Question about Samsung LN40A650A LCD TV
Remove stand I'm trying to remove the stand to wall mount it. I'm unscrewing the 4 back screws but they aren't coming out and the stand won't come off. Is there something I need to do to get it off that I'm not doing?
  • 21 Answers
If the screws won't come out, then get a magnet, the small kind that is used in auto mechanics, that's what I use to finish pulling them out, or use a magnetice drill bit, but that's all that is holding the stand on
Posted on Dec 28, 2008
I have a 42 in. Vizio Galleria and need to remove table top stand so I can wall mount. How do I remove base stand?
1. Unplug all of the cables and cords from your GV42L FHDTV10A.
2. Place the GV42L FHDTV10A face down on a soft and flat surface (blanket, foam, cloth, etc) to prevent any damage to the TV.
3. Pull the stand cover off by squeezing the sides to release the retaining plastic tabs.
(This is probably the trickiest part to find this, just feel around and don't be too rough with the plastic)
4. Remove the four (4) screws (screw's specs: M4, 0.7 Pitch, 15mm long) so that the stand base can be removed.
5. Gently remove the stand base
6. Now, the GV42L FHDTV10A can fit securely to a mount (sold separately) by utilizing the mounting holes in the center of the back panel of the TV. Please make sure to read the instructions of your specific mount to properly hang the GV42L FHDTV10A
Mar 13, 2011 | Vizio Gallevia GV42LF 42 in. LCD...
I can't remove the stand off the tv
Hi, i have instruction on removing your base stand.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
Note: Extreme care should always be used when removing
the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3) Remove the four screws shown in the diagram below. This will
allow removal of the pedestal stand.
4) Once you have removed all four screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
Feb 12, 2011 | Toshiba REGZA 52RV530U LCD TV
How do I remove the stand to mount the TV on the
the TV will mount to the wall via the VESA screw mounts on the back of the LCD. If it is a smaller, monitor sized LCD then the screw pattern will be either 75x75mm or 100x100mm. On larger TVs is it usually 100x200mm. Sometimes the base is screwed into this mount and othertimes to the bottom. Simply unscrew it from the screen. Be sure that the wall mounting kit can handle your LCDs VESA screw pattern, screen size and screen weight.
Feb 07, 2010 | Televison & Video
How do you remove the base inner bracket parts so that you can mount the TV on to a wall?
What make and model?
Most wall-mountable TVs will have threaded holes in the back for wall-mounting. Most of which you can bolt a bracket to then unscrew a few of the set-screws for the stand and slide the TV off of the stand.
Most TVs have 4 set screws for the stand located near the bottom middle of the TV where the stand inserts into the TV. The screws may be recessed fairly far into the back of the set and may require a long thin screwdriver.
Jan 01, 2010 | Panasonic TX-32LXD1 32 in. LCD Television
How to remove the stand from samsung 860 52"
  1. Spread the comforter out on a flat surface such as the floor.
  2. Step 2 Lay the Samsung flat-screen television face down on the comforter on the floor.
  3. Step 3 Use the magnetized screwdriver to gently unscrew the four to six screws securing the stand to the television.
  4. Step 4 Remove the screws with the magnetized screwdriver. If you do not have a magnetized screwdriver, cover the end of a normal screwdriver with masking tape with the adhesive side out so that it will catch the screw and pull it from the hole.
  5. Step 5 Pull the stand from the back of the television
  6. Step 6 Mount the television to the wall with wall-mounting hardware you can purchase from any home entertainment store.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Nov 15, 2009 | Samsung LE40R74BDX 40 in. LCD Television
Removing back stand supports
First I am not to sure about the brand you got there, But if it is not wall supportable you do not need to reove anything but by a wall mount that will hold the bottom in place and yes there are wall mounts for this tpye of arrangment see not all flat panels go on walls thus hence you cannot remove the stand easy. Try finding a wall mount the has a L shape to it, it will hold the bottom of the tv and it comes with a little strap to hold it back into securement. Please do not try to remove the stand I would suggest a diffrent wall mount- Rulds2008 TV expert for 20 years
May 14, 2009 | Sampo PME-42S6 42 in. HD-Ready Plasma...
I need to remove my flat screen footing so i can mount it to the wall
on the back of the set near the stand there is 2 - 4 screws just unscrew them, you will need to giv the pedistul a good tug but it will come of :D
Mar 10, 2009 | Toshiba REGZA 52RV530U LCD TV
I am trying to remove the stand on a LG Model : 52LB5D. I have removed the 4 screws on the back but can't remove stand. It feels like there is another screw or something holding it in.
If you are looking at the back of your tv there is the stand bracket with a screw on each side. remove those screws and nothing will happen. that is the problem i was having but if you look right above the ones you just took out and there is going to be a black screw. take those off from each side and it will fall off.
Dec 09, 2008 | Televison & Video
Akai 32"
I just purchased this unit and briefly looked at removing the stand though I haven't taken it off yet. Anyways, I think you need to remove the black metal mounting frame from the TV before trying to unscrew the stand (4 screws) from the metal frame. After the frame is off the TV, I think you can then get at a couple of hidden screws to remove the stand from frame. I don't know if the frame goes back on the TV or not.
Dec 01, 2007 | Akai LCT3201AD 32 in. LCD Television
Samsung LN40A650A LCD TV Logo
1,231 people viewed this question
Jerry Greenberg
Jerry Greenberg
