Question about Toshiba 42H81 42" Rear Projection Television
Negative looking white screen picture
When the picture is mostly white or light in color it shows like a negative but the rest of the time the picture is almost perfect - just goes a little wavey sometimes. Any idea how much this will cost to fix? Thanks! Q2007
    Scholar:
  • 77 Answers
This tv has many problems in the scan converter/hyper bd. the wavy picture is very common the problem with the white not so much. However, I have seen them cause many odd looking video distortions and I suspect this is where your problem is. The part is usually kind of high, 250 + Labor i'd guess. If you get it somebody good they can probably repair the bd rather than replace it and save you some money. Either way i'd plan on 300-400
Posted on Apr 24, 2007
On the startup screen color negative
Hi, It's an unusual problem but I don't thinks it's hardware. Most likely a corrupted preference file. Remember the screen just displays what is sent to it. if the signal arriveing is reversed then you get what you are experiencing.Go to your Home Folder (the one with the house icon) and loctate the Library Folder. In there locate the preferences folder and look for
com.apple.universalaccess.plist
Locate it and put it in the trash.
make sure you have the screen showing the correct way around and then shut the computer down.
Restart and see what happens. If it's still the same, do the routine again but this time leave the screen in negative mode before shutting down.
Post back and let us know what happens.
Jan 28, 2013 | Apple MacBook Pro with 17" Display
I need to know what does the colors on the harness to the sony radio mean?
Most aftermarket cd players have the following wiring diagrams
(+)Red..............12v ignition
(+)Yellow...........12v battery (Memory) Constant Hot
(-)Black............12v Ground
(+)Blue.............12v Power antenna
(+)Blue/white.......12v Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
(+)White............Front left positive
(-)White/black......Front left negative
(+)Grey.............Front right positive
(-)Grey/black.......Front right negative
(+)Green............Rear left positive
(-)Green/black......Rear left negative
(+)Purple...........Rear right positive
(-)Purple/black.....Rear right negative
Hope this is what you were looking for.
Nov 07, 2010 | Car Audio & Video
Stereo wiring harness need to the colors and what they do? for a 1997 mercury mountaineer
cannot find 97 but found 98. Do these match?
1998 Mercury Mountaineer Car Audio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Light Green
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Blue
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6? x 8?
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): Dark Green/Orange
Right Front Speaker Negative Wire (-): White/Light Green
Car Audio Rear Speakers Size: 6? x 8?
Car Audio Rear Speakers Location: Rear Doors
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Oct 16, 2010 | 1997 Mercury Mountaineer
1/turning the unit on the screen or panel is all white
You need to resolder the video IC processor they are one smd device
Apr 15, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
LCD Screen colors are bad on toshiba Satellite M115-S3094
Was the screen showing all OK before you updated the driver? If so did you try backing out (uinstalling) the graphics driver? You mentioned gtaking screen cover off ... did you completely remove the screen from the laptop, including the wide connector at the top and the smaller one at the bottom, and the small one to the backlight? These connectors might be seated wrong, and you'll have to reseat them, mostly the big one at the top. Best o'luck, Moorethemerrier!
Sep 20, 2009 | Toshiba Satellite M115-S3094 Notebook
Black and white screen...
The color wheel can cause a black and white picture but not the jumpy or negative look.
Those symptoms are usually caused by the DMD assy which drives the color wheel and is somewhat expensive, most of the time you can purchase the whole Light Engine which includes the DMD assy for the same price.
Mar 20, 2009 | Samsung HLN617W 61" Rear Projection HDTV
No real color picture, looks like an undeveloped negative, ghost
The pictures are indeed negative.  When scanning negatives or transparencies make sure you have the scanner set to the appropriate setting, otherwise simply Invert the colors in Photoshop, or similar photo editing software.
Dec 03, 2008 | Cameras
Negative screen image
Look in System Preferences for Universal Access, there is a Display option which says Black on White(the normal setting) and White on Black (the setting that has been enabled).
There is a keyboard short cut to change the setting, it involves pressing four keys - Apple, Option, ^ and 8.
Nov 29, 2008 | Apple iBook G3 Mac Notebook
E machine T2742
Well I can tell you that the white wires are negative. The colored wires are positive. Do you still have your manual? Never mind that. There is not a description reference to show you how & where the connectors connect to the board. I would say the two "Black & white", connect the case speaker, most Pc's the negative would face to your right looking in at the board. "Blue & white" would be the reset switch & red & white most likely is the "Power Led". Good luck.
Dec 17, 2007 | Computers & Internet
Toshiba 42H81 42" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
