Question about RaidMax SIRIUS (ATX-701WS) ATX Mid-Tower Case
Raidmax Sirius case not turning on
I have bought these items and i am putting it in my case.
XfxForce 8200 GPU Motherboard http://www.bhphotovideo.com/c/product/57... AMD Phenom™ X3 8650 BOX Triple-Core http://shop4.frys.com/product/5582050?si... 2GB DDR2 PC2-8500 / (2X1GB) / (1066MHz) Enhanced Latency DIMM KIT http://shop4.frys.com/product/5541090 Raidmax Sirius Silver Mid Tower Case http://shop4.frys.com/product/5275987?si...
Well when i plug it in to the wall and flip the 500 wat power supply on i get two lights that light up on the mother board, one is green and the other one is red, the red one saids PWR_LED, now when i click on the power button that is built into the case it flickers green for a second then turns back off.. Nothing happens none of the fans turn on or anything..
  • gameguysz Dec 28, 2008
    thermal paste, i have to apply it to the cpu and fan even the fan that came with the cpu i have to as well? ok but i didnt even get to start the computer yet im building from scratch
    President:
  • 1,179 Answers
Recheck the wiring. Make sure the fans are all plugged into the proper place. Then try reseating the RAM, video card, & cpu. Make sure you have applied a good thermal paste between cpu & heatsink as overheating can cause the system not to boot. Hope this helps & please remember to rate my answer. Thanks.
Posted on Dec 28, 2008
  • Roy Lonsinger
    Roy Lonsinger Dec 28, 2008
    Yes if you do not apply thermal paste on the cpu before mounting the heatsink you will get a fried cpu. Hope this helps.
Installed a GA H55M USB3 motherboard in a Raidmax Tornado case. When I go to turn it on their is power for about for about a 1sec and the fans turn a couple of times and a couple of seconds later their is...
I once had something similar happen to me. Triple check to see that all connections are secure to the motherboard - a loose 20 pin ATX cable was the culprit in my case.
Hope that helps. Good luck!
Dec 09, 2010 | RaidMax Tornado ATX238WRP Black SECC Steel...
I need a motherboard that will fit in a Raidmax ATX1072BP Mid Tower ATX Computer Case!
Most desktop computer cases have a range of standard mount holes, standard offs.
I suggest you select a motherboard that suits your requirements.
To be sure that the motherboard will fit your case, take the motherboard mount base with you to the computer shop and place the motherboard of your choice on the base to see if the mounting holes line up.
You may need to upgrade the switch mode power supply to a higher power unit if the total power requirements is near the maximum the existing unit can deliver.
Dec 03, 2010 | RaidMax ATX1072BP MID TOWER ATX COMPUTER...
Raidmax Sirius mid-tower case fan alarm
Here are some solutions:
1. Try to use some silicon oil in fan apertures to decrease rub
2. Try to manually (look for a mainboard's service software settings) decrease rotation speed if available
3. Less recomended: disconnect fan cable from mainboard and don't stress your computer (try not to overheat, - work with software that uses less resources) and buy a new one when available
Jan 28, 2009 | RaidMax SIRIUS (ATX-701WS) ATX Mid-Tower...
Cant get sound from my pc
Please spell the name of the speakers again, I have no listing...accordianman
Mar 08, 2008 | RaidMax SIRIUS (ATX-701WS) ATX Mid-Tower...
I broke my temp probe on my raidmax
if by the probe you understand front fan controller,yes,there are controlers to replace yours..just pay attention to fit in the bay..
Jan 21, 2008 | RaidMax SIRIUS (ATX-701WS) ATX Mid-Tower...
Doesn't power up anymore
use a test pen and check if any power coming out from the power supply cable e.g. to hard drive, motherboard and so on.. this will help to to find out if it is actually power supply issue or components issue....
Aug 29, 2007 | RaidMax (ATX-612WBP) ATX Mid-Tower Case
Raidmax Scorpio ATX Mid-Tower Case
The on/off connector is the power labelled one. The one thing you may have to do is (if you have'nt already)connect the power connector from the PSU to the processor power supply, close by to it as it may not just run off the motherboard ZIF socket for it's power up.
Feb 07, 2007 | RaidMax Scorpio 868W ATX Mid-Tower Case
Continuation to 'help no power' question?
It's not a short in that sense. It's just preventing thee motherboard from starting. I had the same issue a long time ago when building a pc. Once it's seated properly, it should turn on...unless like I said previously, there is something wrong with motherboard all together.
Oct 05, 2006 | A-Top Alien Gaming ATX Case
RaidMax SIRIUS (ATX-701WS) ATX Mid-Tower Case Logo
292 people viewed this question
Top RaidMax Computers & Internet Experts
Mohammad Abumuailek
Mohammad Abumuailek
gaucherre
Are you a RaidMax Computer and Internet Expert? Answer questions, earn points and help others
