Question about Iomega ZIP 250 External ZIP Drive
250 zip drive
When i put in a 250 disk it will start to spin and will not stop. it will not accept 100 disk also. all i can do is push the eject button two times to eject the disk.
Throw it away. It is rubbish.
Posted on Sep 06, 2007
How do you get a disk to pop out of a iomega zip 100
Hello.
If your iomega drive is connected to your computer, open My Computer and right-click on the Zip disk drive icon and choose the option to eject.
If unsuccessful, or the drive is not connected to your computer, remove the disk manually. Look for a small hole or lever. If a small hole, use a straightened paper clip and push into the hole to remove the disk. If a lever, lift and pull backwards.
Hope this helps.
Jan 07, 2012 | Iomega ZIP 100 MB USB (32133) External ZIP...
I have a Zip 250 disk that will not read. When I insert the disk in the external disk drive, it will spin and stop a few times and that's it. When I try to access the disk/drive letter via "My Computer",...
If the disk is unreadable this means that the format or the files extensions on it are not readable in the operation system you use..either are damaged or the disk itself is damaged or it wasn't finalized like it should ...If other disks inserted run ok than the disk it is damaged and it is nothing wrong with the drive itself..When it says to insert a disk this means that it is not seeing the disk at all and it sounds like a drive problem ..but if other disks are ok ..than it is just a damaged disk or in a format unreadable ..beware if it a cd unit ..will not read dvd-es..or if it a dvd kind will not read large dvd-es (dual layer) or blue-ray disks..
May 29, 2010 | Iomega ZIP 250 External ZIP Drive
Iomega ZIP drive Model Z10052 purchased in 1998. Disk is stuck inside. Have turned off electricity & used the paper clip as shown in Troubleshooting. Doesn't work, think maybe disk was put in wrong....
Some Iomega Zip drives suffer from what end users have dubbed "The Click of Death". The symptoms of the drive meltdown under this conditions is that the disk will not eject and makes a distinct clicking noise when it attempts to spin up. I do not now if the Z10052 is specifically a model of the Zip drive that is effected by this problem.
I do know that others, though I have never had the occasion to use it myself, have had success with stick disks in ZIP drives by powering down the unit then re-powering it back up while holding the drive eject button in during the process [holding the button down the whole time]. They report this has caused the disk to eject.
Feb 05, 2010 | Computers & Internet
How to eject a floppy disk from the external drive? It is stuck in the drive and can't remember how to get it out.
Sometimes the disk stops when ejecting, and remains in a slightly lifted position, making it impossible to eject it no matter what. It has to come back to it's resting place inside the drive and then you can try ejecting it again.
Try to push it back in with something that will not destroy the disk and the drive, like a piece of cardboard, or your finger, if you can reach inside.When it clicks back into place, try ejecting it again. Repeat a couple of times if necessary, it should unlatch eventually.
Nov 03, 2009 | Iomega (32453) External ZIP Drive
Zip drive does not eject the disk and will not power up.
To the left of the Eject Button/Activity Light is a Disk Eject Hole. It will be a very small hole big enough for you to straighten out a paperclip and push in to hit the eject the disk
Jul 20, 2009 | IBM Iomega ZIP 750 (22P7099) External ZIP...
MY PS3 WONT ACCEPT DISK
I bought a PS3 yesterday and had to take it back - when entering a disk it would get pulled in and start to spin but would only go in still leaving about a half inch sticking out - it would spin for about 15 seconds and then stop. I had to take it back and get a replacement which worked fine.
Jan 03, 2009 | Sony Playstation 3 (PS3) Console
Can not eject zip disk
I have the imoga 100 external zip drive and there's a pin hole on the front panel. that if you straighten a paper clip and stick in the whole, it should manually eject the disk.
Jul 12, 2008 | Iomega (32453) External ZIP Drive
Cant figure out how to use zip drive when i have added a pass to my zip dr 250
1. Insert a blank disk into the zip drive
2. Give this disk a password (it can be any password, as long as you
remember it)
3. Using the Ioega toolset, set the zip drive's sleep time to a large
value (such as 1 minute)
4. Wait a while until the drive "spins down". You will hear the drive
stop spinning.
5. Take a pin or a straighten paper clip and stick it into a hole in
the back of the Zip drive. This will manually eject the blank disk.
6. Insert the disk you want to access (the one you don't know the
password to)
7. now use the IoMega toolset to remove the password. When prompted
for the password use the password from step (2).
This is just a word of warning in case you store any important information like I used to on zip disks. Perhaps move to a more secure medium.
May 09, 2008 | Iomega Zip 100MB (31714) External ZIP...
Iomega ZIP 250 External ZIP Drive Logo
181 people viewed this question
Top Iomega Computers & Internet Experts
Starnley Johnwells
Starnley Johnwells
Marvin
Marvin
 Grubhead
Grubhead
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
