Question about Vtech 5.8GHz Cordless Phone with Digital Answering System
My Vtech answering machine won't take messages and is blinking A
I have a vtech5.8 answering machine phone set and the answering machine won't stop blinking ''A'' and won't take messages.  We have tried unplugging it, pushing ''Change'' and ''setup.''  Nothing works.  Any suggestions because it's frustrating not having a machine that takes messages.  Thank you for you help!
  • 365 Answers
Try to disable the Announce Only feature from the settings and try.select the Announce Only feature to be in OFF condition.try it and then you will be able to use the phone in the good condition.try resetting the system also.thank you
Posted on Dec 28, 2008
    Sergeant:
    Novelist:
  • 327 Answers
Messages are retrieved from the base unit by pressing your mailbox number. You can set the base unit to give an audible message alert which beeps every 10 seconds when new messages have been received, or set it so the mailbox light blinks. The lights are red. You cannot retrieve the messages through the handset, so you cannot listen to messages privately (unless no one else is in the room, of course!). A small window with a red LED display shows the total number of messages recorded. You have to press the lighted mailbox button to see how many are in that mailbox.
You can set the number of rings before it picks up to 2, 4 or 6. This was another important feature for us because from certain parts of the house we simply cannot make it to the phone in 4 rings. Additionally, there is a setting to screen calls so that by pressing the correct button on the handset if you pick up after a message has begun it will override the mailbox and you can answer the call.
You can pick up your messages remotely by dialing your phone and entering a two-digit security code that you have pre-set. I have only done this twice, but it was easy enough and worked fine. You can listen to new messages or old messages. Supposedly you can save, delete, record a new announcement and even record a memo from a remote location, but I have not tried all those features.
You can adjust the message volume. You can skip or repeat messages while listening. You can slow down or speed up the message by pressing and holding the repeat or skip keys. This is handy to be able to understand a number that someone gives you too hurriedly, or to move through a long-winded message-leaver to get to the number he left at the very end.
You can also use the mailbox to record a memo to yourself.
This is a digital recorder; there is no tape. A total of 15 minutes of messages can be saved, and the limit for any one message is 4 minutes. If you are gone from home for long periods of time and don’t retrieve your calls this might not be enough total time for you. It is plenty for us.
You can also make a separate recording to be used if you do not want to accept messages. In other words, the machine will store two outgoing messages at the same time, one when you want to accept messages, and another one if you just want to announce to the world that you are not interested in hearing from anyone. There is a setting which allows you to choose which message is heard by callers.
for more details just click this link for manuals
http://www.retrevo.com/support/Vtech-i6777-Telephones-manual/id/6684ci656/t/2/
    Genius:
  • 1,550 Answers
Verify the unit is installed correctly. Refer to "Getting Started" section of your user's manual for installation instructions.
  • 2,427 Answers
YOu need to try hard resetting it..
1.) unplug the machine and the phone line
2.) open the machine up and you will see a lithium battery
3.) remove the battery .. wait 5 minutes
4.) replace and remount.
5.) that should work,, if not,,.. I hope you have warranty..
  • Rishi Roshan Ali Dec 28, 2008
    PS try blueextc3221 solution first ,, he's right about the Announce Only feature he suggested that you turn it off by looking in the manual under Answering System Operation if his fails then try mine.
  • 15,935 Answers
Do you have a model # ?
  • 2 more comments
  • blueextc3221
    blueextc3221 Dec 28, 2008
    An A will appear in the display window when the Announce Only feature is turned on. In Announce Only mode, callers hear an announcement but cannot leave a message. If you want to receive messages, make sure Announce Only is turned off. For more information on configuring Announce Only and other features of the answering system, please refer to the Answering System Operation section of the User's Manual.
  • blueextc3221
    with a model # i can give you a direct link to your manual
  • blueextc3221
    Solution:
    1) Make sure your answering system is plugged into a live telephone jack and power source.
    2) Make sure your answering system is turned on.
    3) Some answering systems have an announce only option, which plays your greeting but won't record messages. Make sure your system is set to record messages.
    4) Your answering system’s message capacity may be full. You must erase old messages to make room for new ones.
    5) If you have voicemail service in addition to your answering system, your caller’s message may be going into voicemail before your answering system picks up the call. Program your voicemail to pick up at least 2 rings after your answering system is set to answer the call.
  • blueextc3221
    Answering system operation
    Activate the answering system
    The answering system must be turned on to function. If the answering system
    is turned off, the base unit displays ANS. OFF on the screen.
    To turn on/off the answering system:
    • Press the softkey MENU in idle mode.
    • Press the softkey twice to reach ANSWERING SYSTEM. Press the
    softkey SELECT to confirm.
    • Press the softkey SELECT to select ANSWER OPTIONS.
    • Use the softkey or to scroll between ON and OFF. The current setting
    is highlighted. Press the softkey SELECT to confirm, and there will be a
    confirmation tone.
Vtech phones
is memory full on answering machine
May 02, 2014 | Vtech ia5874 Cordless Phone
How to set up VTech answering machine
Enter the model of your VTech 5.8GHz system into the search box at http://www.vtechphones.com/support/general/manuals to download a copy of the manual.
Feb 14, 2014 | Vtech 5.8GHz Cordless Phone with Digital...
Vtech phone anserwing machine light is blinking.
You apparently have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Jan 09, 2014 | Vtech CS6629-3 2 Handsets Cordless Phones
Can not set a message on the answering machine
Jan 06, 2014 | Vtech 5.8GHz Cordless Phone with Digital...
My uniden phone message light won't stop blinking. Have deleted all messages. How do I get the annoying light to stop??
click on menu button
move down to answering set up keep going down to global set up
click menu and down to VMWI press menu
' move down to yes press menu and end
it starts from NBN installation
It will continually reappear so when you get the process correct copy it down
Oct 01, 2017 | Lands Phones
Vtech model 6053 answering machine will not record message
Perhaps your answering machine needs to be set set to accept messages. Maybe your message machine memory is full of messages?
Aug 03, 2012 | Vtech DECT 6.0 Cordless Phone with Digital...
How do I set the number of rings before the answering machine picks up on a Vtech CS6114 cordless handset?
The CS6114 isn't an answering machine. It won't pick up any calls on its own.
If you have an answering machine attached, refer to the documentation for that machine or else repost your question specifying the make and model of your answering machine.
If you subscribe to an answering service provided by your phone company, contact them for information and help.
Sep 04, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
Lost my manul - how do I set my answering machine? It records a message, but not as my answering machine message. Thanks!
Enter the model number of your VTech phone into the search box at
http://www.vtechphones.com/vtechphones/index.cfm/support/general/manuals/
to get the manual.
Jul 29, 2011 | Vtech 5.8GHz Cordless Phone with Digital...
Answering machine not taking messages and blinking "A"
Your system is set to "Announce" instead of "Answer". Since you neglected to specify the model of your VTech system I can only suggest you enter it into the search box here to download a copy of the manual to learn how to switch the mode.
Dec 28, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Vtech 5.8GHz Cordless Phone with Digital Answering System Logo
512 people viewed this question
Top Vtech Lands Phones Experts
Marvin
Marvin
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
