Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Compressor under warranty, how much is the labor to fix it?
Amana side by side repairman says it the compressor It is under warranty I need to know if I have to pay for labor and how much do you think it will cost ?
  • 334 Answers
How old is it and is the repairman an indipendant company or the manufactuers repairman?
If its older than a year, and/or the repairman is indipendant then yes you probably will have to pay for labor.
Expect between 250 to 400 for the labor.
Some units have no labo warranty from the manufacturer.
If less than a year and the repairman is actually employed by AMANA directly and not a subcontractor or "authorized rapairman" then you may have a labor warranty.
Posted on Dec 28, 2008
Amana abb2224dew repairman installed part # 8201786. This was to replace the compressor start up. Worked for a week, then same buzz click sequence occurs. Looked up part number. Part is for mostly...
The replacement compressor kit is #12002633 from Amana (Now Whirlpool).
In this kit are the following New model compressor, relay/capacitor, jumper and instructions.
Kenmore does not make appliances rather all of the other manufacturers produce for them.
That part number is for Whirlpool Start Relay/Capacitor and as long as the compressor is the right horsepower for the relay it makes no difference who made it. (Techumseh or Embraco)
Apr 29, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Computer board went out. when you remove the computer it has a black mark behind it on the plastic housing. how long is the warranty on the comperssor of this refridgerator?
the compressor usually has 5 year warranty in fact the sealed sytem itself which includes the compressor .evap coil and usually the condenser coil has 5 years... the boards usually only have a 1 year parts warranty or up to a 5 year parts warranty but after the 1st year you are responsible for the labor on the board....the compressor though should be covered through amana for 5 years total cost... good luck to you....
Feb 16, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
What is the cost for a repairman to replace the compressor of an Amana ARB2257CSR?
depends on price of parts plus labor time -easy replacement nothing in way to work on unit, wiring good and compressor/freon oil is not contaminated should take about 2 hrs @ $70hr ---$40 house call plus price of compressor[which can be from 100 to 200+] ,freon,filter and other mics parts it adds up quick best is to call and ask for an estimate from a repair service
Jan 13, 2010 | Amana ARB2257CSR Bottom Freezer...
I have an Amana bottom freezer frigerator. The
Possibly a bad relay/overload or shorted run capacitor.If it was built between 2002 and 2005 it may be a bad compressor in which case you would want to check the warranty for possible coverage.
 the relay/overload and run capacitor plug right into the compressor on the left hand side.
 IF it isn't under warranty and the Oem part won't get it going pick up a 3in1 hard start for it they are easy to install and will get it working for you.
Sep 05, 2009 | Amana SXD524VW Side by Side Refrigerator
Refrigerator does not get cold, motor is running, repairman says get a new one. only 1yr old (frigidair side by side)repairman said sealed system needs to be replaced.
Well, that's great for you since the sealed system is cover with a five year parts and labor warranty. Call a local Frigidaire certified repairman and tell him the situation.
Aug 05, 2009 | Frigidaire FRS26H5AS Side by Side...
Amana refrigerator too warm, freezer too cold
the damper control is not working let me tell you what to do the air that comes from the freezer block if you can get to the damper you will see it have a get rool a piece of paper between the body of damper and the get flap and have it open if the refrigerator side start cooling is the damper control i am sure about that is the damper control
Apr 01, 2009 | Amana Easy Reach Plus ABR2527FES Stainless...
Freezer Compressor Leaks Oil and Stopped Working
Hi I'm a subzero asc (Autorized service center) Subzero would not be responsible, your unit is out of there warranty. Now if the service company your dealing with is any good they can get a new compressor under a part warranty from there part distributor. Also in my many years working on subzero I have never seen oil dripping from the compressor unless you have a leak somewhere in the sealed system. Unfortunately the only thing you can do is see if your service provider will fix the unit. they will charge you labor if they get the part in warranty. It's possible that the service provider did not to the job properly but that's your word against there's. Good luck I hope everything works out for you..
dmparenti
Jan 09, 2009 | Sub-Zero 661/F Side by Side Refrigerator
Amana Side by Side Refrigerator not getting cold
amana is having some problems with their compressors locking up. if the compressor is manuactured by tecumseh then tthe compressor is mostlikely locked up and will need replacing. good news is your refrig is most likely less than years old and should be in warranty to amana..
Dec 15, 2007 | Amana ARSE66MB Side by Side Refrigerator
Amana bottom frezzer refrigerator
Gazzo, You are on the right track. I've been finding a lot of compressor failures on these Amana's. It's possible that the overload and relay for the compressor failed, but Im more inclined, from what I've seen, that the compressor is the problem. The compressor is covered under warranty, parts and labor for 5 years. I would call for warranty service...Catriver...post back.
Jan 04, 2007 | Amana ABB1927DE Bottom Freezer...
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
132 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
