Question about Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
MY CDRW DELL DIMENSION 2400 BURNER ISNT WORKING ? HELP
MY CD BURNER USED TO WORK BUT THEN MY COMPUTER GOT MEST UP I MADE IT NEW AND NOW THAT I WANT TO BURN CD OR DATA ANYTHING IT DOESNT READ MY CD BUT COMPUTER IS WORKING FINE HELP ?
  • 1 more comment
  • Anonymous Jan 13, 2009
    does the same thing
  • Anonymous Jan 28, 2009
    my computer was cleared off and now my cd dvd burner isnt working
  • Violetglas Mar 25, 2009
    Mine also has the same problem, got messed up, fixed it, now I can't burn anything. Does't recognize the cd I put in.
Check to see if it shows up in device manager first. Once you click on it in device manager go to properties and see if you have any code error. I had a cod 19 on mine. I did exactly what they said and in less than 10 minutes I had my cds back. Good luck.
This solution is for the following error codes 31, 32, 19, 39 and 41 shown in device manager in device status.
If your cd or dvd drive isnt working properly but you can see it in the device manager, and it has worked before.
And if you have tryed uninstalling it, updateing drivers and so on and it hasnt worked?
Then I suggest you try remoteing the lower and upper filters from your windows registery as they most likely are the problem.
here are the instructions in plain text
Click the Start button, press run and type regedit.
In the Registry Editor window, in the left pane, double-click the HKEY_LOCAL_MACHINE folder.
In the HKEY_LOCAL_MACHINE folder, double-click the System folder.
In the System folder, double-click the CurrentControlSet folder.
In the CurrentControlSet folder, double-click the Control folder.
In the Control folder, double-click the Class folder.
In the Class folder, click to select the {4D36E965-E325-11CE-BFC1-08002BE10318} folder.
In the right pane, click to select the UpperFilters registry value.
Press Del / Delete to remove the registery entry.
In the Confirm Value Delete dialog box, click the Yes button.
In the right pane, click to select the LowerFilters registry value.
close the regedit window.
I've made a youtube video about this few months ago you can see it at
http://www.youtube.com/watch?v=kyFRAONkCko
Posted on Dec 28, 2008
My dell dimension 2400 isnt acknowledging cds in the e drive yet it says that the drive is ok. Can I get it to read them again?
Is it a CD drive, a CD burner, a DVD drive, a DVD burner or a Blu-Ray drive? Have you tested all types of cds for the drive? Do certain ones read and noth others? What version of Windows are you running? Did it stop working after a program install or a system crash?
Nov 08, 2011 | Dell Dimension 2400 PC Desktop
My cd door no longer opens on my dell dimension 2400. The light is off too.
Hi minic2,
Your CD-ROM must be defective.
Try to check the connection of the cables from and to your CD-ROM and motherboard as well as the power cable.
If it is still not working, I suggest you replace it with new.
Hope this helps you a lot.
Thank you for using FixYa!
Oct 31, 2011 | Dell Dimension 2400 PC Desktop
MY CDRW DELL DIMENSION 5150 BURNER ISNT
im not sure what cdrw isnt doing so i will have to guess
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd-rw/dvd rom burner then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jan 20, 2011 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
Hello i have a Dell Dimension 3000 computer. it works fine but my cd/dvd drive don't work so i need a new one. can you help me pick the right one out
hello
the link below will take you to Dells website , where youc an selecet the DVD drive you have ..
this machine had several options to slecet one of a few drives.. i am not certain which one you have these are the part numbers you can select when making a purchase . These drives range from $20-$50 -- just go to www.google.com and enter the highlighted part numbers to get a resller near you.
HLDS GWA-4164B HH 16X DVD+/-RW
HLDS GCR-8483B HH 48X CD-Rom
HLDS GCC4481-B HH 48X32 Combo
HLDS GCE-8487B 48C CDRW Lead Free
LiteOn JLMS XJ-HD166 HH 16X DVD
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&catid=&impid=&SystemID=DIM_CEL_3000
i hope this helps -- please rate my service
Nov 29, 2010 | Dell 3131115 CD-RW Burner
My cd burner stopped working TS-H 292B code 28 wisard can't find on computer how can i get it working again
check,PATA cable,SATA cable and Power cable connecting the drive with main motherboard and SMPS Box.
Nov 28, 2009 | Dell Dimension 2400 PC Desktop
Does the dell dimension 2400 burn dvds?
Hi budliteman36
Dell Dimension 2400 series will not bur DVD, see the link blow for specifications.
http://reviews.cnet.com/desktops/dell-dimension-2400-pentium/4507-3118_7-30824846.html?tag=mncol;rnav
You can replace the CD-RW drive with a DVD writer. Here is a list od DVD-R-RW writers.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=89&name=DVD-Burners&
Cheers!
Mike
Mar 31, 2009 | Dell Dimension 2400 PC Desktop
DEll 2400 - cd-dvd drive stopped working
try to clean the lens using lens cleaner...
Dec 02, 2008 | Dell Dimension 2400 PC Desktop
I Need the software that goes with the LG GCE-8483B cd-rw burner that's in a dell 2400 desktop computer
start here with this link, and look for the Dell logo..you may need to hunt inside that area, for the cd/dvd drives, but you'll be close enough
Mar 22, 2008 | Computers & Internet
Dell (1G055) CD-RW/DVD-ROM (Combo) Burner Logo
832 people viewed this question
Alun Cox
