Question about Ariston Technologies ASL75CXSNA 24" Ventless Dryer with Delay Timer in Platinum
Ariston avxl129 Washing Machine, delay timer flashing??
The delay timer on my washing machine has somehow come on and is stopping the machine from completing the cycle. When I turn it off then back on the cycle runs but only for a minute before reverting to the delay mode. How do i turn this off!!!???
SOURCE: Washer not completing cycle
I HAD THE SAME PROBLEM ON A 4 MONTH OLD MACHINE AND I CALLED A SERVICE PERSON. HE SAID THAT I CAN THROW IT AWAY. THIS IS A PROBLEM THAT NOBODY CAN FIX.
Posted on Feb 15, 2007
  • 183 Answers
SOURCE: Flashing Lights on Ariston A1636 & Won't progress to rinse either
Suggest checking for a faulty heater. Regards Engineer
Posted on Jul 29, 2007
SOURCE: ariston 6kg washing machine
Do you have the "easy iron" feature on? If so, the clothes will stay in water until you manually rinse it.
Posted on Jun 13, 2008
SOURCE: ariston margherita washing machine
I have an old Margherita washing machine year 2000, my problem I don't have user's manual. Can you please provide me or teach me how to operate the machine?
Thanks & regards
ray salac
Posted on Sep 03, 2008
  • 236 Answers
SOURCE: Washing machine is not completing it's wash cycle
either you have a blocked hose to the pump or the pump itself is either jammed or the impellor has come off the shaft. either way i think you will need to replace the pump. i presume you managed to get the water out? if so i would say the pump is favourite.
Posted on Mar 16, 2009
Why are my clothes dripping wet after the spin cycle I have a ariston front loader avxl129
sounds like the pump could be unable to get the water out after the wash. check the door into the pump, at the bottom front of your machine
Aug 12, 2014 | Ariston Technologies Washing Machines
Ariston avxl 140
Check that you don't overload the machine. This can happen if the load is too heavy.
Jan 31, 2014 | Washing Machines
I can't stop the dryer from coming on Ariston AL128D, I just want to wash
Hi there, the F button on your washing machine (see manual http://www.gebruikershandleiding.com/Hotpoint-Ariston-al-128-d-margherita/preview-handleiding-431405.html?page=0004) is the clue. if pushed in it won't dry. don't know why, but by trial and error this seems to work
Sep 12, 2012 | Ariston Technologies AL128D Margherita...
We just bought a second hand Ariston Washing Machine model AVL 95. It works fine all programs, but when it goes to spin, it starts to spin, speed up, and then stops with an error (Delay Timer flashes and...
its the drain pump see if you can take it out there small and easy to get to,also you see a black ribbed hose that goes to the drum to the pump see if there any thing in it.The drum is inclosed.try running 2xclorox through machine.
Jul 05, 2010 | Ariston Technologies AWD120 13 lb. Washer...
Washing machine wont spin
Maybe something is physically preventing the drum from spinning, causing the motor protection to kick in and stopping the machine.
I'd check this out as a first step before calling a repair man:
1) unplug the machine from mains
2) make room between the rubber gasket and the drum for your hand/arm to reach down into the bowels of the machine, in the compartment between the drum and the bowl (or whatever you call it). If you find something strange there, remove it.
I've done this on occasion and have found lots of obstructing objects that don't belong there. Most notably hardware from underwire bras I might add... :)
It is worth a try.
May 21, 2009 | Ariston Technologies Washing Machines
Soon as i set cycle and swich on door light flashes open
hi,
The cycle doesn't advance
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Thanks for your question.
Jan 03, 2009 | Ariston Technologies AW129NA 16 Lbs Front...
Ariston delay timer problem AVXL129 washing machine
It appears your timer has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 28, 2008 | Washing Machines
Ariston Margherita 1635
try putting timer dial to the black dot and holding the start button until the red light flashes,then try selecting a new cycle.not sure what country you are in, aristons might be set up different in australia.hope this helps.
Feb 27, 2008 | Ariston Technologies AW149NA Washer
Ariston Technologies ASL75CXSNA 24" Ventless Dryer with Delay Timer in Platinum Logo
165 people viewed this question
Top Ariston Technologies Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Oloyede Monsuru
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
