Question about Philips Magnavox 9P6034C 60" Rear Projection Television
My 60inc phillips magnovox has poor color, what do i have to do?
My tv has poor color what do i have do do to improve it?
  • Philips Master
  • 3,459 Answers
You can get the CRT fluid and a photo instruction guide from www.TvRepairKits.com. They have one for the Magnavox models.
Posted on Dec 30, 2008
We just bought a 55 inch phillips magnavox and told it was working fine when we got it home and turned it on it was a red screen and was really foggy. we looked up some tv repair places and ONLY 1 told us it was the picture tube and to look down them with a flashlight for bacteria! sure enough the green and blue had it. so we found one place that would sell us the coolant fluid that you have to change the others could get it in or wanted us to bring the tv to them. we did it our selves the stuff was $17.00 a bottle or if we took it in it would be about $375.00. we have a great picture now and it wasn't as hard as all the other repair places said.
Posted on Dec 29, 2008
I have a faded picture on my Magnovox 55 inch
You can get the service manual at
www.servicemanuals.vstore.ca
If the color are dim you most likely need the phillips coolant kit also available there which contains the CD with instructions.
Jan 01, 2010 | Televison & Video
Phillips Magnovox
Its a power supply issue the only solution is to get it repaired.Possible power outage.Repair charges would be around $400.
Goodluck,
Please don't forget to rate the solution
Apr 25, 2008 | Philips 9P5034C 50" Rear Projection...
Reference to Phillips Magnovox Model PR1302 C121.
turn on tv,it turns back off,without lighting screen.
May 04, 2009 | Philips Magnavox 27MS343S 27" TV
Blue color bleeding
the color issue is most likely the crt coolant needs to be replaced you can get the phillips CRT coolant replacement kit at the following link which contains the coolant and the instructions on how to do the replacement.
http://servicemanuals.vstore.ca/
The crack you hear could just be the speakers or a intermitant ground problem in the audio circuit more likely the spealers if its only on strong Bass
Apr 03, 2009 | Philips 55PW9363 55" Rear Projection...
Poor picture quality on old 55" rear projection phillips tv
replace the coolant in the CRts. Very common problem with the older rear projection tvs. You can get the coolant replacment kit at the following link which contains the coolant and instruction CD.
Dec 19, 2008 | Televison & Video
TV repair
you need to replace the coolant in the CRTs ( picture Tubes) you can get the repair kit at the following link which contains all the coolanr and the instruction CD with the step by step instructions with pictures so you can easially do it yourself. Heres the link.
Aug 17, 2008 | Philips 9P5544C 55" Rear Projection...
Help..... Phillip Magnovox Model 9P5034X101
NOT EXPENSIVE POWER SUPPLY PARTS ARE NEEDED TO BE REPLACED . ONLY A TECH WHO , HAS EXPERIENCE ON THIS TV MODEL AND THE KNOWLEDGE ABOUT THIS PROBLEM ,COULD FIX THE TV RIGHT THE FIRST TIME. OTHERWISE REPLACE POWER DEFLECTION BOARD ,PARTS AVAILABLE AT PARTSTORE OR SIMILAR COMPANIES
Where are the inputs for rca plugs to my magnovox?
I think your set does not support A/V inputs. It is only able to be used as a simple TV on cable or an antenna.
For your DVD player, you can buy a modulator that can convert the A/V to RF. You can then connect it up with a CATV A/B switch so that you can switch between the modulator and the cable or antenna service. Speak with the sales rep about the details for the modulators that he is selling.
I have seen low cost modulators for under $30. Check out places like Radio Shack or Circuit City.
The quality of the DVD player will be very poor when fed to the TV through a low cost demodulator.
Jerry G.
Apr 14, 2008 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
193 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
