion by rodents. If you have questions about anything I've explained to you, please contact me and let me know. I hope this helps.
Feb 10, 2009 | Frigidaire GLER642A Electric Dryer
Dryer not drying clothes properly
Replace the vent tubing, sounds like something is stuck or it is crushed somewhere. So replace it for about 5 dollars and see if that works. It should since you disconnect the hose and it drys right away
Feb 10, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
122 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
