Question about Oster 12-Bottle Wine Cellar - Black
Adjusting temp Can't lower temp stays at 76. I can't refer to instruction manual because I lost it.
  • jjloughlin2 Jan 11, 2009
    i have the same problem ,what can i do to fix it
  • toto136 Jan 25, 2009
    I have the same problem. It quit cooling ant now stays at 72 degrees. What's up with that?? Any body know the answer? Please help. Just a year old. thanks.
    Problem Solver:
  • 7 Answers
I think your problem is a fuse in back panel has burnt out....you will need to replace it, Tthere are two fuses and one is easy to see and as usual the easy fuse is not the problem, the fuse you need to replace is probably the one in a black shrink rap on top left side of the panel. You will need to cut shrink rap off fuse and find wires. Next step cut and solder in new fuse. I belive the fuse used is a 5 amp 250v, I put in a 6 amp to repair.
Posted on Feb 23, 2009
Fridge temp is set at 5 degrees. How can i lower it
5 degrees is quite a good temperature for a fridge though I agree 2 or 3 degrees would probably be better.
I have never heard of a fridge without an adjustable thermostat whether electro-mechanical or electronic. Mostly the old types are accessible and intuitive to use but anecdotal evidence is the later bells-and-whistles types need a degree in computer science to even understand the instructions.
You really need to refer to the instruction manual to find the answer to your question. Fairly sure you can download one if necessary but it might be wise to return to the store and request a practical demonstration of how to adjust it. Perhaps you have a neighbour who has one - maybe facebook can help find you a local person...
Jul 01, 2016 | Whirlpool Refrigerators
Lowering arcticpro temp.
Find in a manual in advanced setup where you can adjust the maximum and minimum cooling and max min heating. Should be a set point that someone set to where it won't go lower than 76
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 05, 2016 | Arcticpro Ypc-07c Faac7 Portable Air...
Wont let me change temp. below 76 degrees on arcticpro
76 f is 24 celsius which is optimum temperature for comfort
User manual for jnc JAC-24Y2???- want to know what the optimal setting for heating temp is for economy in the unit. We seem to have to have ours set quite high to get the unit to run consistently. If we...
Normal settings 70 heating 74 to 76 cooling, I try to leave my cooling a 76 and keep it there. 76 degrees feels good if its 95 or hotter out side and the lower you set it the more it will cost.
Jul 03, 2011 | Heating & Cooling
The refrigerator door will not stay open.
check the adjustable feet at the bottom front of most refrigerators. Your refrigerator is probably up in the front to much. Lower the leveling feet some in the front and the problem will likely go away, Refer to your ownrs manual as how you do it on your model. ALL refrigerators have adjustable levelers.
Sep 30, 2010 | Hotpoint HSS25GFP Side by Side...
Have a new ac system installed thermostat is set at 76 shows room and setting the same all the time shouldn't the room temp rise before unit comes on.
Yes the temp should rise 2 to 3 degrees before the unit comes on, This is called the temp swing, try lowering the temp setting and wait for the temp to drop, then set it back when you want it.
Aug 21, 2010 | Computers & Internet
Temp too high
lamgrimes9,
Welcome to Fizya.,
You said, your Oster wine refrig won't lower its temperature below 76 degrees. I have it for about 5 months, and it worked fine all this time with a setting of 50 degrees. Now it refuses to lower its temp. It reverts back to 76 everytime. Can someone give me any ideas about what is wrong? FYI Mine did not come with an owner's manual.
Sounds like the Thermostat is bad.
http://www.oster.com/CustService.aspx?content=manual
The tel # in your Oster Manual is a recording and will not help you!
But New appliances are under Factory warranty and are fixed or replaced no cost to the customer!you are under
http://www.oster.com/CustService.aspx?content=center
Let me know how it goes.
Huuum
Please leave a rating.
Oct 05, 2008 | Oster 12-Bottle Wine Cellar - Black
Oster 12-Bottle Wine Cellar - Black Logo
162 people viewed this question
Top Oster Furniture Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
jasbo
jasbo
Rob Sinbad
Rob Sinbad
Are you an Oster Furniture Expert? Answer questions, earn points and help others
