Washing machine water want stop running.
I have a whirlpool washer it's around two years old.When the washer cycle had's finish,the cool water is still running.Even if I push the dial to off the water want stop.Can anyone tell me why is that,do I need a new control unit.
  • 15,935 Answers
Sounds like your stop valve has a leak.
You dont need a control unit, just the proportioning valve.
Posted on Dec 28, 2008
Wfw9150ww00
Make sure your washing machine is on level ground, if the machine is off balance it will stop.
Oct 30, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool ultra care II quiet wash II - over the past few day has run intermittently. It stops for what appears to be no reason. Can't get it to start. I turn it off, then a few hours later when I...
Sounds like motor overheating and shutting down. Motor will have to be replaced if that's the case. Probably not feasible on a 10 year old machine
Aug 25, 2017 | Whirlpool Washing Machines
I have a 15 yr old Whirlpool washer that has run great. During a cycle, it stopped full of water. I moved the dial around to different areas pushing it in and out and got a cyle to run long enough to pump...
Not always a Timer issue. could be stopping at the cold fill part of the cycle which is the 8 o clock position on the dial. This would be fault with the cold fill vavle.
Sep 15, 2010 | Whirlpool LXR6432JQ Top Load Washer
Calypso washer stops/runs every 5 - 30 seconds in the middle of any washing cycle. No error codes. It just stops and than runs again all the time and cannot finish any washing cycle. It is 8 years...
I had the same problem. The washer control board has an intermittent failure. If you unplug power for about 30 minutes then plug it back in you will get a PF code (power failure). Ignore this code and push start again. It may run till it finishes the cycle or it may start cycling again right away. A new board costs about $180 at repairclinic.com
Aug 21, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
We have a Whirlpool duet washer that doesn't finish washing
its probably a blocked water filter to this fabric water valve or the coil has failed on the valve,it should be 3800kohms,check the filter at the water inlet connection,hope this helps
Jan 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Our whirlpool washing machine is 2 years old. It
Lid switch bad. Turn on and push down on lid switch with something
Aug 03, 2009 | Whirlpool WTW6400SW Top Load Washer
Whirlpool top loading washing machine not finishing cycle
SOUNDS LIKE A PUMP HAS GONE BAD. REPLACE IT. IT WOULDN'T COST TOO MUCH.
May 14, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Leaves white marks on coloured clothes
I'd try putting the machine on a hot fill wash, max water level put in half a cup of baking soda when the machine starts to washer turn it off and leave it to soak overnight, then let it finish the cycle the next day. Also make sure you tip some of the hot water down the beach dispenser and clean all around the top of the machine
Cheers
Mar 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultmate Care II won't drain
You will have to remove pumps hoses and make sure they are not clogged.
May 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
