Question about Aluratek AIRMM01 Internet Radio Alarm Clock with built-in WiFi
"Failed to lookup DNS" error with Aluratek wifi internet radio
Aluratek wifi internet radio:
I can connect the device to my wireless network (I see the device in my DHCP clients table), but whenever I tried to retrieve internet radio stations, I'm greeted with a "failed to lookup DNS" error. I've restarted the modem, restarted the router, turned off security, done everything I can think of, but whenever I queue the radio to pull down the station list, I get the same DNS error. This even though all my other devices (3 laptops, ipod touch, and wii) connect the internet flawlessly. Thoughts?
  • 5 more comments
  • Anonymous Dec 31, 2008
    i am also getting this error. worked fine for a week then (nothing changed) got this error. also, can play playlist but wont wake to playlist.
  • BioMechanic Dec 31, 2008
    same here. worked fine for a week then out of the blue i get the DNS error. also, unit wont wake to a playlist... i can play a playlist but once set, it will not wake to a playlist.
    Wireless is BAD. Updated firmware, nada. Save your self some trouble and run a Cat5 wire to it.
  • Anonymous Jan 03, 2009
    I also have the "Failed to Lookup DNS" error when running as a wireless client. When wired, the problem disappears.
  • kadie_marie Feb 03, 2009
    Have you guys put in a "ticket" at Aluratek Support website? I am hoping to get a response. Have any of you tried calling them? There is a phone number in the back of the manual, 1-866-580-1978. I will try that tomorrow if I don't get an email response. They are on pacific time.
    I also am having two other problems with this new radio. It doesn't "see" the FM transmitter on my satellite receiver so I can't pick up my satellite stations. Also I just tried the "add a station" feature on the website but it won't take my Vturner ID. Very frustrating!
  • jonflan Feb 22, 2009
    I have this fail to look up dns problem as well. I did get it to work once with the wire, but now it won't work either way.
    I also tried Alurtek support on the web to no avail. They finally just said get a newer router, which is ridiculous.
  • Anonymous Mar 08, 2009
    Same problem with both wired and wireless connection to LinkSys WRT54g V6. Added static DNS IPs to router and that did not help.
Here's the useless response from Aluratek customer support:
"Failed to lookup DNS, the password is case sensitive, if you are using upper lower case letters you have to key in the correct case otherwise you won't be able to connect your radio. Thanks."
However, Aluratek advised another AIRMM01 owner to obtain a newer modem. I bought a new Actiontec GT724WGR Wireless DSL Modem and that resolved the problem with my AIRMM01F.
Posted on Nov 02, 2009
This is an old question that didn't have a definitive answer, so I hope someone is able to make use of my resolution if they are googling this same problem.
I was having the same problem and spent hours trying to figure it out. Same as everyone else, it worked when wired, but when setup for wireless, "failed to lookup DNS" error. I updated to latest firmware and it did not help.
I created a ticket with Aluratek support and they got back to me pretty quickly. They said to use WEP with a 10 digit numeric password on the wireless router. I had been using 128-bit WEP with a 26 character password and when I tried it with 64-bit WEP and a very basic 10 digit password, it finally worked. However, when I went back and tried to change it to a stronger password, it stopped working again and had the same DNS error. Even if I changed back to my original 10 digit simple password, it wouldn't work. I was only able to get it to work if I disabled WEP altogether. Disabling security isn't an option for me, so I kept trying to find a way to get it to work. I wound up changing the SSID on my wireless router and assigning it the stronger password that I originally wanted to use and it worked. Somewhere on the radio the old SSID is caching some setting that was preventing it from working.
Now my only problem is with the range of the wireless - if I go anywhere outside of the room where the wireless router is, the radio can't find it. I've gone back to Aluratek support and will see if they have an answer for this one.
Anyways, hope this helps someone. Once it is working, this radio is a good product.
Posted on Nov 13, 2010
  • 1 more comment
  • ssaroop Nov 30, 2010
    I had the exact same problems with an AIRMM02F and got the same useless "help" when I called up the Aluratek phone number (i.e. case sensitive WEP key, turn off WEP, use Google DNS). Needless to say none of it worked. I finally got it working by turning off the wireless N leaving only A/B/G. Also, I found that it won't work at all if you don't broadcast the SSID.
  • raytech104 Aug 04, 2011
    well all of you, I had the same problems and was told it was a network problem... Worked wired but nor wirelessly.... SO.... After getting some help from Aluratek support I muddled with my router and played with the wireles modes.... Initially I had it set to 'mixed'.... Then changed to b/g only and it worked!.... Tried with another router and the mixed option worked so it was indeed a router issue.... A Linksys/Cisco issue.
    I am not using cheap routers either .... One is the WRVS4400v2 and the other is a WRT600N that is flashed with dd-wrt firmware so Cisco is the culpript here .... Not Aluratek..... Thanks to Aluratek for their help and support!
  • Pritam Jaswal
    Pritam Jaswal Aug 30, 2012
    Yes, you are correct, set it to the setting without the N and it will work. I also called
Give up, return your product and move on.
The tech support people at Aluratek are well intentioned and helpful. But the product simply can't find or interact with wireless routers. Return it and move on.
Posted on Aug 03, 2009
What is the ranking of
The server at can't be found, because the DNS lookup failed. DNS is the network service that translates a website's name to its Internet address. This error is most often caused by having no connection to the Internet or a misconfigured network. It can also be caused by an unresponsive DNS server or a firewall preventing Google Chrome from accessing the network.
Jun 07, 2014 | Dodge journey mirror. inside rear view
Having trouble connecting to internet
My mobile internet is not working with and without the wifi, It's always saying DNS Lookup failed. Why?
Nov 17, 2013 | Samsung i9500 Galaxy S4 16GB Unlocked...
I am connected to the internet but can't connect to certain sites.
Check your poxy settings. Almost sounds as if there is a proxy server blocking access. Also check DNS settings. If you need to hard code DNS settings into the network connection. I use googles DNS free servers at or these are a global DNS server.
Sep 12, 2013 | Linksys E1200 Wireless Router - Ieee...
Problem with internet connection
These sort of problems are usually caused by malware (Virus or Spyware) I would suggest that you try to setup your router again using the Router installation disc.
May 07, 2013 | Dell Inspiron 1501 Notebook
Aluratek AIREC01F will not connect to wifi
first need more info is this a secure router connection...does it require a password to login to. if no then i'd refer to this link make sure you meet tehe requirments.
if yes i would make sure you entered in the correct password on your new device and if you did try a reboot to clear any possible communication error sit may have gotten.
Aug 20, 2012 | Aluratek AIREC01F WiFi Internet Radio -...
How can I connect WiFi router to office network?
On your computer wireless card configuration, try changing the fixed IP address to the following -.
In the TCP/IP Protocol set Obtain an IP address automatically and set Obtain DNS server address automatically.
Jun 25, 2012 | D-Link DIR655 WiFi Router 4port switch...
My belkin n USB adapter (f5d8053) has been unable to access the wireless internet at my new place, through the mwn-apr150n medialink wireless n broadband router. My other devices connect fine, it's...
Please check the Network Range B/G/N Signal.
This could be the issue if other aplications are able to connect.
Also try to delete Wifi Profiles using the USB and add fresh wifi networks
If not in install & reinstall the the USB Software on ur pc / laptop
Lastly if this doesnt work try to use the USB Adapter on another network / other device and try to connect
If it doesnt then u have a USB Issue
Jul 02, 2017 | Belkin Computers & Internet
Dns failed error occured in s5620 samsung mobile .. when i use internet through mobil office or wifi
This sometimes happens in Samsung Cellphones that while connecting to internet via WIFI, DNS failed
To solved it follow the given procedure:
  • Go to browser
  • Then go to setting
  • Then clear cache, empty cookies and delete history
  • Now restart your Samsung S5620 cellphone, then connect to desire wifi connection, then browse after setting up your browser profile
If it doesn't solved then contact to Samsung Service providers and consult with providers of WIFI connection, But i hope it will work.
Don't forget to do Rating by Clicking on Four Thumbs which are given below to this solution if it is HELPFUL
Thanks and keep Using FixYa
Mar 09, 2011 | Samsung S5620 Cell Phone
DNS error when trying to connect to internet
1- Try setting your own DNS server settings, right click on your network connection > properties > TCPIP v4 > edit DNS settings ( use as a dns for example).
2- Try refreshing your DNS cache:
start > run > cmd > and type: ipconfig /flushdns
Hope it helps !
Feb 01, 2009 | Dynex 802.11g Wireless-G Laptop Card
Aluratek AIRMM01 Internet Radio Alarm Clock with built-in WiFi  Logo
3,173 people viewed this question
Top Aluratek Audio Players & Recorders Experts
Are you an Aluratek Audio Player and Recorder Expert? Answer questions, earn points and help others
