Question about HP Pavilion dv9000z Notebook
Need password unlock code for HP Pavilion dv5
My brother passed away and have his laptop, can't get pass the logon screen that request the password. Does anyone out there know the code for Windows Vista Home Premium Edition?
  • journey155 Apr 06, 2009
    when I boot up i get hp screen then i am asked for a password
    Filmmaker:
    Uploaded 5 video answers.
  • 23 Answers
To reset a forgotten Windows password on HP Pavilion, there are several free methods:
1. With another admin account.
2. With Windows password reset disk.
3. From Safe Mode.
More dtails you can found on other sites, it is easy to find.
Anothe tip: Recover Windows password with Windows Password Recovery Tool.
1. Install this program on another computer and create a password recovery disk with USB
2. Insert the disk to your laptop and set your laptop to boot from it.
3. All user accounts will be loaded, then you can reset any user password.
If you want to read more details: http://www.windowspasswordsrecovery.com/hack-hp-computer.htm
Posted on Mar 27, 2013
    President:
  • 1,179 Answers
Remove the cmos battery from the motherboard for about 5 seconds, replace & reboot. Hope this helps & please remember to rate my answer. Thanks.
Posted on Dec 28, 2008
    New Friend:
If you need to unlock HP password, you can use the SmartKey Windows Password Recovery to unlock it, it does not only support HP, but also support other computer brands. You can watch this video guide about it: How to Reset HP Password
Posted on Feb 10, 2014
    Filmmaker:
  • 50 Answers
I suggest you one way to get Windows lock screen password, please see this video learn how to do.
http://www.youtube.com/watch?v=quxuEqpG6f4&feature=youtu.be
Posted on Nov 18, 2013
  • HP Master
  • 32,281 Answers
Is the password reqested as you power up the laptop or does it request a user password to login to Vista?
If it is a power up login then it is near impossible to crack, try various names, pets, kid's names, family names/places, street names etc. There are no back door passwords and the password is not stored in the BIOS and removing the BIOS battery won't work.
The password is stored on an EEPROM chip and you need electronic knowledge to build an EEPROM reader, pull your laptop apart, solder the reader to your laptop, connect the reader's connector to a working computer, and run a program to read the contents of the EEPROM, identify the password from the downloaded data, unsolder the reader, put the laptop back together, boot up and insert the password. You can now enter the BIOS and change the password or remove it. For further info goto
http://sodoityourself.com
If the login is a user password it is easier to remove, there ae Linux boot programs on the WEB that can reset/remove Windows passwords such as Password Recover. Download and copy to a CD and boot up from the CD.
  • Chris Hingee
    Chris Hingee Dec 28, 2008
    By the way, this EEPROM hack applies to IBM ThinkPads as well as HP/Compaq laptops. I have successfully unlocked several laptops as well as hard disk passwords that are installed on the same laptop.
    These passwords are designed to prevent unauthorized acces to laptops and the data.
    Removing the hard drive from these protected laptops and inserting them in another laptop will not work, you still cannot access the data without the correct password.
    New Friend:
  • 43 Answers
Way 1. Use another Windows administrator account
Step 1: Sign in Windows via another administrator account.
Step 2: Type "user accounts" in the search box and select User Accounts in the search results.
Step 3: User Accounts windows will open, with All Windows user accounts displayed.
Step 4: Select the user account that you want to reset password of.
Step 5: Type a new password twice, a password hint once, and then click Change password button.
Way 2. Use Reset Windows Password Utility
Reset Windows password utilities are regarded as the most widely-used and efficient way to bypass lost Windows password, and Windows Password Key Professional is a good example. With this program, you can easily bypass Windows password in 5 minutes.
How-to:
Step 1: Download and install Windows Password Key Professional in any PC that you can run as admin.
Step 2: Create a boot Windows password reset CD/DVD or USB drive in seconds.
Step 3: Boot the target Windows PC from the burned boot password reset disk.
Step 4: Reset the forgotten Windows user password within 3 clicks.
Step 5: Sign in Windows without password on its logon screen.
For more: http://www.lostwindowspassword.com/windows-password-recovery.htm
    New Friend:
  • 36 Answers
Helpful post: How to hack hp password?
Posted on May 13, 2013
  • 3 Answers
This is a very hard solution because you MUST have electronics and soldering skills to perform it. There is a VERY EASEY solution for this model.
you CANT erase this password just by removing rtc battery, you have to get a master password based on the hash code .
The hash code appears after entering 3 wrong passwords it has a 5 digit format "xxxxx", you can get your laptop unlocked at Laptop Rebirth
Posted on May 24, 2010
2 Suggested Answers
gabysrivera
  • 8 Answers
SOURCE: Need password unlock code for HP Pavilion dv5
You can start it in safe mode pressing the F8 key...it change between brands but must out there use f8... when you start in "safe mode" in the log in screen you will find your user name and the administrator one...normally the administrator don't have password, so you can log into it and there you have the permission to delete other users passwords...
If you don't found that option, there is an other option but you need to download it and burn it in a cd... Is called ERD Commander here is the link for it: http://rapidshare.com/files/113560492/ERD.Commander.2008.CrOwN.rar... the password for decompress it is:( munda ) when you have burned it, insert it in you cd drive> go to your computer bios>select boot priority>change it for boot from cd first...once you have done that press f10 and select the option yes to save your settings and restart your pc....then your computer will start with a wizard looking like windows xp...complete all the things that it request...when finally boots up>go to start menua and select system tools>locksmith and delete all the passwords that you want...that's it! restart without the cd in the drive and log in! "Hope it works for you"
Posted on Jul 20, 2009
How can i unlock fn on my Hp pavilion dv5
To unlock the "Fn" key, Try press two keys simultaneously
Oct 17, 2012 | HP Pavilion dv5-1125nr Notebook
My hp pavilion 6700 is locked
F10 to setup bios? reset to default to remove all passwords.
Apr 21, 2012 | HP Pavilion ZV6000 Laptop
How can I get into a hp pavilion dv5 if I don't have the password?
Just download the Windows Password Key and burn it to a CD or USB drive, then insert the disk to your locked computer, reboot, press the button it says on the screen. then it will auto remove the password in minutes.
Sep 27, 2011 | HEWLETT-PACKARD Pavilion dv5-1235dx...
I want to know the unlock code of pyramidbloxx i already received the unlock code unfortunately i erase the said text please help i want that game
Assume that prior to functionality the device either phone or computer requested pass codes. Acquiring pass codes in such a situation display message space from where typewritten codes are keyed. A situation where the device requests pass codes least displaying type entry area to type key passes. Attempting to operate the device would produce results either requesting pass codes also display the space area at which passwords at typewritten.
Feb 25, 2011 | Samsung GTC3300 Cell Phone
My computer does not regognise my password, it will not let me into it
Attempt to reset the lost password alloweable from the click an alterantive request. Usually the computer allows for several attempts to logon. Several attempts to logon would lock out the user requesting the reset codes. The computer owner then provides the reset codes in place of what was lost. Attempt to reset computer pass.
Jan 29, 2011 | Toshiba Computers & Internet
During reformat hp pavilion dv6-1251nr reboots and the screen goes blank, har drive seek light goes out
Shut down the computer.
Turn on the computer tapping F10 key on your keyboard.
You will see BIOS comming up.
Go to the option SMART and Run HDD Self Test.
If it passes then get another set of recovery disk for HP Pavilion.
If test fails, replace hard drive.
Dec 02, 2010 | HP Pavilion dv5-1251nr Notebook
Jan 06, 2009 | HP Pavilion 2500 Notebook
Unlock logon password for HP dv5 series
Dec 28, 2008 | HP Pavilion DV5234US Notebook Laptop
Need system unlock code for dell latitude
So I bought a Latitude D620 and I bet u heard this a million times already it came with the famous This system #xxxxxxx-xxxx, is protected by a password authentication system. Any help from the gods of this site would be appreciated. below are the numbers needed i believe,
CHZ0P2J Service tag
272-081-320-75 Express code
This system #CHZ0P2J-595B is protected by a password authentication system.
Any help would really be appreciated. thanks in advanced.
Nov 04, 2007 | Dell Latitude C400 Notebook
HP Pavilion dv9000z Notebook Logo
6,263 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
