Question about Sharp Office Equipment & Supplies
HS on read out
When I tried to copy I had an "accordian" type paper jam as it was coming out. I couldn't find the paper jam after opening the side door. On the read out it said to contact a service person and an "HS" appeared on the screen where it showed the number of copies. One other time that happened and a service person gave me a code to put in and I have lost it. Can you help me?
FR in Jonesboro, AR
  • Everett Lin May 11, 2010
    hellow sir; the code you posted "HS" I believed should be "H5" if I'm right I do need the model # and which maker to reset for you!
  • 145 Answers
To access the service mode.you need to PRESS the the folowing.. BOTTONS.using the the oporation panel.PROGRAM INTERPUPT CLEAR ITERUPT .THAN ENTER # 14 THAT START BOTTON
HOPE THAT HELP
Posted on Dec 29, 2008
We have a imagerunner 210s. we just replaced the fuser unit and now when you try to copy, it copies the original but when it feeds through the exit door, it jams and when you open the door, the paper is...
please to see the claws. they are 5 claws which pluged on exit unit.
if you open the cover exit you will see them.
the shape like as a tigers claw. but more like as triangle.
they are move by spring, you try to moving. what are they work well?
problem usually cause
- the spring was loose or (you can plug or replace the spring)
- the claws have broken or (you replace a new)
- the claws dirty by crust toner. (you can clean up by your finger or your claw)
good luck.
May 22, 2011 | Canon imageRUNNER 210S Copier
Copier keeps jamming- prints a page but it jams on the inside. Looks like an accordian. I can open the side door, and pull out the jammed piece of paper.
It either needs a new fixing unit, or there is something stopping the paper on the paper path. Check and see if you can see anything obstructing the paer path. The fixing unit is what melts the toner to the paper, it is usually a consumeable option that isnt too hard to remove and replace, but can be pricey on some models.
Apr 13, 2010 | Sharp AL-1551CS Copier
The screen reads paper jam error, but there is no visible paper jam and when turned on a grinding noise occurs
Most likely, there is a paper jam in the fuser unit....which is stalling the fuser rollers, thus causing grinding noise (accordian or fan folded jam)
Oct 24, 2009 | Canon imageCLASS D320 Digital Copier
Jamming
Hello sir; Go make a copy let paper jam again, do not remove the paper, check the jamming paper area see there have any paper chip stuck in the paper path, clear it, otherwise cleanup roller with alcohal.
Jul 20, 2009 | Ricoh Aficio MP1600SPF Copier
Brother 2820 constant paper jams
Most likely the fuser is worn out, and needs replacement
Jun 02, 2009 | Brother IntelliFax-2820 Laser Fax
Ricoh copy machine 3025 paper jams every time we try to print
Make sure the paper that is in the drawer matches the orientation and size indicated on thje Op Panel Display, If NOT, MAKE IT MATCH.
Mar 31, 2009 | Ricoh Aficio 3025P Black and White Copier
Paper jam at output on the Imagerunner 1310
I have a solution. Take a baseball bat and knock the crud out of that ******! That will fix the problem of not having a door! Thus it will make a verrrrrry easy opening to get the paper out! :-D
Feb 04, 2009 | Canon imageRUNNER 1310 Printer
Sharp AL1642 CS Copier Grinding noise and Paper Jams
Loud clacking sound, jamming in fuser ? sounds like the gear that turns the fuser are bad and not meshing together,
accordion jam is the fingers or claws that ride on the fuser roller are probably worn out ( these can be replaced usually 3-5 ).
You can buy the parts and replace them yourself if a handy person, not that difficult.
Nov 19, 2008 | Sharp AL-1642CS Copier
41 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
George Mclaughlin
Ed
Ed
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
