Question about Philips 28PW6506 28" TV
Philips 28PW6506 Hi, recently my tv was making funny noises, like a squealing. The picture starts to dissappear with a horizontal line. When i switch the set on now i get no power to the tube, but a component near the front of the chassis board is making the squealin noise. The noise goes up and down, once the power is switched off it sounds like it is being drained...Any help would be much appreciated............Jason
    Problem Solver:
  • 6 Answers
This sounds like one of the capacitors has dried out. They are metal cylinders containing 2 rolled up strips of foil separated by a gel. Over time the gel can dry out an eventually the strips of foil touch creating a short circuit. A TV repair shop should be able to replace the faulty component relatively easily. I wouldn't recommend trying to do this yourself unless you are very confident you know what you are doing, the voltages present in a CRT TV are very dangerous.
Posted on Apr 24, 2007
SOURCE:
My TV keeps switching its self off, it makes a clicking noise as if its trying to switch on. Then cuts out.
Do to the clicking noise your tv makes is a very common idicator that your power supply in the tv is failing. Its an easy fix lots of DIY videos on youtube but may cost you a arm.
Apr 29, 2013 | Philips 28PW6506 28" TV
Sony 32" tv makes a squealing noise, the picture goes to a horizontal line, then goes away with the squealing noise continuing. Turning it off and on again resets it temporarily.
The power supply regulator board should be checked. Visit the site named 'Electro-help' for more details. Click this link. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 900 posts to different brand TVs now.
Oct 03, 2012 | Televison & Video
Horizontal lines across the top 3 inches of picture
Hi
what line started? from Left to right? or from top to bottom?
Thanks!
Nov 28, 2008 | Philips 32PT6441/37 32" TV
Samsung TX-P2670WH 26" tv squealing
hi there, you do have a problem at the hozintal section, check the FBT and some parts at the horizontal section and at the power supply section. ty
Jan 01, 2008 | Samsung TX-P2670WH 26" TV
Philips 28PW6506 28" TV - no picture - just went pop
Hi
Please check TV's control board main capacitor for worn out.
Thank you.
Dec 28, 2007 | Philips 28PW6506 28" TV
Philips wide screen TV
OK sorted the problem on my set. Replaced the capacitor ref: 2455 on main board it is a 47uf 25v but i was told a 35v will work as well? But mine is a 28pw6506/05
Nov 08, 2007 | Philips 28PW6506 28" TV
Option codes for 28pw6506/05
Option Code are 220 255 151 184 240 54 3
Imran Ghafoor
Oct 23, 2007 | Philips 28PW6506 28" TV
Tv philips 28"
Hello, you (tech) can try this remedy - 1500 = fuse (250V/4A) - 3523 = resistor (47R) - 3527 = resistor (0.22R) - 3532 = resistor (2.2K) - 6500 = diode GBU4JL7002 - 6523 = diode 1N4148 - 7520 = circuit TEA1507P/N1 - 7522 = transistor BC847B - 7521 = transistor STP10NK80ZFP - 6526 = diode BZX384-C22 - 7515 = optocoupler TCET1104-G - 3526 = resistor (0.15R). - 3526 = resistor (0.22R). If you need more info please advice. Arpi
Jun 17, 2007 | Philips 28PW6506 28" TV
Green horizontal lines
Hi, I have a Philips 29PT9009/12 TV. Recently I have begun to see horizontal green lines on my tv, when either watching a dvd or watch tv. This has gotten worse and now the green lines are more visible and the background is now turned a shaded green. Please help me. Thanks in advance
Apr 30, 2007 | Philips 28PW6506 28" TV
TV will not switch on
It sounds like you may be on the right track. Also you could have a problem in your Horizontal Deflection circuit. Since you say it flickered, you may have a solder joint that was arcing. Probably in the horizontal circuit. I found a capacitor which was arcing in this circuit. I was a small disk type. NOW since it is chirping, the horizontal output transistor may have shorted placing too much of a load on your power supply. The noise you hear is the power suppply trying to start. Stargazer
Jan 29, 2007 | Philips 32PW6506 32" TV
Philips 28PW6506 28" TV Logo
114 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
