Question about Danby DMW1146SS Microwave Oven
Missing the plastic ring under the turn table
We recieved a Danby DMW 1048SS 1.0 microwave as a christmas present. The plastic ring piece with the wheels that help the turntable turn which is placed under the turn table is missing as well as our mannual for the microwave. How can we retrieve these things so we can use our microwave.
  • 1,234 Answers
I'm not 100% sure but 95 that it doesn't have a roller.
Here's the replacement...
https://www.amazon.com/Replacement-Danby-DMW753W-Microwave-Glass/dp/B00YOPH5F0
or ck here too...
www.repairclinic.com
Appliancepartspros.com
All show it without roller.
here's the manual....
https://www.manualslib.com/products/Danby-Designer-Dmw1048ss-193717.html
Best to you.
Posted on Feb 02, 2018
4 Suggested Answers
  • 75 Answers
SOURCE: Replacing light bulb in Microwave Oven.
if this is a counter top modle this is no problum, unplug it!!!
open door look for the light hole vents, ( that is where the bulb is )
you will need to unscrew the outer casing. noproblum there is nothing but reguler insalation in side and a area where the bulb is. replase it you can buy them at any hardware store,
if is a under cabinet there my be a axes door if not will need to take down,
hope this helps.
p.s. 1st time i that there was all kinds of things in side but not
Posted on Jan 23, 2009
MicrowaveSvc
  • 9149 Answers
SOURCE: I have danby microwave m# dmw 1147SS the glass
Contact Danby Customer Service US / Canada here.
Please let us know if they do not help you.
Posted on Jun 16, 2009
  • 105 Answers
SOURCE: turntable won't turn in the microwave
look for supply to turntable motor if supply is coming on motor and it is not moving it means motor is faulty
Posted on Jun 23, 2010
Turn table not turning
Normally that would mean you have a bad turn table motor or the a plastic drive piece that goes into the motor gear from inside the microwave.
Apr 05, 2014 | GE Microwave Ovens
Need a replacement part The plastic part that turns the turn table cracked. The part nmber is 5888W2A012-1 Where can I order one?
Its called a turntable ring. That specific one can be found at sears for $16.26. I have a kenmore microwave and its has the same # on mine as well.
Mar 10, 2011 | Microwave Ovens
Turn table wont turn
This is commonly caused by a turntable motor that has worn out and needs replaced.
The motor can be replaced by following these steps:
1. Unplug microwave.
2. Open oven door and remove glass tray and carousel ring.
3. Locate and remove the screws holding the bottom panel (under the microwave) in place. With the screws removed, the bottom panel should open.
4. Disconnect the connector plug from the turntable motor.
5. Reach inside the oven and remove the coupler. This is the small plastic piece that the center of the glass tray sits on. You may have to gently pry up with a flat screwdriver to get it to come loose.
6. With the coupler removed, loosen the mounting screw(s) to the motor and it should easily come out from under the oven.
7. Install new motor in the reverse order of the steps I just provided.
This is a very simple repair. I could only find the motor listed at repairclinic.com. The part number is 1467810 and costs about $34.
If you have any questions, or require additional assistance, please post back with your complete model number so that I may be able to provide you with better assistance. I hope this help you.
Oct 09, 2009 | Sharp R-1470 Microwave Oven
I have danby microwave m# dmw 1147SS the glass centre dish slipped out and broke I am currently looking for a replacement Please advise. sherry I live in brampton Ontario
Jun 15, 2009 | Danby Microwave Ovens
hope this helps.
Jan 23, 2009 | Danby DMW1153 Microwave Oven
Part Needed
If you're referring to the roller wheel assembly, the part number is 5889W2A011A.
You can order this from www.microwaveglasstrays.com
or call toll free 1-877-894-0035
Sep 03, 2008 | Microwave Ovens
Danby microwave not heating
yes the turn table turns, everything works, but no heat.
Jul 02, 2008 | Microwave Ovens
My DANBY DMW744W 700 watts does not work?
What would cause the plastic turn table shaft plate holder in the center to ignite
Feb 22, 2008 | Danby DMW650 700 Watts Microwave Oven
Microwave Oven EM-804T
You need to trace the power feeding the high voltage transfomer. Because the table doesn't turn, it implies that a door switch or safety interlock is the problem.
Jan 01, 2008 | Microwave Ovens
Danby DMW1146SS Microwave Oven Logo
65 people viewed this question
Top Danby Microwave Ovens Experts
William Miller
William Miller
vince
gbob59
Are you a Danby Microwave Oven Expert? Answer questions, earn points and help others
