Question about Toshiba CN35F95 35" TV
Weak and distorted audio
Audio output level, even with Volume Setting adjusted to maximum is just barely above an audible level. I have set the Bass and Trevle control levels to max and I have various settings for the Surround Sound, the Dolby(R) and Effects, none have given adequate volume. The audio is equally weak in the Right, the Left and the Woofer channels.
I thought the output amp (TA8256H) was defective and replaced that. I have also checked the coupling caps for the audion into and out of the output amp chip; these all checked out okay.
Suggestions for what other things to check are appreciated. Thank you!
John
2 Suggested Answers
  • 3 Answers
SOURCE: The speakers work but at a very reduced level.
Could be either an amplifier failure or a short in the speaker connection. For the latter, try removing and cleaning the speaker connections at both the unit and at the speakers. Then reconnect the wire, being sure to return the leads to their former location such that you don't accidentally reverse the leads.
Posted on Nov 28, 2009
The audio output level is too low. How do i increase it? I have to turn the volume up on the TV almost maximum to hear a "normal" level of volume.
my experience says that the VCR/DVD recorder does NOT has a volume setting inside. Cables may be bad or connected to wrong input but most likely, the TV has a setting for the volume for any source and that is probably set to mid-range like on a PC sound control panel. Go the audio setup on the TV and see if you can adjust the level for each input.
Mar 03, 2014 | Memorex MVD4544 DVD Recorder/VCR
Audio of Hyundai tv set
Some components are getting heated up most probably in the sound section due to high voltage. Either there is a failure of regulated power supply to that are or the IC or other components in the board are defective. This is a case to be handled by a qualified service technician, as the back cover has to be opened.
Aug 19, 2012 | Hyundai Televison & Video
I need someone who actually knows about audio and particularly MOTU microbook and headphones. I do voice transcription through headphones and am looking for clarity in audio but also a little bit of...
The realtek chip should come with the HD audio manager in the control panel if the drivers were installed correctly.
You'll want to check and make sure the equalization (under the sound effects tab) is set to none, or possibly to treble (I had to use the treble setting on mine if using a sound system with a subwoofer).
Another trick to raise the frequency of the audio is to raise the "Karaoke setting which will pitch shift all frequencies upward.
Jul 21, 2011 | Computers & Internet
Low volume on my HP Pavilion dv6-1245
Open the audio panel (settings -> control panel -> Sounds and audio devices -> volume). Check that the volume slide is all the way to the right. Also, click on the "speaker volume" button and check it is all the way to the right
Mar 21, 2010 | HP Pavilion dv6000z Notebook
Sub woofer volume adjustment
The gain dial is not a volume control. The gain dial is used to compensate the output level of your car radio head unit. all car stereo units output are not alike. If you set this gain level too high, it will cause major distortion (clipping) to the audio output of you speakers when cranked up. This excessive distortion WILL eventually, or even quickly damage or blow your speakers.
I personally blown speakers this way no not properly setting this. (lesson learned, I guess :| )
Jan 27, 2009 | Clarion DXZ545MP CD Player
Hear sound but cant get any real volume even at full blast
I was playing around with my Sherwood RD 6513 and adjust the the output level to its maximum, amongst other settings. This limited my output on the amp to a maximum volume of 65 not 90+.. Anyway i pluged in the microphone and done another 'auto setup' of the volume levels and distances, and this allowed the volume to exceed 65 again!
Also if you have an external source such as a DVD player - i would assume you have already checked its output volume setting?
Nov 23, 2008 | Sherwood RD-6500 Receiver
Need to know the right setting to apply for my subs
You need to match your amp's input voltage (the gain) to the output voltage supplied via your deck's preouts. Turn you radio up to normal listening level, and turn the amp's gain until you induce audible distortion then back it off slightly. Set the bass boost and crossovers to on and type (highpass for front/rear full range or lowpass for subs).
Apr 26, 2008 | Jl Audio 12W3 Car Subwoofer
Low volume
> Open Control Panel
> Sound Properties
> Speaker Properties
> Enhancements
Loudness Equalization : on
Equalizer: Choose one (Jazz seems to be loudest setting but sounds of hallway effect so I use powerful for clarity.)
This has more than doubled the level of volume on my acer 5570.
- verc
Jul 16, 2006 | HP Compaq nc6320 Notebook
Televison & Video Logo
37 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
