Question about GE NSXMA845 Shelf System
Aiwa nsx-ma845 cd tray stuck
Our system was in storage for 5 years, we set it up today and the cd tray opened and does not want to move in or out. We shut the system down and tried to clear it but still wouldn't budge. Any help is appreciated.
  • 36 Answers
CD drives have rubber belts and wheels - 5 years is a long time, perhaps these are worn out. A new CD/DVD drive is very inexpensive.
Posted on Dec 28, 2008
I have an Aiwa NSX-R20 and the cd changer won't move so I cannot load 3 discs and if I close the unit it opens again.Please help
Mine did the same, look underneath the tray when open, you'll see a rubber drive belt which has probably perished. You may have to remove the cd carousel, one screw in the middle, for access. Replaced mine with an elastic band and am back in business.
Sep 06, 2017 | Aiwa Audio Players & Recorders
I have an old Aiwa NSX-V150M Compact Disc Stereo System. I cannot load CD's into the unit. Pressing the "Load" button causes the internal mechanism to cycle up and down 5 or 6 spaces and then a "CHECK"...
Hi! I also have an (old) NSX-V150M that does nearly the same, I suggest two problems on mine: 1) maybe the laser assy has to be changed because it doesn't detect the actual CD anymore and skips to the next one. 2) there is a tiny limiting switch on the moving platform that seems defective, or the rubber belt (?) is too stretched, so that it doesn't detect when the CD is in place from the changer. Then the unit starts again "CHECK"ing, as when the memorized list of CDs doesn't match the detected list of CDs. For the first one, maybe the Sony KSS210 or KSS213 spare part could be used, not sure of it. For the limiting switch, I have glued a match to keep it in place to keep the CD part quiet. Result: no more CD playing for now, but the unit doesn't "CHECK" anymore, and tuner and amplifier still work great. Need to look inside one of these days.
Jan 09, 2013 | Aiwa Audio Players & Recorders
My aiwa cd disc rotating tray is not working i don,t know what's wrong with it
hi there i know wht is problem rotary changer systems like 5 disic or 3 dics chnager.i have 2 oprions for that 1 is,from cd chnager belt small belt between motor another also mechanism like small tears lack white if there not good oily enaugh,maybe stock with tooth,DO u hear motor when u tray chnage disc 1;2;3? if motor burn rotary change then never will work,Some times belts getting older in cd rotary changers.the gey slepery,like flashy,but i hope will help your problem.Regards,Emil
Sep 13, 2012 | Aiwa NSX-DS55 CD Shelf System
I have a nsx-a508 unit,the 2nd tape deck got stuck i was able to open it but now neither deck plays and the cd player did work when this happened originally but does not work now ,the lights all come...
I think I can help you with the tape part, but as for the CD, that's a whole different story.
First, you should reset the unit by holding down the stop button (clear), and then pressing the power button. Everything stored in memory after purchase is cleared, including the radio stations, clock, etc.
Check if deck 1 is now playing.
I had a similar problem with my AIWA NSX-AJ310, and after some digging up, I realised that the belts were busted. They're not hard to replace though, unless you don't trust yourself to replace them. If you don't, let a qualified technician see about that for you.
The CD player in my system has retired also, so, we're in the same boat as with regard to that issue!!
Hope my solution was helpful!!
JaHa
Jun 21, 2011 | Aiwa NSX-A505 CD Shelf System
Hi! I have a problem for reading CDs with an aiwa hifi system
the spindle motor goes bad a lot on these aiwa cd unit
May 12, 2010 | Aiwa NSX-DS55 CD Shelf System
I have two aiwa nsx-d737 stereos with basically the same problem. On the one, the CD tray will not oepen and the display shows that it is playing a CD when it's not. On the second one, the CD tray will...
Hallo! Mayby you can sell my one of your aiwa nsx-d737 stereos? I've been dreaming to get it for a long time, but I can't find it nowere in Russia. I ready to pay all transportation costs and expances. May I also ask you to write me back on e-mail zhivulko@gmail.com even if you can"t or do not want to sell it?
A milliomn thanks))) Olga
Jul 13, 2009 | Aiwa Audio Players & Recorders
The tray of cds does not work properly, does not allow the change of disc to disc and stuck
Try pressing repeatedly the eject button while you turn on the unit. If this doesnot work
then it is a mechanically problem in your player .
You need to manually open to take out the cd .
The rubber thread which should be connected to the motor inside the cd player might have moved from its place.
You need to place the rubber thread to proper place.
Also if the belt is slipping, the mech never gets the "drawer closed" signal, and the disk will not spin.
Mar 04, 2009 | Aiwa NSX-A505 CD Shelf System
No sound from stereo
If you can hear a hiss then the spkrs and amp are OK. It sounds like you're not on whichever source you're wanting to hear or it is on mute. Make sure ther is no function enabled that turns the sound off or over-rides it (like a tape monitor or AUX in...).
Sep 09, 2007 | Aiwa NSX-DS55 CD Shelf System
CD Changer
Common Problem with AIWA 3 disc machines. I have 3 in my service shop right now. For tray not rolling in on it's own, the drive rollers have to be changed, along with the Drive Belt. Also, for CD not reading, try CD lens cleaner.
Sep 10, 2006 | Aiwa NSX-A115 Shelf System
213 people viewed this question
Top GE Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jim Goldsmith
Jim Goldsmith
john1959ny
john1959ny
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
