Bad order during final rinse
We have a top loading fisher paykel intuitive eco washer and this problem just started happening that during the final rinse there is a bad odor. We have taken it apart and there is no residue build up or mold on any parts we can see. Also did a fosforus rinse to clean it out internally, but it still is happening? We do about 2-4 loads a week, mostly cold in the past and it is about 1.5 yrs old. Any help would be great
Have a old 703 top load, has same poroblem????, all apart very grotty,but wanted I.P.L's , found lite metal strip on shaft ,seal looks ok ,shaft has very little movement, pump is ok and not leaking . i've replaced a few. will clean and try again . cheers jc
  • 86 Answers
Hi,Is the machine connected to a stand pipe or sink connection?
Posted on Dec 28, 2008
Fisher Paykel Intuitive Eco Washer - IWL15: what is error code 136 on a fisher & paykel IW...
fault code 136 is a hard one possible causes are faulty rotor speed sensor on motor,siezed bearings or rotor,motor windings ,or motor control module, would suggest you get a tech for this one to diagonse correctty ,without proper tools to test eg: rss tester you could cot yourself more money... hope this was some help....:)
May 18, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and paykel intuitive washing machine not spinning
the pump could have overheated nd burnt out or u could have damaged the controller
Jan 28, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
I have a problem with white depost on black clothig after final spin in my new eco top loader
it is either he detergent or limescale got to espares and but the lime scale and gunge remover
Jul 29, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel Intuitive Eco switching itself off during cycle.
Could be a bad drain pump or controller or rotor position sensor. You will need a Tech to take a look. Unfortunately with these machines there can be many reasons for a failure. Call F/P to get a certified technician out there.
Jun 14, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
How do i put intuitive eco on to just spin clothes not a whole wash cycle
press power button press up button 2 times on option button to "wash advance" press adjust button to which ever rinse cycle youd like to use. press start.
Jun 05, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher&Paykel Intuitive eco IWL 16 Auto washer Fault code 51
Our washer did the same but it was after I took the excess drain hose and pushed it into the drain in the wall. I thought it looked "more tidy" In doing so I created a siphon effect. Once I pulled the excess hose back out it was fine.
Jan 23, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
the top load f/p washer is a "high efficiency" unit and has to be used with "HE" type soap. it is a non-sudsing soap and if you are using low or regular soap then the residues are not rinsing out causing the odors. they do make a special cleaning tablet called "affresh" it is designed to clean out any residues caused by your using too much or the wrong type of soap.
you can also run a cup of bleach on the longest cycle with hot water and see if thats helps too.
Dec 28, 2008 | Fisher and Paykel GWL11 Top Load Washer
Intuitive eco Iw811 Rinse 1 no water coming thru!
the 1st rinse light is normally set to "spray rinse", this means the machine will pump out the water, spin at medium speed then pulse cold water into the machine, this occurs for about 2 mins, then the machine will spin out, and advance for the final rinse which is a deep rinse.
Nov 15, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
62 people viewed this question
Top Washing Machines Experts
