Question about Toshiba 52HM95 52" HDTV Projection Television
Toshiba 52in THE TV IS NOT TURN ON IT MAKES A SOUND WHEN WHEN U PLUG IT IN AND OUT THE LIGHT IN THE FRONT OF THE TV IS TURNING ON A OFF YELLOW AT THE LAMP SIGN
MY TV IS ON A REC TIMMER IT WILL TURN ON BUT IT WILL TURN OFF AGAIN AND THE GREEN LIGHT WILL COME ON .
Posted on Jan 03, 2009
56 in toshiba rear projection tv. When u turn it on the green light comes on and a yellow light flashes 15times followed by a click sound. No picture. What does this mean?
Try going to www.toshiba.com to research your problem and what the 15 flashes of the yellow light means. Try unplugging your TV from the wall for about 30 seconds and then plug it back in. This will re-boot your TV (like re-booting your computer). If still no picture, if could be your bulb, motherboard or color wheel.
Mar 01, 2015 | Toshiba Televison & Video
Hello, I have a 52in RCA projection tv, model D52W20BYX1. It used to work fine but now whenever i try to turn it on it the power button light turns on and the tv makes a short whistle sound, this happens...
Not sure why chat got closed/ disconnected.
There is big transistor TL010 attached with heat sink near flyback transformer, this is horizontal output transistor, check it and replace if found shorted.
Thanks.
Apr 08, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Toshiba regza 47" flat screen last night i was
Check your power cable. Unplug it from both ends and plug it back in
Mar 05, 2011 | Toshiba REGZA 47HL167 TV
Tv won't turn on
change your lamp the sound will be the fans coming on if tv is a sony on some models are behind the cover on the front of tv and others are on side
Nov 29, 2009 | Televison & Video
Lamp light flashing on toshiba 50" projection tv
TV tries to come on - yellow light next to power light flashes but then it turn itslef off.........It tries agin after few sceonds and sequence repeats. I can hear the sound but no video
Dec 29, 2008 | Televison & Video
Toshiba 32A32 won't turn on
just fixed one with that problem it was the vertical output ic Q301
that was shorted. try wicking it out. it is a LA7833S.
Postings say to be sure to use the Toshiba part
Feb 27, 2008 | Toshiba 32A32 32" TV
RCA 52in HDTV will not stay on
I would turn the circuit board over and check for clod solder joints and cracked solder, you will have to look close, my other sugestion would be to get a can of freeze and spay the different IC's and see if it stays on longer.
Dec 05, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
No picture, sound and flashing red power light...
Pull off the back pressboard. At the bottom left hand corner is the power cord that attaches to the power supply board. There is a white plug that attaches directly to the power cord. With the TV power off, pull this white plug up to disconnect. Then push it back in. Then plug your TV back in and press the power button on the front of the TV. I just did this and it is working fine.
Sep 16, 2007 | Toshiba TP43H60 43" Television
Toshiba 52HM95 52" HDTV Projection Television Logo
57 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
