Torque specifacations
SOURCE: front engine mount torque spec
Tighten it until it strips and then back it off a quarter turn.
SOURCE: torque specs 7.5 inch rear axle 96 ford ranger
Differential bearing caps 70-85 ft lb
Ring gear bolts 70-85 ft lb
Pinion bearing preload if using original bearings 8-14 lb-in, if installing new bearings 16-28 lb-in
SOURCE: 93 artic cat jag head torque pattern and specs
the best place to find it is the service manual. if not avail. i usually 1, tighten it to ~10-20Nm in a 'outwards spiral' fashion, ie start tightening from centre bolts outwards. 2, spiral tighten by 1/4 turn, 3, another 1/4 turn, and 4, final 1/4 turn.
SOURCE: torque settings on front wheel yamaha 535virago
Here is a manual for the yamaha.
http://www.carlsalter.com/download.asp?fileid=089097109097104097095088086053051053046112100102
If you get one spoke right then tapping it will give a certain pitch/sound. Then you can compare it to the rest. There is a technique for lacing a spoked wheel, it would be advisable to have a professional do the work.
Here is a link to info on lacing a wheel
http://www.geocities.com/spokeanwheel/
