Question about Onkyo TX-SR603X Receiver
Programing a Onkyo Universal remote control
Help !
I need very simple intructions on how to program our Onkyo Universal remote control. Can anyone direct me to a web site that has VERY simple instructions. The Onkyo reciever I have is ..Tx Sr603. I have even checked out U tube ... no luck there...
I wait a reply... I'm sure someone can help...
Charlie
    Habit-Forming:
    Scholar:
  • 51 Answers
Not to be found. Your remote controls a lot of functions, and as such can be confusing to program properly. I can only suggest two things, one, sit down with pages 14-18 of your user's manual and use some patience finding how to work it. If you do not have a manual it can be found at manualslib.com and look for this search result ONKYO TX-SR603X INSTRUCTION MANUAL Pdf Download. with manualslib.com underneath. Your second option is too take it a repair shop or knowledgeable audio/video dealer and have them program it for you.
Posted on Dec 18, 2017
  • 6 Answers
SOURCE: cant find universal remote code for the onkyo tx-sr605
Your onkyo receiver and remote controller only decodes 4 digit codes so what you have to do is to call the manufacturer of the remote controller it self and ask for the hexa decimal codes for their remote. They should provide it to you coz they're the ones responsible on doing that.
Posted on Nov 29, 2008
  • 239 Answers
SOURCE: remote code for sony playstation 3
you cannot control a ps3 with that remote because the playstation 3 only works with bluetooth. I'm sorry to have to tell you. you can purchase a remote that works with your system at any that sells your system.
hope this helped
please rate well.
Posted on Mar 06, 2009
SOURCE: What remote control code does the Onkyo TX-SR304 use?
From: http://www.comcast.com/remotes/universal.html - only worked for me when I had AUX setup with 30135
Unlocking Volume Control For A Single Device (Individual Volume Unlock):
  1. Press a desired mode key where you want volume to be unlocked (e.g., AUX) and controlled within its own mode.
  2. Press and hold SETUP until the selected mode key blinks twice, then release SETUP.
  3. Enter 9- 9- 3 and then press VOL- once. The mode key will blink four times confirming unlock.
    If desired, repeat steps I to 3 (of this section) for each device that you want volume to be unlocked.
Now, after you select a device that has volume unlocked (e.g., AUX), pressing VOL , VOL-, or MUTE will control the device's volume only in its own mode.
Posted on Apr 15, 2009
  • 5 Answers
SOURCE: Onkyo Reciever TX-SR806 Losing HDMI signal.
I had the same problem with my xbox 360. I was able to fix the problem by disabling the Display Discovery setting on the xbox.
Posted on Feb 12, 2010
  • 4234 Answers
SOURCE: I have an Onkyo TX-DS797 it is about 6 yrs old
These units *(if I remember correctly) had a problem with a memory IC in the surround porcessing section that would show up initially as popping and would eventually end up with no sound at all. This is a straightforward repair that involves replacing the IC with a new one (different manufacturer). The problem is that this is a surface mounted IC and is difficult to replace without damaging the underlying PC board. This is NOT a DYI repair. Have this unit checked by an authorized Onkyo service center.
Dan
Posted on Mar 09, 2010
Onkyo remote control codes
Your Vizio universal remote should be able to search for an appropriate code. If a thorough search produces no result, you may have to try another universal remote.
Sep 09, 2014 | Televison & Video
Tip
Onkyo Remote Control Programming Would you like help programming your Onkyo...
Would you like help programming your Onkyo remote control to control other devices?
To program your Onkyo remote control, follow these steps:
  1. Hold down the REMOTE MODE button for which you would like to enter a code, and keep pressing it down.
  2. Press and hold down the DISPLAY button until the remote indicator lights up (about 3 seconds).
  3. Within 30 seconds, use the number buttons to enter the 5-digit remote control code for your device. (look these Onkyo remote control codes up in the codes list.)
  4. The remote indicator will flash twice to indicate a successful programming.
The Onkyo remote control codes, listed by brand, are available here.
I hope that helps.
on Apr 11, 2010 | Audio Players & Recorders
Onkyo Codes for Samsung remotes?
Hi, unfortunately this remote does not have the ability to program to your Onkyo receiver. You must use your original Onkyo remote to control the volume of it. If you need a new Onkyo remote you can purchase one from Replacement Remotes. You can also buy a universal remote to program and work for both your units, so you will not have to keep switching back in forth between remotes. If you would like a universal I suggest getting the RFS200, this remote will even work if your receiver is not in direct line of site.
Sep 02, 2012 | Samsung BN59-00852A Remote Control
How to program remote control?
Your Onkyo TX-SR304 receivers remote (RC-645S) is not capable of controlling devices by other manufacturers. It controls only Onkyo devices.
Other Onkyo remotes do have universal remote functionality and you can download Onkyo remote codes here.
I hope that helps.
________________________________________
Download Onkyo TX-SR304 users manual here.
Mar 26, 2010 | Onkyo TX-SR304 Receiver
Mitsubishi M-VR900 remote
Harmony by Logitech; they have models ranging from 70-400 based on your needs. They are 100% programmable, meaning any function your unit has, it will duplicate. PC software is very user friendly. You can set this remote to control up to 14 different devices and one button control. They even pass the Wife/Mother, & in-Law tests.. They have a substantial Database of products on file so you don't have to have your original remote. If you have problems while programming, they will actually answer their phones 14 hours a day. Why do I like these so much? Price/Performance/User friendly & I program all remotes from Universal to Crestron. Hope this helps. If you have any questions, reply & I will answer for you & help any way I can.
May 25, 2009 | Mitsubishi M-VR900 Receiver
Need codes for universal electronics remote that will oporate tx-sr606receiver
The user manual for your remote can be found here:
http://dl.owneriq.net/8/81ab9d22-0467-4cae-bd9e-72c0d73c95c2.pdf
The manual says to try codes 3015, 3063, 3064, 3066, 3068, 3075, 3076, 3078, 3083, 3084, 3086, 3088, 3090, 3092, 3098, 3100, 3103, 3104, 3105, 3106, 3110, 3132.
If these don't work I don't think it's possible
Apr 21, 2009 | Onkyo TX-SR606 Receiver
Remote Control Programming my MX-3000
Hi Jimmy, we do programming for several types of universal remotes all across the country. Once a client visits our site, www.totalcontrolremotes.com, and fills out a new customer form and downloads, fills out, and emails us their configuration we can give them a quick estimate, eta, and mail them back a configuration file. We also are unique in that we offer a lifetime contract for changes made in case the customer adds or subtracts equipment, has channel lineup changes, wants something else set up, etc. We provide many graphical, simple to use and most of all enjoyable custom designs.
Visit our website www.totalcontrolremotes.com for more details. We will be glad to help you with any of your programming needs and do quite a few MX-6000, MX-3000, MX-980, MX-950, MX-900, MX-880, all the way down the line. We also do many other types of remotes as well and I am sure you will find our pricing very reasonable.
Thank you,
Vincent
Total Control Remotes
Universal Remote Programming & Advanced Control Systems
Feb 26, 2009 | Universal Remote Control MX-3000 LCD...
Finding codes
how program my control sanyo for tv curtis mathes
Sep 12, 2008 | RCA DIRECTV Satellite Remote Control
Alberto
I have a Sanyo TV and a RCA remote (universal) I have misplaced the code, can you help me?
Jul 29, 2008 | RCA RCR311B Remote Control
Onkyo TX-SR603X Receiver Logo
113 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
