Question about Frigidaire GLTF2940ES Front Load Washer
Frigidaire FEFB9200ES0 not draining water
I have a Frigidaire FEFB9200ES0, and the water is not draining. We checked the drain pipe, and it's not clogged, and straightened the drain pipe, but those two options are not working. Also, what does LOC mean? It appears on the display when I try to start it.
H taello.You probably have to clean the filter.On the bottom of the front of the machine there are three screws.They are philips head.When you remove these screws the panel below the door will slide off.It's really easy so don't be nervous.Then if you look to the right side you will see a round 3 inch face with a handle grip built into it.They normally have a black magic marker mark on it.This tells you where to tighten it to when you put it back on.When you turn it counter clockwise it will undo.Then you pull it outwards and you will see all the stuff plugging it up.Clean it out and put it back in.This may have to be done on a regular basis.Then your machine will drain properly.Hope this helps.
Posted on Dec 28, 2008
Frigidaire FAC107S1 water drains into the house
One: The drain hose has come out of the house plumbing drain pipe or Two: The house drain pipe is plugged up.
Sep 17, 2015 | Frigidaire Washing Machines
Washing maching will not drain
Good Morning Friend,
I understand that you are having trouble with your Frigidaire washer, model# FWS1339A, draining water. Here are a couple of suggestions that you can try.
    1)Check the drain hose for any kinks or clogs. Also, make sure that the drain hose is only 6-8 inches down in the drain pipe. If the drain hose gets backed up with water this error can occur.
    2)Make sure that the actual drain pipe, where the drain hose goes into, is only a maximum height of 8 feet. If it is longer than 8 feet, you will need to cut some of the pipe off.
    3)Make sure that your homes drain pipes are not clogged. If they are, you will need to unclog them. Call a plumber if necessary.
    After checking the above suggestions, reset your washer by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When you restore power, start any cycle on your washer. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
May 15, 2014 | Frigidaire FWS1339A Top Load Washer
Why wont frigidaire washer drain?
I understand that you are having trouble with your Frigidaire washer draining. Here are a couple of suggestions that you can try.
    After checking the above suggestions, reset your washer by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When you restore power, start any cycle on your washer. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your range status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
May 15, 2014 | Frigidaire Washing Machines
Have a frigidaire GLTF2940EEO will not spin. it washes..just no spin any ideas?
Take the power plug off the wall. Be prepared for a lot of water before attempting the following: It doesn't spin because the unit is not draining water. It will not spin with water in it - must drain first. Check drain hose for kink,check exit pipe for blockage. Remove the front access panel, bottom front; if you find a pipe there with a cap -this is for draining water.Could be your "coin trap assembly" is blocked, therefore not allowing all the water to pump out. Remove the clamp that connects the trap assembly to the pump and clean it out.
If helped, pl say so.
Apr 01, 2013 | Frigidaire GLTF2940ES Front Load Washer
Fiirst started with a buzzing noise, then next load wouldn't spin proper, then not at all, unplugged washer to reset, tried a small load and it won't run water now,after running 10 to 15 minut
Take the power plug off the wall. Be prepared for a lot of water before attempting the following. It doesn't spin because the unit is not draining water. It will not spin with water in it - must drain first. Check drain hose for kink,check exit pipe for blockage. Remove the front access panel, bottom front; if you find a pipe there with a cap -this is for draining water. Could be your "coin trap assembly" is blocked, therefore not allowing all the water to pump out. Remove the clamp that connects the trap assembly to the pump and clean it out.
Apr 01, 2013 | Frigidaire Washing Machines
Water will not drain out of drum
Take the power plug off the wall. Be prepared for a lot of water before attempting the following. It doesn't spin because the unit is not draining water. It will not spin with water in it - must drain first. Check drain hose for kink,check exit pipe for blockage. Remove the front access panel, bottom front, screws beneath; if you find a pipe there with a cap -this is for draining water. Could be your "coin trap assembly" is blocked, therefore not allowing all the water to pump out. Remove the clamp (or unscrew) that connects the trap assembly to the pump and clean it out.
If helped pl say so.
Mar 24, 2013 | Frigidaire Washing Machines
I took clothes out of my frigidaire affinity washer and there is water resting in the drum of the washer what does this mean
Mar 18, 2013 | Frigidaire ATF6000ES Front Load Washer
My Frigidaire washer will not drain. It work
check all the drain hoses for something caught in the line to the drain from the tub thru the pump to the stand pipe at the drain,you may have a plugged line and machine pump wont start due to this restriction
Mar 13, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer won't drain or spin
This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
Nov 12, 2008 | Frigidaire GLTF2940ES Front Load Washer
Dishasher does not drain
If it gravity drains, but the pump does not push out the water.......replace the drain pump. I just repaired an 8-year-old  Frigidaire dishwasher with this very problem, and although it sounded like the pump was operating, it was not....it was just vibrating. I replaced the drain pump and it now works perfectly. I am a service tech with 38 years experience.
Jun 21, 2007 | Frigidaire 24 in. FDB635RF Built-in...
Frigidaire GLTF2940ES Front Load Washer Logo
151 people viewed this question
Top Frigidaire Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Jason Harris
Jason Harris
Sal De
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
