Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Frige and freezer not getting cold fan is working
This is a kenmore 5366220 2004 model
Thanks so much for the help. i had the exact same problem and this diagnosis was dead on!
Posted on Jan 03, 2009
  • 318 Answers
There is a problem with the compressor realy. it is mounted to the side of the compressor and when the coils get plugged with lint they will overheat and short out.
clean the coils and remove the relay, a white box looking device and shake it in you hand, if it rattles or has pieces coming out of it, then it is bad and should be replaced.
Posted on Dec 28, 2008
3 Suggested Answers
  • 90 Answers
SOURCE: freezer works frige dont
check for frost in freezer section. If frosted up your air flow is being blocked. Must thaw and determine why it is not defrosting
Posted on Jan 05, 2008
  • 2006 Answers
SOURCE: kenmore model (p) 66992 fridge
If the compressor is not operating to cool the unit then the most likely causes are the relay or the capacitor or the compressor. If the compressor is extremely hot then that tells you the compressor is getting power but not working. If it isn't hot then it probably mean that either the relay or the capacitor is not allowing power to get to your compressor.
http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Refrigerator-Parts/W10293291/0046/106/Model-59669928011/0582/0161000?keySuffixId=NA&productTypeId=x&searchModelNumber=59669928011&subCompDesc=Unit%20parts&brandDesc=KENMORE&modelDesc=REFRIGERATOR&blt=11 Relay
http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Refrigerator-Parts/2169373/0046/106/Model-59669928011/0582/0161000?keySuffixId=NA&productTypeId=x&searchModelNumber=59669928011&subCompDesc=Unit%20parts&brandDesc=KENMORE&modelDesc=REFRIGERATOR&blt=11 Capacitor.
The part numbers on those links are searchable so you can look for cheaper prices.
Posted on Jul 19, 2011
Freezer side working frige side not
Check ur cold control thermostat, ur thermistors in both fridge and freezer ( they should be checked for both ohms and for amount of current being put out as per ur model ), ur air flow vent from freezer to fridge.( to make sure it opens and closes without any restrictions) On thermistors check for A close circuit and amount of ohms not just an Ohm reading. As per ur model. Most should atleast show 1200 ohms. Also Check door seals for leakage. check ur fan and air flow damper vent too
Jul 28, 2014 | Kenmore Refrigerators
Frige freezer works fine but frige does not. 6 yr old kenmore 596.75509400 model
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 25, 2011 | Refrigerators
Refrigerator isnt cold anymore but is running
Sounds like a too low setting or the compressor shut down.
Dec 01, 2009 | Cars & Trucks
Freezer is working good but the frige is 52
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Aug 17, 2009 | Refrigerators
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator getting hot!
There is a part of the condenser called the mullion loop that adds heat to keep moisture from building up and causing the door gaskets to stick. If it's too hot to the touch, first check your frige and freezer temps. You'll obviously know if the frige is too cold, but you may not know if the freezer is too cold. The freezer should be between 5-10 deg ABOVE zero. Any colder and the frige will have to work harder and would create more heat. Also check the condenser coils. If they are dirty it will prevent the frige from removing the heat properly. The condenser should be cleaned at least annually. Most friges have a condenser fan motor. Make sure the motor is running and the fan blades are clean. Most friges also have a cardboard type panel on the back at the bottom. That panel directs the air flow across the condenser and must be in place. If it's missing or damaged it will need replaced.
Jul 20, 2008 | Refrigerators
KENMORE SIDE BY SIDE NOT COOLING
You should hear a fan running inside the freezer. It also blows cold air into the refrigerator side.
Jun 09, 2008 | Kenmore 50522 / 50524 Side by Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
133 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
