Question about Haier XQG65-8SU Front Load Washer
Loose drum!!!! Hey, i have a haier front loading machine, and the drum seems to be loose, i´ve taken it apart but cant see how to get into the outer drum to tighten up the connection to the inner drum, any idea`s?
  • Anonymous Mar 20, 2014
    aquarius AQXXL149PI
    President:
  • 1,462 Answers
Inner drum is tightened usually with a bolt thro the main pulley (sometimes a nut) but this is unlikely to be the problem. suspect you bearings have worn.
Posted on Apr 24, 2007
Indesit WIL143UK knocking noise
Most likely the suspension gone a bit loose. Try with lesser load
Nov 10, 2013 | Indesit W 123 Front Load Washer
Drum rotating unevenly, squeaking
If the drum moves up/down side/side without the outer drum moving, bearings gone, replace. To check for clothing, which I doubt, remove front seal outer section, look around outer part, to bottom you probably find clip, prise apart, front back, not side ways, refit sideways
Mar 16, 2013 | Maytag MAH2400A Front Load Washer
WHIRPOOL washing machine drum out of alignment and making horid noise
There are no alignment adjustments for front loading washers. The only issue that could exist to make this type of problem is if the spider or support arms that hold the wash drum true in the washer are broken. You can verify this by removing all items from the washer and spinning the wash drum by hand. If it is sagging or rubbing against any part of the washer as it spins, then the spider is broken.
It is an expensive repair, since the washer needs to be taken apart and the wash drum and spider assembly has to be replaced and maybe the outer plastic tub may also need to be replaced. Get a few estimates before deciding whether to repair or replace. Sorry.
Mar 23, 2011 | Whirlpool AWZ412 Front Load Washer
When the machine goes into spin cycle there is excessive vibration as if something was loose in the drum. Other wise the machine cycles fine. Is there someway to check for bolts or nuts loose on the drum....
Move the drum around by hand and listen carefully. There should be no loose bits or rattling, if there are it is possible that something has slipped in between the drums. It sounds as if the drum bearing may be failing. Grip the inner drum and move it up and down at the front while feeling for play relative to the outer drum. i.e hold outer drum and lift inner drum relative to where you are holding. There should be virtually no play.
Jan 05, 2011 | Kenmore HE2 Plus Front Load Washer
Can't separate basket from tub
look insidethe drum and at the back in the middle of the drum do you see a cover of some sort if so it may be covering screws hold it in.Just a guess not sure without seeing it
Aug 23, 2009 | LG WM1814CW Front Load Washer
Kenmore Elite Dryer Blower fan is loose
in the back opf your dryer the drum runs on 2 black rubber wheels when they are worn out it will giveyou that kind of noise replace them they cost about 8.00 each there is two of them you van see one from the bottom right side in the back of the drum if you remove the front lower panel thanks from gilles
Mar 15, 2009 | Kenmore Elite HE4 Electric Dryer
How to take apart drum assembly on kenmore front load washer
Is this a HE2,5,4 model? Can you give me the model number from inside the door. If it's a front loader. The only way you can get it out is to totally tare it down, cement, springs, shocks, and crack apart the outer tub. Very very labor intense. Usually if the unit is out of warranty, the cost of a tech to do it isn't worth it. What's the issure with it?
Jan 24, 2009 | Washing Machines
The drum bangs on the spin
Two possibles for this are aloose balance block or cracked drum spider.The front block is most prone to coming loose.
To check spider rotate drum little by little and pull towards you to check for movement.
Post back if further help needed.
Thankyou
Dec 19, 2008 | Hotpoint Aquarius WF220 Front Load Washer
Haier Washer M # XQG50-11
Once you remove the rear access panel, you would see the main pulley on the rear of the outer tub. You need to remove that nut with a metric allen wrench. once the pulley is off, you can then remove the bolts holding the yoke in place. The Yoke and the bearings are available as a part assembly from haier. It is highly unlikely that you would need to replace the outer tub.
Mar 07, 2008 | Haier XQG50-11 Front Load Washer / Dryer
Haier XQG65-8SU Front Load Washer Logo
806 people viewed this question
Top Haier Washing Machines Experts
shaun taylor
Jim Goldsmith
Jim Goldsmith
Marvin
Marvin
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
