Dual Monitor Problem
I need help. I was trying to set up dual monitor on our church computer and messed it up. The computer monitor is now identified as monitor 2 and the video screen is identified as Monitor 1. The desktop of the pc now shows on the video screen. I know there is a keyboard shortcut, at least there was on a laptop I used several years ago. This is a desktop computer by emachines that I use at church.
  • teresaj1963 Dec 28, 2008
    I have tried that yesterday when we were at the church. However, it doesn't change the computer desktop back to the computer monitor. I know on a laptop, you use something like Function+F2.
  • 36 Answers
Go to Control Panel, select Display, select Settings - change the drop-down to select which display is Primary?
Posted on Dec 28, 2008
No video.dual monitor set up. power button briefly goes from amber to green and then off.
after connecting external monitor see on the bar click on the displays symbol the select extended desktop or multiple display then you can see but if no display then restart the computer and go to setup by pressing del key and disable internal monitor and enable external monitor then you can see dual display .windows98 and old versions does not support dual display windowsXP and lates versions support dual display
Mar 12, 2010 | ViewSonic VA1930WM LCD Monitor
I need the settings to put this flat screen on my computor LCM 20-v5 ser# W2005cmc063905801
Can you please provide us also the barnd and model of your video card because its important so we can provide you the correct settings....You can also try this connect this monitor to the DVI port on your video card output then restart the computer and if you have teh setup CD for this monitor just run it and let it configure the settings for you...
Hope that helps............
Oct 02, 2008 | Computers & Internet
Starlogic 17'' as dual display not clear
Check and see if your NVIDIA drivers are up to date. Then try changing the resolution on your laptop to match the native resolution on the monitor and see if it works. If it does then you will need to look for the option to set custom resolutions on each monitor so that you can have both devices working at diferent resolutions if 1 is wide screen and the other is not.
Let me know if this does not work and you need more help.
Apr 20, 2009 | Computers & Internet
Dual monitor, Intel 82915G & nVidia RIVA TNT2 64, FC6, Dell Gx520
Here is a little guide for setting up dual monitors with fedora core 6: http://blog.taragana.com/index.php/archive/how-to-setup-dual-monitors-on-linux-fedora-core/
I haven't had to use duals monitors with Linux yet but if this doesn't work let me know and I'll run some tests as I can easily set this up at work (we use the same computers and similar cards).
Jan 12, 2009 | Dell OptiPlex GX280 PC Desktop
Dual monitor, Intel 82915G, ATI Rage 128 card, FC6
the ati chip is not so good dual monitor so please use nvidia for dual monitoring
Jan 09, 2009 | HP ATI FireGL4 (128 MB) Graphic Card
Setting up dual monitors with vista
1.both monitors work in single mode ok.
when you start the nvidia contol panel under the display heading
you have setup multiple displays. What does this say.
are you using the nvdia drivers or the cards oem drivers ?
plug one monitor in then start the computer when that monitor works ok , turn off and plug in the other ...
hope this helps
Dec 31, 2008 | Computers & Internet
How to add a 2nd screen to a acer pc
Do you have a video board in the computer, or just the on-board Video output?
You need to install a video board in the computer then you can set up the display for dual monitors.
Here is a link with a video on how to set up dual monitors.
http://lifehacker.com/software/dual-monitor/how-to-set-up-dual-monitors-218991.php
Good Luck
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 16, 2008 | Acer Computers & Internet
Dual monitors
You'll need a dual-monitor video card in your computer. The GVLM1928 is basically two monitors on a shared stand. Each side of the monitor has a separate video connection.
Feb 26, 2008 | Computers & Internet
Dual Monitor
To arrange multiple monitors
This procedure applies when two or more monitors are connected to one computer.
  1. Open shortcutcold.gifDisplay in Control Panel.
  2. On the Settings tab, click Identify to display a large number on each of your monitors, showing which monitor corresponds with each icon.
  3. Click the monitor icons and drag them to positions that represent how you want to move items from one monitor to another, and then click OK or Apply to view changes.
note.gif Notes
  • To open Display, click Start, click Control Panel, and then double-click Display.
  • The icon positions determine how you move items from one monitor to another. For example, if you are using two monitors and you want to move items from one monitor to the other by dragging left and right, place the icons side by side. To move items between monitors by dragging up and down, place the icons one above the other. The icon positions do not have to correspond to the physical positions of the monitors. You can place the icons one above the other even though your monitors are side by side.
Feb 13, 2008 | Computers & Internet
Monitor is off center
try using windows mode for WoW so youll be able to access the desktop..
Jan 25, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
Computers & Internet Logo
442 people viewed this question
Alun Cox
k24674
