Question about Frigidaire FMV156DC Microwave Oven
I have an fsv156DCA Frigidaire microwave. When we finish heating something, open the door to take it out and shut the door and it comes on b y itself. Even if the timer is on zero and have to open the door again for it to shut off. Does this sporatically. Not alll the time
  • Frigidaire Master
  • 9,128 Answers
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Dec 28, 2008
Fridgidaire microwave won't shut off
Good Morning friend, thank you for your post!
I see that you are having difficulties with your Frigidaire microwave not shutting off. This could be a possible issue with your control panel or door switch. I would recommend performing a reset on your microwave and that can help clear out any potential miscommunications. To perform a reset you can flip the household circuit breaker off for roughly ten minutes. If that does not help resolve your issue you may need to seek assistance from a professional technician for proper diagnosis and repair. Hope this is helpful. -Matt
Mar 09, 2015 | Frigidaire FMV152KS Stainless Steel 1000...
Microwave runs when door is open
Hey friend, thanks for your post!
From my understanding your Frigidaire microwave is running when the door is opened. I have identified a few possibilities could be the control panel or your door. Since it could be any one of these underlying issues I would recommend having a professional come and properly diagnose your appliance. -Matt
Sep 22, 2014 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
Microwave keeps running with door open
I'd say the door interlock switch has failed, and supplies a connection when it should not. Microwave ovens can be dangerous to anyone poking around inside, even when unplugged, so get a quote from a service tech. You might find that parts+labour is almost as much as a new one.
Microwave radiation being released through an open door is also a hazard, as it is known to cause eye cataracts, so don't get near if the oven does this.
Nov 19, 2013 | Panasonic Inverter Countertop Microwave
When door is shut some type of internal fan kicks on...
Hello Derrick Baker - Typically no fan should come on without starting the microwave. There is one exception! For an example, if the microwave becomes too hot from something that is cooking on the stove below the microwave, the fan will come on and will cycle off once the bottom of the microwaves cools back down. If the fan is turning on when the door is closed, more than likely, a door switch as failed. At this point, I recommend connecting with a certified technician to move forward accurately to assist with the repairs.
Mar 09, 2013 | Frigidaire FMV157GM Microwave Oven
My husband heated up something in the microwave and when he took his food out he bumped the latch and broke it and then shut the door. Now we can't even get it open. How do I open the door so I can see...
You would need a new "door latch". It's a pretty easy do it yourself job.
You can look it up and find helpful exploded views by entering model number (as FMT118E1W0) at the Pros' site here.
You have to separate the door panels (as shown in the attached photo).
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Jan 11, 2011 | Frigidaire FMT118E1W Microwave Oven
Frigidaire FMCB115GC Microwave Oven wont stop
The only parts that are available for this unit by model number are the tray inside and the feet on the outside.
If you were adventurous and found a way to take it apart and remove the door switches you might be able to match them up at an appliance parts dealer but short of that it sounds like a lost cause.
I know that is not what you want to hear, and I as well do not like being the bearer of bad news.....
May 12, 2010 | Frigidaire FMCB115GC Microwave Oven
The microwave won't stop.
You probably have a bad door switch or door switch mount. See this file.
May 05, 2010 | Frigidaire Built-In Microwave
Microwave comes on on its own. What can be the problem?
I suggest you see a repairer but until then when ever it's not in use leave the door OPEN
Kind Regards,
J Howard
FixYa Operator
Dec 28, 2008 | Frigidaire FMV156DC Microwave Oven
Microwave Steams Up, Heats Up, and Shuts off!
first of all your mwave needs to be properly ventilated .the problem is your magnetron when heated the thermal cutof switch cutts out power to magnetron.works again when cool.change magnetron
Mar 20, 2007 | GE XL1800 1100 Watts Microwave Oven
Frigidaire FMV156DC Microwave Oven Logo
101 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Jim Goldsmith
Jim Goldsmith
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
