Question about SanDisk Sansa e200 MP3 Player
My sansa mp3 player won't charge or connect
My sansa mp3 player wont work charge or connect.. i tried everything.. i need 2 figure out something.. so can some1 explain
  • richgirl4u94 Dec 28, 2008
    that didnt work either
  • brooklynn07 Jan 09, 2009
    yeah i have the same problem and this didnt work
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Dec 28, 2008
My mp3 player wont charge but will turn on when pouted in
connect the Sansa (via the player's USB cord) to different USB ports on the computer until the Sansa starts to charge. A weak or non-working USB port won't charge the Sansa.
  • Reset the Sansa MP3 player. Slide the player's "Power" switch all the way up to the "On" position. Hold the switch in that position for 20 seconds. The Sansa resets. Try to charge the player.
  • Install the latest firmware onto the Sansa MP3 player. Download the Sansa Firmware Updated (link in References), and then click the link in Resources for the specific model of Sansa you own to learn how to update the player's firmware.
  • May 01, 2012 | Kitchen Appliances - Others
    My sansa when its connected to my computer comes on works syncs and everything so as i disconnect it from my computer it' s dead and wont turn on
    Three possibilities;
    1) You have a dead battery because the battery is no good.
    2) You have a dead battery because your Sansa is no longer charging the battery.
    3) You have a dead battery because you didn't leave your Sansa tethered long enough to charge it up.
    When you have the Sansa c250 tethered to the computer, you should see a tiny yellow lightning bolt flashing, and a battery icon that shows the amount of charge on the battery.
    If you see the lightning bolt, but the battery does not charge after being tethered to a working computer or charger for 24 hours, you may need a new battery. You can get one on Amazon.com. Here's a link:
    http://www.amazon.com/HQRP-Replacement-Battery-Universal-Protector/dp/B001NZ981S
    If you see the lightning bolt, and the battery charges after 24 hours, AND your player works when unplugged--Problem solved! You just need to let it charge for a longer time.
    If you do not see the lightning bolt when the player is tethered, and the battery indicator shows "empty," It's likely that the internal plug to your Sansa c250 has broken. Your Sansa is no longer able to charge the battery.
    If you happen to be an electrical engineer, or otherwise have a shop full of electronics equipment (including signal injector, volt-ohm meter, needle-tip soldering iron, and stereo magnifying goggles with work lamps) you may be able to fix it yourself. Otherwise, forget it-- your Sansa is dead.
    If it's still under warranty, try to get it replaced. Failing that, it's time to get a new MP3 player.
    Hope that helps! Please post a message to let others know what happened to your Sansa player.
    Nov 22, 2011 | SanDisk Sansa c250 (2 GB) MP3 Player...
    My Sansa wont take a charge? Can someone help me?
    Probable causes:
    1) Sansa connector is damaged
    2) Cable is damaged
    3) USB port is damaged
    Have you tried other computer/cable ?
    If you did and it didn't work, you'll have to take it to service since it would mean something is damaged.
    May 27, 2009 | SanDisk Sansa e250 MP3 Player
    My computer wont reconize my mp3 player
    Down load the firmware on Sansa's website. I have a Sansa 250R and it wouldn't work with the new replacement usb (Griffin) cord I bought at Best Buy. So I bought a Sansa Fuze and the cord that came with it worked on the E250R. Huh? Yeah, go figure...and oh, that replacement Griffin usb cord I bought worked fine with the new Fuze. I came real close to buying a new battery for the E250R but instead invested that money in the Fuze.
    Oct 12, 2008 | SanDisk Sansa e250 MP3 Player
    Scan disk sansa c200 series locked with an error message
    Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
    -Tha Mp3 Doctor
    Apr 04, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
    Problems with charging my mp3 player!
    -Tha Mp3 Doctor
    Mar 29, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
    Headphone jack
    The Sansas Earphone Jack soldier is very cheap try bending it or placing something extra to hold the jacks connection to the player. when closed its not niticeable, no need for soldiering. Try it. Contact me if you want a video of what i did. hope this works.
    Feb 19, 2008 | SanDisk Sansa e260 MP3 Player
    Sansa
    it could be that you need another cable.
    Nov 13, 2007 | SanDisk Sansa e260 MP3 Player
    SanDisk Sansa e200 MP3 Player Logo
    505 people viewed this question
    Top SanDisk Audio Players & Recorders Experts
    Gyula Lacz
    Computer Repairing
    Computer Repairing
    Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
