Question about Magellan RoadMate 800 GPS Receiver
The hole of +- joint for external connection cord was broken
Dear Sir, I have a Magellan Roadmate 800 and its hole for +- external connection cord was broken. i.e. I can use the external connection cord to plug-into my device successfully. Thanks. Roman
  • roman31 Apr 06, 2009
    The solution is very easy as follows. Please open the bottom and do the soldering on 4 points easily. It is because the old solderings were losed. U can ask for help from someone who has a soldering gun for electronics.
I have a similar problem that the Power cord connection is broke (on the unit itself) - I use an Enhanced Cradle to power the unit and it works.
Posted on Apr 06, 2009
I have found my friend who is very familiar in electionic and small appliances to help me. I can fix it too, but unfortunately I do not have any soldering tools and parts here. I will bring it to Hong Kong and let my friend to fix it. It's very cheap if we find anyone to fix it in China where Magellan is assembled . Thanks.
Posted on Dec 28, 2008
Device will not power on
I found a Magellan Roadmate in the dumpster when I was dumping the trash off my truck.They were even so kind to leave the charging cord.I figured out that the charging cord wasn't connecting to the unit when plugged in.It took 20 minutes to figure out how to pop the case open(retainer tabs on all sides in addition to the screws).Once opened up,it took 5 minutes to repair the solder connections from the power socket to he circuit board.Works like new!
May 31, 2012 | Magellan Roadmate 2035 4370 2036 4040...
Magellan roadmate 800 update maps
http://www.peopleswireless.biz/magellan-rm800-traffic-kit.html
No You Will Need A traffic kit
Jul 05, 2008 | Magellan RoadMate 800 GPS Receiver
Female receptacle for power cord is damaged.
We have a Maggelan Roadmate 800.
The pin that charger connecte to is missing.
Can you help please?
Rgards
M Daneshvar
Glenwood, Bracknell Road, Warfield, Bracknell RG42 6BH
Telephone: 01344 883051 mobile: 07768 916053
Fax: 01344 886756
Email: PolyDevelopments@aol.com
Mar 16, 2009 | Magellan RoadMate 800 GPS Receiver
There are various reasons this could be happening. To start eliminating the main causes, go to the Magellan site and create a profile for yourself. You will than be able to download the latest firmware update and the newest maps. This will fix connectivity issues and at the same time give you the latest and greatest of what your device has to offer.
http://www.magellangps.com/support/product.asp
Sep 06, 2008 | Magellan RoadMate 800 GPS Receiver
Magellan roadmate 800 unlock code
turn off your unit with the slide switch on the top. Hold down the repeat button or the one beside the slide switch and then put the slide switch back to the on position. Then select hdd tools then format. exit out and turn the switch off and back on and it should work
Apr 02, 2008 | Magellan RoadMate 800 GPS Receiver
GPS freezes when I need it to work!
i have a 800 also but it does not freeze because i make sure it is up to date on all firmware and software,if i was you chk out for updates on the magellan website2.gif after you register your unit then if ther is, which i know do the update and you will have no problems after that.let me know how it goes.
Dec 25, 2007 | Magellan RoadMate 800 GPS Receiver
Won't turn on
One of the wires in your power cord could be broken. If you have the a/c adapter, see if you can power up with that. If you know someone else with a working Magellan, you could borrow his cord to test your unit.
If not, check the car adapter with a continuity tester. Put one tester probe on one of the side springs of the car plug and the other probe on the outside metal of the GPS plug. If that shows continuity, place one tester probe on the end tip of the car plug and the other inside the the GPS plug.
If either of those do not show continuity, first take apart the auto side of the cord. Check the fuse and the wire to contact solder joints. If they seem okay, carefully cut back the molded plastic from the GPS end and examine the wire to solder joints. If any are broken, replace the cord or resolder the joints.
Nov 05, 2007 | Magellan RoadMate 700 GPS Receiver
MAGELLEN ROADMATE 700 NO POWER
Nov 02, 2007 | Magellan RoadMate 700 GPS Receiver
Roadmate 700
One of the wires in your power cord could be broken and contacting intermittently. If you have the a/c adapter, see if you can power up with that. If you know someone else with a working Magellan, you could borrow his cord to test your unit.
Oct 28, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 800 - External Power Connection
The only thing I can think to add is a general question to Magellan asking why they let a four-year-old child design the power connector as "lightly" soldered to the main circuit board. Very dumb...
Sep 04, 2007 | Magellan RoadMate 800 GPS Receiver
Magellan RoadMate 800 GPS Receiver Logo
67 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
