Question about HP PSC 1315 All-In-One InkJet Printer
Hp psc 1315 printer doesn't want to turn on
Upon plug in the outlet, the printer doesn't want to turn on or the lights are not turning on so that we can't use the printer
Setup driver
Posted on Dec 29, 2008
Hp PSC1210 All-In-One not turning on
HP makes a couple of different power cords for the PSC 1210 and their other printers. First make sure you are using the correct power cord (Amperage and voltage). Unplug the power cord (from the wall and the printer and from a power module if you have one). Leave all of the sections unplugged for at least 15 seconds to reset the power module/printer.
Next connect the power cord to the wall outlet and to the power module if present and check if the LED (if present lights up). If it doesn't try another outlet. In either case, check what the outlet voltage/amperage is at the end of the power cord with a multimeter (before you plug it into the printer). If you have a power module, then check the Amperage (it will be a DC current out).
If you are not getting the correct voltage and amperage out or the LED doesn't light (with a known good outlet), try a different power cord/module.
You can order these from HP.
If you have the correct power at the cord, plug the power cord into the printer and attempt to turn it on. (Press and release the power button.) If the printer still doesn't come on, the unit needs service. Contact HP if the printer is under warranty. Decide if it is worth fixing if it is out of warranty.
I hope this helps.
(I've had to use the HP Repair/Replacement service after a unit was in a home that was hit by lightning. Due to printer availability, an HP gift card was provided to buy a new printer.)
Dec 11, 2011 | HP PSC 1210 All-In-One InkJet Printer
On my HP 1315 it shows check print cartridge light blinking what do i do?
First, remove the cartridges and then replace them correctly. Also check for ink levels.
Sometimes this will correct the problem. If it doesn't, let us know.
Sep 19, 2011 | HP PSC 1315 All-In-One InkJet Printer
I have a psc 1315 all in one printer. When I turn it on it shows it has paper and no errors. When I go to print it won't feed in the paper and just goes into error mode and says check paper. I have the...
try resetting the printer:
  1. Turn on the PSC 1315 by pressing the "On/Resume" button until it lights up. Ensure the printer's USB cable is securely plugged into the back of the machine and the attached computer.
  2. Remove the power cord from the back of the printer. Do not unplug the other end of the power cord from the power outlet.
  3. Press the power cord back onto the metal plugs located on the back of the printer. Make sure you insert the power cord completely into the plug area to ensure a proper connection.
  4. Press the "On/Resume" button on the printer's control panel until it lights up. Allow the printer to complete its warmup process.
  5. Attempt to print with the device if no error messages are displayed.
Mar 14, 2011 | HP PSC 1315 All-In-One InkJet Printer
Where is the plug outlet for the HP PSC 1315 all in one printer. Is it on the back of the printer?
Here's s shot of the back of the printer. The end of the power cord is highlighted.
Nov 30, 2010 | HP PSC 1315 All-In-One InkJet Printer
I downloaded HP PSC 1315 All-in-One Print/Scan/Copy Device Printer but on my pc it is showing HP psc 1310 series .is it the same ?.i am not able to print a word document ,when i click print it goes to...
1.Download from here the correct driver
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=374569&lang=es&cc=mx&taskId=135&prodTypeId=18972&prodSeriesId=360489
2.Uninstall all about hp printer software that you have
3. Power cycle the Pc
4. Reinstall the new downloaded driver
5. Finally plug in the printer and turn it on
Aug 15, 2010 | HP PSC 1315 All-in-One Printer
How do i clean my hp psc printer 1315, dissemble?
I have the same question. I want to clean the inside of HP PSC 1315, I want to get beyond the scanner glass. I tried to use a screwdriver to unscrew the four screws on the four corners of the printer, but the screwdriver doesn't fit. Is there a special tool to use it. Were you be able to dissamble the printer ?
Please let me know. Thanks!
Jul 19, 2010 | HP PSC 1315 All-In-One InkJet Printer
It automatically print a page everytime I start my hp psc 1315
Hi Siddarth
In HP PSC 1315 printer after replacing new Ink Cartridges the printer always prints Alignment test page every time you turn it ON.To resolve this problem you must complete the alignment process.
Steps
1.Turn the printer ON.
2.Once its ON, it will print the Alignment page. Place the page in the scanner bed correctly.
3.Then Press START SCAN button.
4.The power light will start blinking, wait until the power lights turns solid.
5.Now Alignment process is over.Discard the paper from scanner.
6.Turn the printer OFF and then ON, it will not print that page again.
Note:Please follow this steps every time when you replace the Cartridges.
Thanks
Rizwan
rizwan84tx@gmail.com
Dec 08, 2008 | HP PSC 1315 All-In-One InkJet Printer
Will not turn on
if printer in warranty. you contact to hp service station .
Sep 06, 2007 | HP PSC 1315 All-In-One InkJet Printer
Power problem
Check for a fuse. Look inside he users manual and see if they list one or show where one might be located.
Aug 29, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
55 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
