Question about Apple (M9394G/A) Consumer Headphones
Ipod headphone problem
Headphone fell apart. wires sticking out. some look frayed. is this headphone fixable?
    Master:
  • 519 Answers
Posted on Dec 05, 2016
My headphones cut out when I am walking
Posted on Mar 10, 2009
Ignition module fell apart
u need a repair manual-online or in library--it may not be fixable -they wear out-car is 20yr
Jun 05, 2012 | 1992 Geo Storm
The whole wire that connects the left ear bud along with the ear bud still on it just fell out of the part where the two wires come together. Is there any solution to this problem?
buy new headphones?. i think a lot better than trying to repair it. it sounds like you are talking about where both earbud wires come together at the molded connector part that splices the wires together. unless you are mechanically inclined and electrically astute, you should just replace the
Mar 25, 2012 | Bose in-ear headphones - Black with...
No sound in right headphone, however if i hold down the wire in a certain position sound is restored. is this fixable?
Sounds like u have a bad wire, Its fixable depending on where the break is. If its near the plug end, u can head to ur nearest radio shack and get a replacement, however, if the break is in the leading headphone, though still fixable but requires a bit more tech savy. As long as u can operate a pair of wire cutters and a soldering iron, youll be good to go
May 23, 2011 | Sennheiser PX 200-II Headphones
My ipod touch, fell, and now the music sounds different
try cleaning the headphone jack to fix it or
try using different headphones
Nov 15, 2010 | Apple iPod touch
Jack in the headphones fell out?
See my tip on replacing dodgy cables and plugs on headphones.
Apr 25, 2010 | Skull Candy Skullcrushers Headphones
My headphones connect with the adapter, the blue light is on on both but nothing comes from the ipod. I have performed the factory reset but it still doesn't work. The headphones had worked fine and then...
I have same issue....just took my transmitter apart - the wires connecting the male jack to the silicon board are frayed, disconnected.....you might check that...it's only 2 small screws holding the outercase together....be careful though
Jul 07, 2009 | Logitech Bluetooth Wireless Headphones
Ipod earphones work sometimes or not at all?
Hi Humed, your best bet would be to determine whether or not it is the iPod that is malfunctioning or the headphones themselves.
To do this I would recommend plugging a separate set of headphones into your iPod that you know are functional.  If they work then obviously your iPod earphones are malfunctioning.  If the new headphones that you have checked are still not working when connected to the iPod then the problem is likely with the audio jack on the iPod.  In that case you should determine whether or not you have a warranty and send it in for repair at the place you purchased it or directly to Apple.
I wouldn't worry though it's likely that your iPod earphones are just getting a little old and the wear inside the white insulator have begun to fray, you could manually try cutting open the wire and reconnecting the wires but you may end up making it worse, and headphones are relatively cheap to come by.
Thanks for asking and I hope I helped.
Mar 11, 2009 | Apple iPod MA446LL/A MP3 Player
Right speakers don't work
After taking the unit apart, I found that the speaker wire had broken, at the point where it passes through the hinge. Although the wire is reinforced with plastic in this area, wiggling the wire showed that the break was there. I removed the coating and found that both wires were broken. That was it. No problem.
Aug 05, 2008 | Altec Lansing inMotion Plus Portable Audio...
IPod
take it apart and clean it with rubbing alcohol
http://www.ipodhowtovideo.com/mini/
Nov 11, 2007 | Apple iPod nano
Apple (M9394G/A) Consumer Headphones Logo
276 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
