Question about Philips Magnavox 9P6034C 60" Rear Projection Television
The color on my projection is not clear what do i need to do, its my first time.
  • Edward
    Edward May 11, 2010
    Please provide more details. ]
    Does the screen look "3D", distoreted, or wavy?
    Or
    Does the screen look dull, red, or orange ?
    Sniper:
  • 62 Answers
Bulbs may need fluid changed.
Posted on Jan 08, 2009
Need to order a new engine light for my 72A650
started with different color pixels not coming in till the tv warmed up. Hadf to turn TV on and off several times before clear screen. Last night TV went black with a giant red x in the middle of screen. Now just 99% black.
Jan 14, 2014 | Samsung SELECT HL72A650C1F Rear Projection...
Re: Toshiba 65 in Cinema Series - 12 years old. Color Separation. Green bow at top center of screen, red and blue double images tilting upwards toward sides. Sometimes clears unassisted after set has...
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 20, 2011 | Toshiba 65H82 65" Rear Projection...
Colors in left upper corner like a rainbow and fuzzy warped picture with lines that will run thru the picture from time to time, majic focus does not clear this up and I can not get the color set...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 06, 2011 | Hitachi 50SBX78B 50" Rear Projection...
Color is bad especially colors like orange and the white on peoples teeth is black most of the time andthe picture is not clear
HI, thank you for visit fixya.
Common problem on this set .
Picture tube liquid is dirty.
Mostly in crt green and crt blue.
Do you have electronics skills?. If so, open the TV ( back cover), you will see green,blue and red gun. After turn on your tv, select any channel or video signal, cover with piece a paper two guns at the top ( any), and see how look the picture in the front, try one at time, ( press menu on remote control and see leters-clear). I am sure the green and blue will be no clear. all the time red tube is fine.
REPLACE COOLANT LIQUID PROJECTION ( solution).
I will be here for any quetions.
Thank you
Dec 01, 2009 | Philips 60PP9352 60" Rear Projection...
Color red seems to be more prominant...than other
I've had this problem with my projection TV recently. I would say your lens/lamp is to blame. It might be time to change it, depends on the last time it was changed, most of the time, the TV will tell you that it needs to be changed, but not always. I think your best bet is the TV lamp.
Oct 20, 2009 | Hitachi Televison & Video
Cannot print blue/green colors.
I think your cartridge is defective, you need to replace a new cartridge.
May 22, 2009 | Brother MFC 240C All-In-One InkJet Printer
Color
Cover each tube up with a paper plate. Let only one color shine up at a time. Then turn the knobs back untill the single color looks clear and bright again.
Feb 14, 2009 | Philips 46PP9302 46" Rear Projection...
Convergence problem
I did not fix the TV,I have a new Panny, I wanted to find out if I gave it away would it be worth fixing.
Thanks,
Rudy
Mar 03, 2008 | Panasonic PT-56WXF90 56" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
43 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
