Question about Frigidaire FMV156DC Microwave Oven
Microwave comes on on its own. What can be the problem?
We have a Frigidaire FMV156DCA 950 Watts. Sometimes after heating food, we open the door and take it out. No time is left on timer. We shut the door and it comes on,. It will not shut off with the buttons, we have to open the door to turn it off. It works ok most of the time but the problem seems to happen more often and we are afraid it could stay on for a long time and us not know it and start a fire. Can you help us with this problem. It happens every few days. Sometimes it seems to just come on by itself. Thank YOU
  • 63 Answers
I suggest you see a repairer but until then when ever it's not in use leave the door OPEN
Kind Regards,
J Howard
FixYa Operator
Posted on Feb 07, 2009
My microwave is making a very loud noise and not heating food.
Try plugging it into another outlet and see what happens.
Jun 27, 2017 | Frigidaire FGMV174K Microwave Oven
I need to change the interior light bulb in my Frigidaire over the counter microwave. The model # is FMV156DCA.
Good Morning Evelyn, thank you for allowing me to assist you!
Here are some simple troubleshooting tips to help replace the light bulb on your Frigidaire microwave, FMV156DCA.
    ·First, disconnect power to your microwave. This can be done by either unplugging it or at the circuit breaker panel.
    ·To release cover, remove the screw on the light cover (light cover may become very hot, do not touch glass when light is on).
    ·Remove old light bulb and replace only with equivalent watt bulb available from parts distributor or the manufacturer directly. Bulbs are also available at most hardware stores or lighting centers. Bulbs larger than 30 watts are NOT recommended.
    ·Close light cover and secure with screw removed in step 2.
    I hope this information proves to be helpful. If you have further questions, please do not hesitate to reconnect.
Nov 25, 2013 | Frigidaire FMV156DC Microwave Oven
FMV156DCA turns on, cook indicator lights but not cooking, timer counts down fine too
Hello epinvegas - Try reprogramming the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, then it sounds like the microwave has a faulty magnetron, wiring failure or control board. Contact a professional to assist with the repairs.
Feb 07, 2013 | Frigidaire FMV156DC Microwave Oven
Siemens HF26066GB plate is moving when door closed and not moving when open
Have a shop look at this---there usually is a recessed safety switch inside the jam that will prevent the unit from working with door open--sounds like the problem may be with it.
Nov 03, 2012 | Siemens HF26066GB 1000 Watts Microwave...
Frigidaire FMV156DC 950 Microwave sometimes stops heating
This sounds like a common primary interlock switch. Need to check and or replace both door switches. DISCHARGE high voltage components first with no power applied prior to touching anything in the unit. Failure to discharge High Voltage Components can result in death
Aug 13, 2012 | Frigidaire FMV156DC Microwave Oven
Ge jvm1540 no power..piece of ****?
The main fuse in the microwave oven has probably blown, usually caused by a bad door switch due to food partical buildup.
Mar 12, 2012 | GE JVM1540SPSS 950 Watts Microwave Oven
Frigidaire FMV145K 950 Watts Microwave Oven makes LOUD noise when turn table turns?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 25, 2011 | Frigidaire FMV145K Microwave Oven
Will not heat food, does come on when you push start
Check the latch switches, it has two types one is open another is close.You can replace a same types. Be careful the high volt ! could be unplug the power before to fix.
Those switches are behind the door. Good luck.
Oct 12, 2010 | General Electric JES1142WD 1100 Watts...
Food won't heat up
Hello, I had the same problem, and just fixed mine. Start by turning on your microwave (on mine, the light turned on and timer worked, but the fan nor the plate turned)... push the door upward and see if the microwave turns on... (mine did). so far so good. open the door and take the upper hinge cap off with flat head screwdrive. take the door off and place a small washer on the bottom hinge, put the door back on. your microwave should be good now. essentially, the door just needs to be pushed up a bit so it will work.
good luck, hope that works for you...
Jun 01, 2010 | Frigidaire FMV156DC Microwave Oven
Frigidaire FMV156DC Microwave Oven Logo
296 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
