Question about KDS K22mdwb LCD Monitor
Sudden color distortion
The display of my KDS K22MDWB sometimes goes irridescent - white becomes a purple/pink, yellow turns bright orange; even on dvd's; cannot predict when it will happen or when 32 bit colors will show properly
  • 36 Answers
This can happen if there is a poor connection of the VGA cable - tighten the screws on both ends, just in case one is loose
Posted on Dec 28, 2008
Screen is orange and pink where it should be white
Try updating graphic drivers from the HP website.
HP has a lotta tools inside, maybe one lets you run an updater HP Pavilion dv6405us Notebook PC Drivers Download
Feb 28, 2014 | HP Pavilion DV6405US Laptop
What are the corresponding values to the colors of poker chips?
the standard values for the poker chip colors are as follows
White, $1
Yellow, $2
Red, $5
Blue, $10
Grey, $20
Green, $25 sometimes green is also used as a $20 value
Orange, $50
Black, $100
Pink, $250
Purple, $500
Burgundy, $1000
Light Blue, $2000
Brown, $5000
Oct 08, 2013 | Games
Need to determine whichcolor wires are for the speakers,the constant,switched.
Your vehicle radio color codes below;
Radio 12v blue + radio harness
Radio Ground (chassis)
Radio Ignition pink + radio harness
Radio Illumination yellow/red + radio harness
Factory Amp Turn-on blue/white or pink + radio harness
Power Antenna N/A
LF Speaker +/- purple - green/yellow +,- radio harness or amp under rear deck
RF Speaker +/- brown - brown/white +,- radio harness or amp under rear deck
LR Speaker +/- orange - black/pink +,- radio harness
Notes: On vehicles with premium audio systems, the LR speaker wires are yellow/green - white/orange.
RR Speaker +/- gray - gray/red +,- radio harness
Notes: On vehicles with premium audio systems, the RR speaker wires are red/black - gray/blue.
Feb 06, 2011 | 2007 Nissan Sentra 2.0 SL Sedan
I need to know what each color means on the existing radio stereo wires please... 1999 chev silverado.
I think this is the right table, but I don't know if it will display right. If not, go to http://www.installdr.com/InstallDocs/GM/PDF/460005.pdf
Typical GM Factory Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Left Front Spkr (-) Light Gray White w/ Black Stripe
B Left Front Spkr (+) Tan White
C Right Front Spkr (-) Light Green Gray w/ Black Stripe
D Right Front Spkr (+) Dark Green Gray
E Ground Wire Black Black
F Not Used
G Headlight Dimmer Wire Gray Orange (if available)
H Power Antenna Turn On Pink Blue
I +12 Volt Ignition Wire Yellow Red
J +12 Volt Battery Wire Orange Yellow
K Right Rear Spkr (-) Light Blue Purple w/ Black Stripe
L Right Rear Spkr (+) Dark Blue Purple
M Left Rear Spkr (-) Yellow Green w/ Black Stripe
N Left Rear Spkr (+) Brown Green
Sep 06, 2010 | 1999 Chevrolet Silverado 1500
A digram for the factory wireing for the radio
This color code works for 87-93 mustang factory radio; it might work on yours as well. I'm not sure if it has the same fuses though.
Radio Connector:
Light Green / Yellow - Hot at all times (Fuse 8)
Yellow / Black - Hot in ACC or Run (Fuse 11)
Light Brown / Red - Goes to instrument panel dimming rheostat (Fuse 4)
Red - Ground
White / Purple - Hot in ACC or Run (Fuse 11)
Speaker Connector:
White / Light Green - (+) Right Instrument Panel & Door Speaker
Dark Green / Orange - (-) Right Instrument Panel & Door Speaker
Brown / Pink - (+) Right Rear Speaker
Pink / Light Brown - (-) Right Rear Speaker
Pink / Light Green - (+) Left Rear Speaker
Tan / Yellow - (-) Left Rear Speaker
Light Brown / White - (+) Left Instrument Panel & Door Speaker
Orange / Light Green - (-) Left Instrument Panel & Door Speaker
Hope this helps.
Aug 15, 2009 | 1991 Ford Econoline
Need color code diagram for sterio
I'm not sure what year you have but this color code works for 87-93 mustangs.
Radio Connector:
Red - Ground
Speaker Connector:
Hope this helps.
Jun 19, 2009 | Ford Escort Cars & Trucks
Cd player installation
CAR WIRING
Constant 12V+ Orange To Radio Yellow
Switched 12V+ Yellow To Radio Red
Ground Black To Chassis Ground
Illumination Gray Orange/White on radio
Dimmer Brown n/a on radio
Antenna Trigger Pink Blue/White on radio
Left Front (+) Tan White on radio
Left Front (-) Gray White/black on radio
Right Front (+) Light Green Grey on radio
Right Front (-) Dark Green Grey/black on radio
Left Rear (+) Brown Green on radio
Left Rear (-) Yellow Green/Black on radio
Right Rear (+) Dark Blue Purple on radio
Right Rear (-) Light Blue Purple/Black on radio
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 29, 2009 | Clarion M235-RET CD Player
1998 dodge ram 1500 4x4 stereo wiring
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground
dark green = left front spkr +
purple = right front spkr +
blue/white = right rear spkr -
brown/blue = left rear spkr -
brown/yellow = left rear spkr +
blue/orange = right rear spkr +
black/yellow = park lamps
brown/red = left front spkr -
orange = dimmer signal
pink = fused battery +
green/red = radio choke relay
red/white = fused ignition
blue/red = right front spkr -
cheers
djmac62 is also an excellent answer
Jan 10, 2009 | 1998 Dodge Ram 1500 4WD
Oem Radio installation
*** 91 park ave with delco bose =
black = ground
dark green = lights on input
grey = panel lights
pink = on input
yellow = power input
orange = battery power input
nca = shield ground
tan = left fr spkr +
orange/black = left & right spkr -neg
lite green = right fr spkr +
nca = shield ground
dark blue = right rear spkr +
dark green/yellow = right & left spkr - neg
brown = left rear spkr +
purple/white = display dim output
pink = vehicle speed input
**** 91 park ave without delco bose =
grey = left front - neg
tan = left front + pos
dark green = right front - neg
light green = right front + pos
black = ground
dark green = display dim signal
grey = panel lights
pink = power antanna
yellow = ign input
light blue = right rear - neg
dark blue = right rear + pos
yellow = left rear - neg
brown = left rear + pos .
there YA go
Dec 27, 2008 | 1991 Buick Park Avenue
KDS K22mdwb LCD Monitor Logo
204 people viewed this question
Top KDS Computers & Internet Experts
Steve Allison
Steve Allison
Marvin
Marvin
ray
Level 1 Expert
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
